BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Winter Set-up Questions..first time
VIBE Motorsports
      11-05-2012, 08:04 AM   #1
Zirenz2006
Zirenz2006's Avatar
Drives: X3 M40i Phytonic
This is my first time buying a set of winter tires.
I have a couple of questions.
1) Am I crazy to just use the 18" factory wheels and buy 18" winter tires or should I just buy a set of rims for the winter tires?
2) If I bought a set of rims would you recommend a smaller size like 16 or 17"?
I just don't want to spend a ton of $$ for a winter set-up.
I saw that tire rack had some 17" wheels that would fit my car for about $108per wheels. Should I be leary of such cheap wheels?
Thanks
Current: G01 M40i Phytonic Blue|Black with Blue Stitching
Retired: '12 F30 328i Sport Line Sapphire Black|Black-red, '09 E90 335i M-Sport AW|Oyster, '07 E92 335i Graphite|Saddle, '05 E60 545i TiAg|Black, '01 E46 325i Jet Black|Black
      11-05-2012, 09:02 AM   #2
Robin_NL
S0THPAW
Robin_NL's Avatar
Netherlands
1939
Drives: LBB M2+MPE
17 inch is the minimal size for the F30 335i(rotor diameter)
You can change the tyres offcourse, but I bought a complete winterset(rims + tyres). It's easier and faster to change. But I guess if(1) you buy only the tyres you're first cheaper off but in the long run(labour) I guess not...(2)
I have 19"401 summer wheels and I bought a 18"397 set Continental Wintercontact. They don't come cheap(complete € 2300 but I got a very big discount) If you are going to buy 17 or other inch you're cheaper off offcourse...
Not OEM is cheaper...but the one tyrebrand is better than the other. Continental and Pirelli are winterkings atm in EU afaik.
Cheers
Robin
      11-05-2012, 01:24 PM   #3
Rick955
Rick955's Avatar
Drives: 2018 M3 ZCP
Thanks
Depends... I posted a photo of the setup I will use in this thread... details are all there. http://www.f30post.com/forums/showthread.php?t=760485
You live in RI? The Tirerack warehouse is in Windsor, CT. So you can save yourself $100 shipping (for tires AND wheels), by taking a ride (in something other than your 3-series ), and just picking them up. That setup was $1700 out the door (picked up myself), and after a $50 Pirelli rebate. (wheels were about $144 ea). But they look good, and the tires will give excellent performance not only on wet or snowy roads, but in dry conditions too which is important because as you know, here in New England the roads are pretty clear again a day or two after the storm. That number includes the TPM which, if you don't care about the light being on all the time, will save you another $200. But they are ready to go, so no labor cost to have someone mount and balance tires 2x per year.
      11-05-2012, 03:49 PM   #4
martinf79
martinf79's Avatar
78
Drives: F30 335i M Sport
Full specs on my setup below (wanted to maintain a stock look .. even during the winter)....
http://www.f30post.com/forums/showthread.php?t=765582
2013 335i ///M-Sport | + 2015 X3 28i xLine
