BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > M Performance brakes coding
      10-31-2012, 02:21 PM   #1
shutterlife
Drives: F30 M Sport AW
Really wanting to install these myself, but read the following coding is required.
"A DSC retrofit encoding must be performed via ISTA/P after installation of the BMW M Performance sports brake system."
Anyone know how to do this or what is required. I'm a very competent mechanic, and have no problem doing it myself.
Just need help with the coding.
Thanks
      10-31-2012, 02:59 PM   #2
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Check this one for help on the coding
http://www.f30post.com/forums/showthread.php?t=696777
      12-07-2012, 09:41 AM   #3
chlemaire
Drives: 2013 335i M-Sport Line
Thanks
Hi Shutterlife,
Did you end up installing these M-Performance brakes? If yes, can you please comment candidly on your assessment of the braking performance gain, if any, and on the brake pedal feel?
I had these installed, and despite two re-servicing at the dealer, I am hugely disappointed in the pedal feel (soft and spongy) and the braking performance (no noticeable improvement, perhaps even a degradation).
      12-08-2012, 02:06 PM   #4
shutterlife
Nope, not installed yet. Still wondering how I'm going to do the dsc coding.
      01-03-2013, 02:44 AM   #5
simonchs
Drives: BMW 118i F20
I've installed the M performance brake without DSC retrofit encoding, so far don't have noticeable problem.
      01-03-2013, 06:05 PM   #6
Yobyot
Yobyot's Avatar
56
Drives: MY12 F30 ZSL
But if BMW says the car must be coded, if could only mean one of two things. First, to VO must be updated to indicate that the feature has been added to the car. Or, it may mean that some ECU somewhere needs to know what kind of brakes are installed in order to function. It could conceivably be the ABS or even DSC/DTC systems.
Even the battery in these cars has to be coded. If you stick in a new battery and the car thinks the old one is installed, it overcharges and eventually fries the new battery.
Bottom line: if BMW says the car has to be coded, it has to be coded.
MY12 335i ZSL:
Produced: 2012-06-22; ED: 2012-07-19; Arrived in Jersey City: 2012-08-23; Redelivered: 2012-09-12
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
      01-17-2013, 11:20 PM   #7
ykau
Drives: F30 320I
hi shutterlife, did you installed the bbk with encoding?
      01-18-2013, 12:42 AM   #8
shutterlife
Nope not installed. Haven't event bought yet. Waiting to figure out the coding first.
      01-18-2013, 01:57 AM   #9
kon
Singapore
Drives: F30 316i
coding part:
http://www.f30post.com/forums/showth...A#post13265538
the vehicle was coded by dealer, but try at your own risk
      01-18-2013, 05:11 AM   #10
ykau
Drives: F30 320I
hi kon, thanks again! Just ordered my mperformance brake kit. waiting for arrival.
      01-18-2013, 05:26 AM   #11
kon
Singapore
Drives: F30 316i
Parallel import? Otherwise the dealer would code for you as part of installation, right?
      01-18-2013, 05:32 AM   #12
ykau
Drives: F30 320I
Parallel Import from getbmwparts.com.
btw, is adding VO 2NH should be the same as adding HO-Wort = SPBR ? HO-Wort is something new to me
      01-18-2013, 05:36 AM   #13
kon
Singapore
Drives: F30 316i
If me, I will stick with SPBR. Theoretically, they are the same as 2NH, except M-Performance brake is not a factory option, only M-Sport Brake is.
K word, as I understand it is no diff from VO coding, so after adding the k-word, save the FA into the vehicle, and remember to code the relevant ECU, in this case, just DSC?
My initial research on BMW brakes indicate some market do get different rotor size between M-sport & M-performance brake, but I'm not sure if they are still the same. But at least cosmetically, we know M-perf brake is slotted & dimple drilled, but none in M-sports, again, I'm not sure.... just purely based on what I read, haven't had the chance to see the real thing in close detail yet.
And..... good luck on your parallel import coz I HEARD 320 m-performance brake is different from 328/335 which is what US is selling, I cannot remember exactly what is the difference though
      01-18-2013, 05:42 AM   #14
ykau
Drives: F30 320I
HI Kon , thanks for the explanation. Base on your past experience, iF I would leave the setting as it is,without coding, will there be any difference or impact to safty ?
we have checked the vin number , seem ok. If anything happened, will keep up update.
      01-18-2013, 07:27 AM   #15
clarence
Drives: F30 328i M-Sport
Only option 2NH can be called "M-sport brakes". Cars with M-sport package but without 2NH (i.e. all US-spec M-sports) does not have "M-sport brakes", they only have standard brakes (i.e. identical to other lines with the same engine).
Option 2NH for 328i & above are identical to "M-performance brakes", save for the disc surface. Option 2NH for 320i/d & below have smaller front rotors & calipers as "M-performance brakes" (in fact they're identical to the standard front brakes on the 335i but with blue calipers). The rears are identical on all models. The "M-performance brakes", AFAIK, can be fitted to 320i/d & below.
The source of confusion re brakes is due mainly to US posters with M-sports who call their brakes "M-sport brakes" even tho 2NH is not available there, hence they only have standard brakes (only difference is the pads on US M-sports are same as standard EU-spec pads).
      01-18-2013, 07:31 AM   #16
clarence
U won't feel anything if the car is driven under normal circumstances, but it'll be risky once the going gets tough.
      01-18-2013, 09:23 AM   #17
ykau
Drives: F30 320I
Hi, any facts? thanks
      01-18-2013, 09:39 AM   #18
kon
Singapore
Drives: F30 316i
BMW says coding is required, car is yours, life is yours... you decide
and you know what would be really cool? add-in the K word, but don't code anything... send the car in to the dealer for software upgrade (there seems to be a FEM recall going on now)... and let them code for you
Based on feedback that I receive from some guys, if we does VO code, and send the car in, after the dealer reprogram the car, whatever VO coding we did before, stays!
Make sure you save a copy of the DSC ecu settings, and check again when you get your car back, see if any of the DSC settings changed
... or maybe see if anyone done their own retrofitting, send the car back to the service centre for regular service/update, would the service centre inform you that the brake is not coded and insist on charging you to code it
and sorry to SHUTTERFLY if we've "chat" too much in your thread
      01-18-2013, 10:54 AM   #19
ykau
Drives: F30 320I
hi Kon, so to summaries, for M performance Brake coding , it is sufficient by only adding HO-Wort = SPBR will do?
lol. I guess Shutterfly wouldn't mind because we are talking about coding here.
again, how many time must i say thanks to kon , but thanks again. you are the man!!
      01-18-2013, 12:46 PM   #20
clarence
I think it's more common sense cos the effectiveness of active safety systems such as ABS & DSC depend on the performance of the brakes. The calibration of those systems from the factory are based on standard brakes & hence if u fit M-performance brakes the settings have to be changed.
      01-18-2013, 03:41 PM   #21
simonchs
i've added SPBR to HO-Wort and CODE the DSC module, and found significant differences when step down the brake pedal. feel more firm on the brake pedal.
and when i check the accessory of the ETK, they called M performance brake as Sport brake retrofit kit, so i believe SPBR is the correct retrofit coding for F20/F30 M performance brake
      01-18-2013, 08:01 PM   #22
kon
Singapore
Drives: F30 316i
great!
