BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Wheel Spacers - Flush Fitment
      10-24-2012, 12:50 PM   #1
Alex@ONEighty
Alex@ONEighty's Avatar
Drives: 2011 E90 M3 CZP 6MT
Usually cars come with the wheels buried inside the quarter panels or front fenders. To bring them out a little and have a flush fitment look you can purchase and install wheel spacers. This vehicle has 15mm wheel spacers in the rear and 10mm wheel spacers in the front. As you can see the fitment is perfect.
      10-25-2012, 08:53 PM   #2
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
looks good! how much?
      10-25-2012, 09:06 PM   #3
's Avatar
61
Drives: ✚
I emailed Burger Tuning about their 15mm spacers and they said that it will rub if your car is lowered.
      10-25-2012, 10:11 PM   #4
Alex@ONEighty
Not sure if it will rub or not when lowered because it all depends on what tires/wheels your running and what drop your planing on getting.
We sell 15mm spacers in black w/ black bolts for $80 shipped. They are hub centric as well.
      10-25-2012, 10:30 PM   #5
martinf79
martinf79's Avatar
62
Drives: F30 335i M Sport
Any vibration? I was told that you would have to go w/ at least 13mm in front + rear in order to have no gap between the spacer and the hub?
2013 335i ///M-Sport | + 2015 X3 28i xLine
      10-26-2012, 01:23 AM   #6
F555
F555's Avatar
Indonesia
25
Drives: F30 - 335i
Fit Perfectly
      10-26-2012, 02:12 AM   #7
's Avatar
61
Drives: ✚
Who makes 13mm spacers for the F30 rear? I'd like to know. I was told that 5mm and 15mm are the only sizes that fit the F30 rear due to the hub lip protruding more than previous generations.
You can fit other spacer sizes on there... but you have to file down the hub lip.
      10-26-2012, 08:20 AM   #8
Alex@ONEighty
Not true. We were able to put a 10mm in the front as well. No vibrations, they are hubcentric. Just needs proper installation.
      10-26-2012, 08:20 AM   #9
Alex@ONEighty
      10-26-2012, 11:30 AM   #10
's Avatar
61
Drives: ✚
I was talking about the rears. Any size will fit on the front.
      10-26-2012, 11:59 AM   #11
Alex@ONEighty
Got it... Good to know
      10-26-2012, 10:46 PM   #12
Joshhleee
///M Enthusiast
Joshhleee's Avatar
so no rubbing at all with stock height right?
      10-26-2012, 11:53 PM   #13
martinf79
martinf79's Avatar
62
H&R told me they were releasing a 13mm spacer specifically to accommodate the rear hub lip of the new f30. You can't use a 10 or 12mm spacer on the rear.
      10-27-2012, 11:41 AM   #14
remmib
remmib's Avatar
Norway
1154
Drives: 2013 F10 520d M-Sport
Any pics of this larger rear hub lip? How much larger is it than the front?
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      10-29-2012, 01:25 PM   #15
scott@bmwhn
Drives: Msport X3
Good info. Thank
15' Msport X3 28i _Mperformance - ACschnitzer - H&R_
15' Sportline X1 28i _Mperformance - H&R - Recaro baby seat_
Previous:13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      10-29-2012, 02:11 PM   #16
martinf79
martinf79's Avatar
62
13mm Spacers (H&R) for F30
http://store.allsprings.com/bmw-f30-...120-p3721.aspx
      01-15-2013, 08:01 PM   #17
s1k0ne
Drives: ..
Did you install extended lugs or did the 10mm and 15mm fit without any problems?
F80 M3 '18 | ordered
F30 335i 6MT | modified
      01-16-2013, 03:23 AM   #18
's Avatar
61
Drives: ✚
If you get 10mm or larger spacers, you will absolutely need to get extended bolts. I tried a 10mm spacer with the OEM bolts just to see how it would look (didn't drive on them). The OEM bolts barely had about 2 revolutions of bite.
If you decide to use the OEM bolts, be sure to video tape it and upload it to YouTube. You'll become famous like this dude.
      01-16-2013, 09:35 AM   #19
Alex@ONEighty
You def. need longer bolts. You can purchase spacers HERE, they come with extended lugs and I'm running them with no issues.
Here are some photos of my car running spacers as well: http://www.f30post.com/forums/showpo...4&postcount=23
      01-16-2013, 11:16 AM   #20
mikew2069
mikew2069's Avatar
58
Drives: F30 335i MSport
Have you had any rubbing issues over big bumps or speed bumps after your drop?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      01-16-2013, 02:55 PM   #21
's Avatar
61
Drives: ✚
I'd like to know as well. I was told that the 15mm will rub when lowered.
      01-16-2013, 03:44 PM   #22
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
What's the quote for them installed?
I was planning on coming to the coding meeting on 2/2/13 at your store, but can't anymore...
I'd love to get coding/spacers done at the same time!
I have a 20mm drop from stock height, let me know if that'll work...
I was told I had to go with 12mm F and 15mm R here: http://www.f30post.com/forums/showthread.php?t=786701
SOLD: 2012 335i Mineral Gray
f30, spacers, wheel
