BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > E61 headlight condensation
      11-09-2012, 03:33 AM   #1
tanzilees
Drives: E61 LCI 520d
Hi all I have recently purchased a 08 e61 520d the only fault I can find on her is the passenger side headlight has condensation on the inside! Has anyone seen this before/ have a way to fix it without replacing the whole unit?
      11-09-2012, 04:00 PM   #2
fravel
fravel's Avatar
Drives: Monaco Blue '06 330i
Does the headlight work otherwise? If yes, pop all the covers off of it and use a hairdryer on the lowest setting to blow some air in there. Be careful not to melt anything. It will take a bit of time, but be patient. Once all the condensation is gone, check the seals on all the caps to make sure they are intact, then re-install the caps and you should be good to go.
      11-14-2012, 03:00 PM   #3
tanzilees
Thanks will give this a go!
