BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > M Performance brakes coding
European Auto Source
      02-14-2013, 12:18 PM   #23
SergioK
Drives: F30 328i
Along with DSC other systems are affected by the brakes... from BMW's press release for the F30...
The brake system is further supported by various state-of-the-art electronic safety systems, which are integrated into the Dynamic Stability Control (DSC) system for improved driving dynamics and safety. The DSC system incorporates the following functions: Anti-lock Braking System (ABS), Automatic Stability Control (ASC), Dynamic Traction Control (DTC), Dynamic Brake Control (DBC) and Cornering Brake Control (CBC), along with start-off assist, brake drying and an electronic limited slip function for the rear differential, which can be activated using the “DSC Off” button.
I'd venture to say the above are the reasons the car needs to be coded.
BTW, the four wheel M performance brakes are simply amazing.
      02-15-2013, 01:49 AM   #24
zibawal
Drives: 2012 X5D
Would it be better to install 335i brakes or M performance breaks on my F30 328i , 2013?
I kind of don't like soft breaking pads etc on 328i?
      02-27-2013, 03:16 PM   #25
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
Why not just pay the 1.5-2 hours and let the dealer code it?
They code stuff like this all the time for people that are DIY.
      10-27-2013, 03:36 AM   #26
aapriadi
aapriadi's Avatar
Indonesia
97
Drives: '13 F30 AW 320i
what about those who installed aftermarket BBKs (brembo, stoptech, etc)? do they need coding as well?
mod = crack
      10-27-2013, 11:08 AM   #27
free2d
Drives: F30 335
Same situation here. Thinking of upgrading to Alacon bbk.
My E90 upgrade to m-performance bbk did not do the coding. It runs fine.
      10-27-2014, 12:20 PM   #28
ossanboy
Drives: F30 335i
Halo,
I need to know if coding is needed for AP racing BBK
Thanks
      12-17-2016, 07:49 AM   #29
anom3
Drives: 2007 M3
Heya.
Just did this. I have an F30 with retrofitted M Sport brakes and of course, whoever installed them omitted the SPBR coding.
Thanks for the info guys. Have not test driven it yet as I just finished coding it... But I did find the brakes a bit spongy to be honest.
Will report back regarding what my results are.
Not sure if its mentioned in this post... But I did not go ahead and change the rotor diameter via Esys. I figure if anything there was to be changed, adding the SPBR would have changed it... So I just added HO-WORT SPBR and re-coded my DSC.
Thanks again!
07.07 Production E92 M3 :: Akrapovic XPipe + Rear End | BPMTune Stage 2 Tune | 3M 1080 Metallic Blue Wrap | Black BBS CH-R's | Michellin Pilot Super Sports | Performance Steering Wheel v2.0 | FLA Retrofit | CIC+Combox Retrofit | OEM Carbon Splitters | CF Gills | OEM Black Gloss Grills | MS-8 DSP + HD900/5 Amplifier + JL Audio 12" | LCI Tails Retrofit | Ultimate Clutch Pedal + Clutch Stop | Leatherz M5 Weighted Shift Knob | Much more...
      12-17-2016, 08:43 AM   #30
anom3
Drives: 2007 M3
Yep, much better.
Initial bite is pretty much instant, no more sponge at the top of the pedal.
It just feels better overall.
Stubok417.50
