BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Sport Performance Suspension - Labor hours
      01-18-2013, 03:50 AM   #221
nano10
nano10's Avatar
98
Drives: 2013 335i aka Kal-El
Originally Posted by Rossifumi View Post
Looks a lot better!
Lol, but with performance suspension you get the drop you had on a stock E9x car... I wonder how high the next generation will be?
This is so true. I wonder what body roll on e90 sport suspension is like compared to m performance f30. Still great stance, reduced body roll and if you keep ride quality. Worth it
2013 335i Estoril Blue M Sport/ Coral Red Interior/ M Performance Red Brakes/ Enhanced Bluetooth/ Premium Audio/Performance Grills/BBS CX-R
      01-18-2013, 03:53 AM   #222
nano10
nano10's Avatar
98
Originally Posted by rob_h10 View Post
hey guys, here are pics of my M Performance suspension install.. i deliberately turned the 2nd pic on its side to show how much of a drop is achieved
What size is that front tire
      01-18-2013, 11:28 AM   #223
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
brandon, lol, those are the 397 18's with snow tires on them...they look like $hit with the huge sidewalls, I know, but 17's, come on man!
and yes retaining ride quality is a PLUS with this system...
SOLD: 2012 335i Mineral Gray
      01-19-2013, 07:36 PM   #224
brandon @ eas
brandon @ eas's Avatar
Drives: F30 335i
Send a message via AIM to brandon @ eas
haha well I was sure they were 18"s but I was thrown off by your comment about how the 18" M-Sport wheels will be filling up the wheel wells nicely
      01-19-2013, 09:55 PM   #225
shivaswrath
Drives: 2012 335i
Oh yes, the M sports are going on when the snow up here stops!
Ill post pics in a few months...of them.
      01-19-2013, 10:14 PM   #226
RPM90
Drives: 340i M-sport AT
Did you go from base non sport susp to M Perf?
If so ride height should drop by 20mm or about .8"
Sport susp/M sport is a 10mm drop from stock. M Perf is a 10mm drop from sport/Msport.
Your overall measurement from floor to wheel arch lip looks to be about .8".
But something is strange with your measurement.
In the first photo, from the ground to the top of the tire is about 25". On the next photo, sideways, from the ground to the top of the tire is around 25.5".
But, that measurement shouldn't change even with a spring change as you're still only measuring from the ground to the top of the tire.
The only way that measurement can change is if you have a different overall diameter whee/tire setup or you changed the inflation pressure. Maybe the point on the floor wasn't flat between the two measurements?
After a change to a lower spring the only change should be the body's ride height. So you measure from the same ground point to the same point on the body like the edge of the wheel arch.
Ride height looks to be around .8" lower, which is what is should be going from the base susp spring to the M Perf spring.
10mm is only about .4"
Tire gap to wheel arch lip seems to have shrunk by .25" that's nice.
Yet still there is something strange with your measurement judging from the difference between the two shots from the floor to the top of the tire. That measurement should be the same.
Did you notice this too while measuring? If so do you know what happened? Just curious.
      01-19-2013, 11:38 PM   #227
rob_h10
Drives: F30 335i
I started out with the sportline suspension and retrofitted the M performance suspension. The car came with 18" wheels and the 'just ok' goodyear all-season tires..
i think i know what you mean about the measurements being a little odd... very possible the metal tape measure was not completely straight in the second pic i posted. i will try to get a side-by-side pic of my car next to a stock sportline at my dealership when i go visit in the next week or so.
btw. i want to give props to Malek of MRF Engineering for an excellent job on my wheel alignment. He is a very skilled professional. He Will.Fix.Your.Car. Thanks. i only wish his shop was closer to my location.. anyway, he is worth the drive.
      01-21-2013, 12:33 PM   #228
pkimM3r
pkimM3r's Avatar
136
glad a couple of you got it finally done with the correct springs! now its probably a pain in the ass ordering the correct parts lol
      01-24-2013, 03:10 PM   #229
MadZarBMR
MadZarBMR's Avatar
Drives: Current: '16 M3 SSII - 6MT
M-Sport Suspension to M Performance
Been following this thread since I got into my 335i M-Sport 6MT in mid December '12.
I've been patiently waiting to hear good news from those of you that took the early leap. Thank you BTW - I am definitely learning from your experiences.
Looks like I might be the first to go from M-Sport suspension to M Performance. Personally, I think the ride height of the M-Sport is just about right with the 19" 403s and am mainly interested in improved handling.
Will post complete before and after pix for those of you that are interested.
      01-24-2013, 04:54 PM   #230
jamesems
Drives: 2013 335i msport f30
Originally Posted by MadZarBMR View Post
Looks like I might be the first to go from M-Sport suspension to M Performance. Personally, I think the ride height of the M-Sport is just about right with the 19" 403s and am mainly interested in improved l
That's what's I'm doing. Performance suspension goes on Saturday. Hope there's a marked improvement. Wonder if anyone will buy my msport take-offs
      01-24-2013, 07:19 PM   #231
MadZarBMR
MadZarBMR's Avatar
Congrats james!
Did what someone on this thread suggested and searched for ETK. Found the following link which allows you to log in to the BMW aftersales assistance portal (ASAP).
http://www.bmw.com/com/en/owners/acc...catalogue.html
I entered my VIN info and searched through the springs table under "specific parts search" and came up with the correct part numbers for the M performance springs needed for my car. From how the configurator works, there are different part numbers depending on several factors, not just transmission type. I suspect it has to do with overall vehicle weight and the spring rates necessary.
For my 6MT F30 with all but the Driver Assistance Plus, Dynamic Handling and Adaptive M Suspension, the correct part numbers are:
M Performance Suspension Kit: 33502320981
Front Springs: 31336860630
Rear Springs: 33536860621
Seems like dealers should have this info by now and a lot of the confusion came from online stores posting inaccurate info. Hopefully this won't be an issue going forward.
James - would like to get your impressions once yours is done and would also like to know how much you paid in labor. I'm still talking my dealer down - they want $180/hr and are estimating 7 for the install. Absurd if you ask me.
      01-25-2013, 04:20 AM   #232
jamesems
Ill let you know ASAP. Should be really cool
      01-25-2013, 02:26 PM   #233
nano10
nano10's Avatar
98
Can wait to see how how m performance suspension looks on m sport
      01-26-2013, 09:38 AM   #234
Dinh335
Drives: 2004 RX8/2015 M3/2017 X5 35i
Sweet-keep us posted on how install goes ...msport 335 here too 6mt thinking about doing this...
2015 Tanzanite Blue M3 /19 silver/exec/SS full leather/hk/cams/6speed_Wife 2017 x5 xdrive 35i
      01-26-2013, 05:43 PM   #235
jamesems
I hope to have it home this evening
      01-26-2013, 05:47 PM   #236
MadZarBMR
MadZarBMR's Avatar
Can't wait to get feedback and see some pics. I'm working on uploading some BEFORE shots of my Mineral Grey now... Will post link here when their up.
      01-26-2013, 07:18 PM   #237
artieg30
Drives: 2013 335xi M-Sport
Does anyone know if the m performance kit can be installed on a 335 x drive m sport model with adaptive suspension? There was a thread on this site that stated the m adaptive suspension cars would not be compatible. ..
      01-26-2013, 09:38 PM   #238
shivaswrath
Drives: 2012 335i
No xDrive bro.
      01-26-2013, 11:22 PM   #239
MadZarBMR
MadZarBMR's Avatar
While we wait for james to post on his new M Performance suspension, I have uploaded pix of my M-Sport BEFORE mods.
http://www.f30post.com/forums/showthread.php?t=796633
James - hope things are going well with your install.
      01-27-2013, 12:34 AM   #240
jamesems
Photos and review
Installed and home.
The photos include the brakes kit install with challenge braided steel brakes lines. They show the performance suspension as well. The last photos are of the cars stance on the suspension. Sorry i forgot to get before photos but the suspension is definitely lower than just the msport.
Guys, this is the way the handling should feel. It's tight with no very little body roll. Maybe a little more firmness than previously with the stock msport but I'm very pleased. It's perfect.
The brakes unfortunately are soft. The tech bled them 3x with no changes. I pointed out that there's coding. They hadnt done it. I will take it back Tuesday for the coding and hope the brakes firm up. Enjoy photos.
Next upgrade is my wheels due in about a month.
      01-27-2013, 01:15 AM   #241
dcg71
Australia
40
Drives: F15 X5 25d / Ducati Monster
Great pics! Some nice upgrades and the entire car looks stunning. Glad to hear the suspension lives up to expectations. My kit should arrive next week, can't wait to get it on the car!
Somewhat shocking they didn't know about the brake coding. Presumably it was at a dealership.
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      01-27-2013, 02:39 AM   #242
jamesems
Thanks for the compliment. The tech knew about the coding but ran out of time. Between the suspension and brakes it was a full day. We'll do the coding on Tuesday. I have a few other things I want coded as well. Ill get more photos up soon. Just wanted to add thanks to Sean and Ian for the awesome help on this project. BMW of Encinitas thanks.
