BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > First impressions of my F30 335i xDrive
Extreme Power House
      10-29-2012, 01:20 PM   #23
sean10mm
sean10mm's Avatar
Drives: '13 335i xDrive 6MT ZDH
Recommended fuel quality
BMW recommends AKI 91.
Minimum fuel grade
BMW recommends AKI 89.
! Minimum fuel grade
Do not use any gasoline below the minimum
fuel grade as this may impair engine performance.
If you use gasoline with this minimum AKI Rating,
the engine may produce knocking sounds
when starting at high outside temperatures.
This has no effect on the engine life.
The use of poor-quality fuels may result in
harmful engine deposits or damage. Additionally,
problems relating to drivability, starting and
stalling, especially under certain environmental
conditions such as high ambient temperature
and high altitude, may occur.
The car CAN run on 89 but BMW thinks you SHOULD use 91.
      10-31-2012, 09:17 AM   #24
JK479
Drives: 8 Speed Auto Bimmer
I am truly impressed a dealer has a 6 speed, M sport and no plate installed! The stars aligned on this purchase. Perfect options combo!
