BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Low tire Question
European Auto Source
      11-12-2012, 12:40 PM   #1
sr5959
Drives: 428GC M-Sport
Low tire Question
Hi guys, had a low tire warning yesterday, and when I checked the tire it was half normal pressure so I think I'll have to repair or replace. I have about 10k miles on the car so do I have to replace both rear tires? I have 17" Conti all-seasons. Thanks!
      11-12-2012, 01:42 PM   #2
zeezz
Drives: F30 328i Sport Line
Do you check regularly? If not, it might have just gotten low enough to trigger a warning, if you fill it up and it deflates more then you have a problem. To my understanding tires will lose a normal amount of air over time though.
      11-12-2012, 01:46 PM   #3
chrisny
Drives: '15 550xi M Sport
Warning comes on way before half and any normal loss should more or less apply to all tires and not be so drastic. Sudden temperature changes can have a big impact, but again, not just to one tire.. Not sure I would worry about replacing both tires to keep wear the same, but I guess that depends on how low the tread is on the one that is still good.
      11-12-2012, 02:33 PM   #4
sr5959
Thanks guys, I filled it up and was able to drive to work with no further warnings, I think it's a slow leak although I can't see the cause. I will try to get it repaired.
      11-14-2012, 11:56 PM   #5
JUSKIDN
JUSKIDN's Avatar
Drives: 2013 EBII 328i M Sport
extreme weather temp changes can also make the pressure go up and down
It's not illegal. It's frowned upon, like masturbating on an airplane.
      11-15-2012, 12:07 AM   #6
claykin
Drives: 2016 535i M-Sport
Most likely a puncture. Repair it. Just make sure the tire shop has a leverless tire changer. Or, you may end up with rim scrapes.
