BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Launching F30 335xi?
      11-01-2012, 01:14 PM   #1
Dan_335i
Drives: 2014 335i EBII MSport
All I do is put it in sport+ left foot on brake and right foot on gas to which RPM? then foot off brake then floor the gas?
      11-01-2012, 01:49 PM   #2
TheBingoBalls
You also have to turn of DSC/DTC and rev past 2000RPM.
      11-01-2012, 02:18 PM   #3
Dan_335i
You mean turn off traction control right? im pretty sure sport+ turns it off, so 2000-3000 rpm is good? and is it dangerous to do when the light is red and about to turn green then you launch? the car wont slide side ways right?
      11-01-2012, 02:24 PM   #4
NISFAN
NISFAN's Avatar
Drives: The best kind of F30 :)
The engine is not powerful enough (auto's don't have the equivalent of dumping the clutch) to worry 4WD traction. So no you won't be going sideways unless you do that on sheet ice.
Launch? I would guess, left foot on brake, floor throttle and release brake a fraction of a second later.
      11-01-2012, 02:48 PM   #5
SPACEMANRICK
Drives: 2016 M3 6 speed manual
Motortrend or Road and Track in their video for 0 to 60 test for the 335i revved the engine to 2000 RPM for maximum acceleration (I think they did 4.7 seconds for the 335i). With all wheel drive you should be able to do the same to probably 3500 to 4000 RPM for maximum acceleration.
No worries of going sideways, with all 4 wheels getting power you should just hook up and go..........
      11-01-2012, 03:14 PM   #6
dude987
Drives: BMW 335i xDrive M-Sport DHP
4.7 for a 335i is rather amazing. You might be able to squeeze out a 4.5 with the 335i xDrive. Certainly curious to know.
      11-01-2012, 04:06 PM   #7
Dan_335i
Ok would it slide side ways with traction control turned off on the 335 RWD? Thats if i did something wrong like RPM to red line then let go of brake
      11-01-2012, 04:22 PM   #8
ThatEgyptianKid
Drives: E92 335
Whatever technique you end up using be sure to to post up your times
      11-01-2012, 04:48 PM   #9
Naambezet
Netherlands
Drives: BMW X1 sDrive 20i
That isn't called a launch, but just some tire shredding and clutch abuse
      11-01-2012, 05:18 PM   #10
SPACEMANRICK
I don't think it would go sideways, I had a 2006 rear wheel drive BMW 330i with 6 speed manual and if you dropped the clutch at too high a RPM all you would initially get is the rear wheels spinning before they got traction.
      11-01-2012, 05:25 PM   #11
NISFAN
NISFAN's Avatar
When you say let go of brake, I automatically think you are talking about an auto box car?
In that case even a RWD you won't get into too much trouble launching as hard as the torque converter will allow. It won't let you get to the red line whilst your foot is on the brake.
