BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2013 335i Rattle sound during light acceleration and lumpy idle
Extreme Power House
      11-08-2012, 07:18 PM   #1
OnceAudi
Drives: 2013 335i
Only had my new 335 for a week and already having issues. The other day at a stoplight, my idle starting going up and down erratically. On top of that, under light acceleration, there is this rattle/ticking coming from the dash area. I can't pinpoint exactly where it's coming from but it is definitely throttle related. Under light throttle, it sounds like someone is fanning a deck of cards if that makes sense. I wasn't expecting this from a brand new car.
      11-08-2012, 07:53 PM   #2
Maz335i
BMW 4 Life...
Maz335i's Avatar
Drives: 2015 SO M3 (on order)
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
      11-08-2012, 08:42 PM   #3
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
sounds like a vacuum hose lightly popped off under the hood, which would explain a rattle (if it's loose), and erratic idle...did you floor it hardcore over bumpy roads?
SOLD: 2012 335i Mineral Gray
      11-08-2012, 08:49 PM   #4
OnceAudi
Drives: 2013 335i
To be honest i've been driving it rather easily so i'm not sure what could have happened. I'll check under the hood to see if i see anything odd. I knew i should have kept my 06' 330i.
      11-08-2012, 08:55 PM   #5
shivaswrath
Drives: 2012 335i
dude the F30 is MUCH better..nothing to freak out about, it'll be easy...just take it to the dealership, no?
      11-08-2012, 09:52 PM   #6
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [5.00]
2013 X5  [0.00]
2013 335i F30  [4.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Are u going to change your sn to OnceBMW? Jk
Go to the dealer. It's it still doing it or is it a one off type of event?
Same thing happened to me on my 335 and I took it it. Stored faults, they reprogrammed my dme and problem gone. No biggie. Go to the dealer that's what they're there for
      11-09-2012, 07:46 AM   #7
OnceAudi
Drives: 2013 335i
I called my salesman last night to set up a service appt once my plates come in. I'm hoping it will be an easy fix.
      11-09-2012, 01:19 PM   #8
DarkTrigger
Professional
DarkTrigger's Avatar
Drives: 335i MPPK
I have a rattle too. Same place. Doesn't bother me much though.
I'm going to bring it in when I have 3+ issues for them to look at all at once. Already have 2 (reprogram Auto Start/Stop & Rattle behind dash), waiting for one or two more.
      11-09-2012, 04:27 PM   #9
OnceAudi
Drives: 2013 335i
Is the rattle behind the dash dependent on throttle position?
      11-09-2012, 06:31 PM   #10
RPM90
Drives: 340i M-sport AT
Erratic idle means setup a service appointment.
Something like that is one of those things that just happens.
My 335i Msport had no heat when I wanted to use it for the first time.
Only one other person on here had a similar problem. His turned out to be a bad water valve. Mine turned out to be corrupted software that resulted by the tech turning ASS to "last position used".
It took BMW 2 days to figure it out.
They will fix your car, just give them a chance. Yes, it sucks to have a problem with a new car, but it does happen. Remain calm and get a loaner while they work on your car.
      11-10-2012, 11:30 AM   #11
OnceAudi
Drives: 2013 335i
So I located the source of the rattle. It is the shift knob. Though it sounds like its comming from the dash, it's def the shift knob. The vibrations from letting the car rev cause the knob to rattle and buzz. If I pull up on the shifter the noise goes away. The new shift knobs that BMW has appear to be sewn to the boot so it looks like they don't just pull off anymore. There hAs to be something loose in there.
      09-02-2013, 06:51 AM   #12
Cooldude007
Drives: F30 2013 335i MSPORT Glasier S
Hi guys,
I recently received my replacement 335i M Sport and it has exactly the same vibration/ rattle which sounds like its comming from behind the dash!! It happens between 2000rpm and 3000 rpm at low speeds when the engine is warm. Unbelievable!
      10-09-2013, 07:46 PM   #13
yemenmocha
yemenmocha's Avatar
25
Drives: 14 335i Msport-PPK, 06 M3
Originally Posted by Cooldude007 View Post
Hi guys,
Mine may have it too. Planning to do a video soon.
      01-17-2014, 07:44 AM   #14
jessicarobin
Drives: scooty pep
Check the heat shields on the exhaust system to see if any are loose…
      01-17-2014, 10:08 AM   #15
m7ammed
1junkie
m7ammed's Avatar
Saudi Arabia
56
Drives: 335i
Hi guys,
I have the exact thing can't figure what it is had the car for a week now brand new, October production car. It goes away sometime and comes back very random. From 2k to 3k rpm.
      01-17-2014, 03:05 PM   #16
gomichaelkgo
Drives: 2014 335i
This is exactly the condition under which anything loose in the engine bay will rattle. There seems to be resonance at 2500 rpm. I've seen fixes here involving reseating the radiator, adjusting the heat shielding, replacing the AC Compressor, tightening a bracket in the dash board, and securing windshield cowling.
Good luck in tracking down the source of yours!
      01-18-2014, 02:00 AM   #17
m7ammed
1junkie
m7ammed's Avatar
Saudi Arabia
56
Drives: 335i
The AC is always off these days and turning it on and off doesn't make a difference so that is out atleast lol. Will have to see the other stuff.
