BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Will they fit?
Vorsteiner
      10-26-2012, 05:34 PM   #1
chip2058
chip2058's Avatar
Drives: 2012 328i Sportline
Will they fit?
Okay, I've read debate back and forth and spoke to two different BMW dealers who are both clueless.
I have a set of BMW Style 158 Rims. They were the former Winter Package for the E92.
They're 17" with a 34ET offset and are wearing 225/45/17 Rubber.
I know 225/45/17 isn't a true minus size but will that cause any problems?
I also know that the TPMS won't work, but should the wheels work and are there any problems to running the different ratio tire?
      10-26-2012, 11:16 PM   #2
alniri
alniri's Avatar
Drives: C2, ML350, 335
i asked a similar question on the tire rack blog and got this reply:
Thursday, October 25, 2012 by michael:
I have 225/45/17 winters on ASA rims from my 2007 335 that I would like to use on my F30 335xdrive. I don't need the sensors because I'm in Canada. Can I use them on the F30 and what will the downside to using 45 profile tires instead of the recommended 50?
Thursday, October 25, 2012 by Gary:
Michael,
Yes, you can use the shorter 225/45R17 size on the new F30. The tires are an inch shorter in diameter so the speedometer will read faster and the lower profile tires ride more stiffly than a 225/50R17. You should run the tires at 36psi or higher to maintain the proper load capacity.
http://blog.tirerack.com/blog/make-d...w-tires-faq-v1
      10-30-2012, 06:31 PM   #3
kitster
Drives: F31 320d M Sport
Hi,
Bit of an obvious question but am I right in assuming you would just use the standard F30 bolts? If the wheel offset between the E9X and F3X are the same.
Thanks.
      10-30-2012, 09:24 PM   #4
chip2058
chip2058's Avatar
Originally Posted by kitster View Post
Hi,
Thanks.
That was my plan. Mainly since the car is only 6 months old I don't suspect there too be much corrosion.
That being said, does anyone know what the correct torque is?
