BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > What RPM do you release clutch at
Vorsteiner
      10-26-2012, 12:49 PM   #1
snowghost
Drives: '13 335i M-Sport 6MT
Just wondering that after driving my 6 speed manual for a week now. The clutch engages so smoothly you can practically let it out at engine idle.
Haven't tried a super fast start yet due to break-in.
[SIGPIC][/SIGPIC]F30 Sapphire Black 335i 6MT|2PE|4AB|LCSW|ZDH|ZMM|ZPP|ZCW|ZDA|ZDB|ZTP|5AC|4 15|688|Dinan Stage 1 Suspension and Shockware ECU tune
Previously - F30 335i, E46 M3, E39 530i, E46 325i
      10-26-2012, 01:12 PM   #2
DrivenByE30
DrivenByE30's Avatar
France
461
Drives: '12 F30 Lux 335i 6MT
i am not sure i understand your question ?
sorry i am a bit under the weather today.
      10-26-2012, 01:15 PM   #3
JYohay
Drives: 2011 X5
what he is saying is what rpm do you brign the car up to before you engage the clutch
buddy your doing it all wrong.
it should be at the same time you give it gas and engage.
but if your doing it the wrong way.....just keep them as low as possible.
unless your doing a burn out in which i drop it from like 3500
      10-26-2012, 01:18 PM   #4
snowghost
What I was saying is I give it gas and let it out at idle--if that makes sense. Rather than do any revving before release.
      10-26-2012, 01:29 PM   #5
DrivenByE30
France
461
you mean on the first gear, as you start off the line from Zero...
that's what i usually do anyways...: let go of the clutch to the clutch point, then rev/gas it if necessary as you slowly lift up the clutch... ..
I dont see any difference between clutching this F30 to my previous cars: E46, E36, OR E30...
bmw has had this nice long clutch feel...
      10-26-2012, 01:33 PM   #6
nsquared
[Versatile]
nsquared's Avatar
44
Drives: (S)LOW.
Not to thread jack but! with the six-speed manual and with ASS on and in eco-pro mode - if you were rolling down a hill or rolling in general to a stop sign does the car still shut off even though its a brief stop?
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
      10-26-2012, 01:41 PM   #7
ric124
ric124's Avatar
Jamaica
392
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
With Manual we have full control of the ASS. It only kicks in if car is in neutral and foot off the clutch.
      10-26-2012, 01:42 PM   #8
ric124
ric124's Avatar
Jamaica
392
2017 BMW M2  [0.00]
in sport+ use launch control and the rev is held at 3500rpm and lift clutch when ready to go.
      10-26-2012, 01:43 PM   #9
nsquared
[Versatile]
nsquared's Avatar
44
Drives: (S)LOW.
So in neutral and rolling down a hill, the car is off if ASS is on or is it off only when rolling to a stop while in neutral?
      10-26-2012, 01:46 PM   #10
DrivenByE30
France
461
as soon as you clutch, the engine start up again... and it's quite fast
I dont know why so many people complains about it, but i dont see the car vibrating anymore due to ASS over a regular engine start...
if anything it's the same...
      10-26-2012, 01:49 PM   #11
DrivenByE30
France
461
when you roll, the engine is never off ... it doesn't matter if you are in gear or in neutral... the reason is because you need power to the power steering.
The only time the engine shuts off, is when you are STOPPED, off the clutch and in neutral.
      10-26-2012, 01:53 PM   #12
nsquared
[Versatile]
nsquared's Avatar
44
Drives: (S)LOW.
Good and not complaining just questioning. Then, in eco-pro mode/ASS on with the car in neutral - at a stop sign (brief stop) does the car shut off and on?
      10-26-2012, 01:53 PM   #13
BavarianFanatic
Too much is never enough
Drives: Too Many
Why would you ever roll down a hill in neutral while driving?
      10-26-2012, 01:54 PM   #14
nsquared
[Versatile]
nsquared's Avatar
44
Drives: (S)LOW.
I neutral drop all the time. Huge hill and traffic is little to none, why?
      10-26-2012, 01:58 PM   #15
BavarianFanatic
Drives: Too Many
You need to make sure you've got enough revs to avoid bogging/stalling the engine. It's not really a function of the smooth engagement of the clutch. This point will vary depending on the load required to get the car moving - i.e. flat, uphill, downhill, etc.
You actually CAN engage the clutch in most cars at idle so long as you do it smoothly. But this isn't the best for the longevity of your clutch.
Are you new to driving manuals or just soliciting feedback specific to the new car?
      10-26-2012, 01:59 PM   #16
wai2sexy
Drives: 2012 335
7k rpm
      10-26-2012, 02:07 PM   #17
DrivenByE30
France
461
as the driver, It's entirely up to you...
If you come to a stop sign (brief stop as you describe)
The car shuts off or not is depending on your actions:
1) if you get to the stop, but hold the clutch while stopped, the engine does NOT shuts off.
It stays on because you are still on your clutch.
2) if you get to the stop sign, put your car in neutral and dissengage the clutch, then the engine will shut-off for however long you want... until you are ready to go again, just engage your clutch, and your engine will start up again.
      10-26-2012, 02:07 PM   #18
BavarianFanatic
Drives: Too Many
??? You can't neutral drop a manual trans. A "neutral drop" is revving the motor in neutral (at rest) and slamming the auto trans into drive.
The manual equivalent is "dumping the clutch" which is essentially the same with the exception of side stepping the clutch as opposed to releasing it gradually.
Both of these techniques are very good at destroying drivelines.
There's really no benefit to putting the car in neutral unless you just want to coast and see how much speed you pick up. You're not saving any gas if that's your motive.
      10-26-2012, 02:38 PM   #19
ric124
ric124's Avatar
Jamaica
392
2017 BMW M2  [0.00]
Correct, better you put the car in 6th and come off the gas. At that point you are using no gas and car is just rolling and engine is compressing.
      10-26-2012, 03:49 PM   #20
nsquared
[Versatile]
nsquared's Avatar
44
Drives: (S)LOW.
I'm saying going at like 20/30 miles per hour down a hill haha.
      10-26-2012, 04:30 PM   #21
BavarianFanatic
Drives: Too Many
You actually shouldn't just jump to 6th. You can still lug the motor depending on your speed. A gear that's more appropriate for the speed is best.
No matter what gear you're in, there's no fuel delivered while coasting downhill. There IS if you're in neutral however....
      10-26-2012, 04:31 PM   #22
BavarianFanatic
Drives: Too Many
I still don't understand WHY though?
