BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M Sport Performance Suspension - Labor hours
European Auto Source
      02-26-2013, 01:21 PM   #309
classj
Drives: 328xi E90
Wonder how this all plays with the dynamic handling pkg?
      02-26-2013, 02:08 PM   #310
bananachipz
Drives: F30 Mineral Gray 335i
if you mean EDC.... it doesn't....
      02-26-2013, 02:09 PM   #311
bananachipz
Originally Posted by Balzz View Post
I'm good after 2pm today!
I've got a meeting until 3.... free after though
      02-26-2013, 02:28 PM   #312
Balzz
Drives: 2015 Tanzanite Blue F82
2015 BMW M4  [0.00]
Use Webex. :P
      02-26-2013, 03:16 PM   #313
bananachipz
Use Webex. :P
      02-26-2013, 05:53 PM   #314
Balzz
2015 BMW M4  [0.00]
Just rode in it...tough to compare against the sport suspension since I'm on 17"s and chipz is on 18"s for the winter too. It didn't seem too harsh a ride though.
      02-28-2013, 07:30 PM   #315
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
GUYS: you'll have to raise your Xenons (if you have them) once it lowered btw, I had to adjust by 720 degress on the adjustment knob. Raised it by 2.3 inches on both sides....
It was getting annoying and reducing the "pitch" of my adaptive headlight...
SOLD: 2012 335i Mineral Gray
      03-01-2013, 12:05 AM   #316
bmrm396
Drives: 2016 F80 M3
interesting? is it really that bad cause ive never had to do that with my e90?
Formerly addicted to e46fanatics
Formerly addicted to e90post
      03-01-2013, 10:36 AM   #317
shivaswrath
Drives: 2012 335i
it's not bad, I wanted to do it initially when I took delivery of the car last fall, just never got around to it. But lately, driving home late at night, I noticed the pitch wasn't as far as it used to be, and then realized it probably was exacerbated with the lowering.
Technically, the adaptive lighting system should automatically compensate, but I figured might as well put it out there for everyone.
I did a before and after in my garage with a pencil with the cutoff, so if it's too much (I'll check it out tonight), i can dial it back.
      03-01-2013, 11:05 AM   #318
bananachipz
Do I smelly a DIY with pictures?
      03-01-2013, 11:32 AM   #319
shivaswrath
Drives: 2012 335i
LOL, more than happy to...
1. Buy screw driver with long shaft.
2. Insert said shaft into hole in BMW.
3. Rotate 360 degrees.
4.
I'll post later this weekend folks..
      03-01-2013, 05:22 PM   #320
bmrm396
Drives: 2016 F80 M3
better specify WHICH whole ... im accused of trying to insert said shaft into the wrong hole all the time, i guess i need specific instructions
      03-02-2013, 08:48 AM   #321
shivaswrath
Drives: 2012 335i
      03-10-2013, 12:29 AM   #322
brandon @ eas
brandon @ eas's Avatar
Drives: F30 335i
Send a message via AIM to brandon @ eas
just lowered on M-Perf.
      03-10-2013, 12:33 AM   #323
MadZarBMR
MadZarBMR's Avatar
Drives: Current: '16 M3 SSII - 6MT
Looking good - how do you like the ride? What wheels are those? Size?
      03-10-2013, 12:35 AM   #324
brandon @ eas
Drives: F30 335i
a few more:
      03-10-2013, 12:36 AM   #325
brandon @ eas
Drives: F30 335i
The ride is softer than I was hoping for but definitely nice. Wheels are 19X8.5 et35 front, 19X9.5 et35 rear ZCP wheels. Tires are 225/40/19 front, 255/35/19 rear. No rubbing!
      03-10-2013, 02:19 AM   #326
bmrm396
Drives: 2016 F80 M3
lov it! well done man, i cant wait for mine
      03-10-2013, 04:16 AM   #327
brandon @ eas
Drives: F30 335i
Thanks! Post pics up of yours when you can!
      03-10-2013, 01:58 PM   #328
shivaswrath
Drives: 2012 335i
Nicely done!
Love the stance, very aggressive and tasteful with the rims.
      03-10-2013, 03:03 PM   #329
brandon @ eas
Drives: F30 335i
Nicely done!
Thanks!!!!
Here is another comparison photo: white car has M-Performance Suspension, silver car has M-Sport supsension
      03-10-2013, 06:38 PM   #330
RPM90
Drives: 340i M-sport AT
Thanks!!!!
The front drop is much more noticeable, which is nice and looks good too.
Can you distinctly notice/feel quicker transition in handling?
How does the damping feel in a hard corner that has bumps and ripples?
In my 335i Msport with adaptive the car takes a nice set, but if the bumps and ripples are heavy sometimes the rear pogo's a bit and other times it feels like the rear tires skirt a tad towards the outside.
My 135i would also do this a bit but not as much. It had the stock sport suspension non adaptive.
I'm still considering installing the M Perf springs and keeping the adjustable dampers. I think it'll work.
What are the prices for the M Perf springs for a 335i?
How much would a performance/suspension shop charge to install new springs?
Those of you that have done the M Perf install did they use the same alignment settings as stock, or does the M Perf give new settings to use?
