BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Could someone please identify this?
Extreme Power House
      11-13-2012, 09:50 PM   #1
glitched79
Drives: 2012 328i
Question Could someone please identify this?
Does anyone know what this thing is in the engine? I've spent the past hour trying to figure it out... Blow off valve? Exhaust valve? It's driving me crazy!!!
Much appreciated!
      11-13-2012, 10:21 PM   #2
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
My guess is bypass valve- modern turbos have bypass valves which are like a blow off valve that recirculates.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      11-14-2012, 04:42 AM   #3
MidgetInBikini
SFBA Photographer
Drives: 2013 E84 N20 28i
what is blow off valve?
      11-14-2012, 10:20 AM   #4
mocohead
mocohead's Avatar
26
Drives: '16 M235i 6MT & 12 128i Msport
I believe that is the vacuum operated wastegate. When vacuum is applied, it opens the flap on the turbo to release boost.
      11-14-2012, 10:29 AM   #5
Turbo00
Drives: 2013 328i M-Sport
You've got it.
My car has an N26, so this is electro-mechanical rather than vaccuum operated, but on the standard N20, BMW uses a pretty run of the mill twin scroll turbo w/vacuum-operated internal wastegate; only difference is the operation between N20/26.
      11-14-2012, 11:38 AM   #6
eric@helix
eric@helix's Avatar
Drives: 01 M Coupe, 08 135i, '12 328i
This.
      11-14-2012, 07:47 PM   #7
Kaitain
Drives: Estoril Blue II F30 M Sport
It is called an actuator. A wastegate is different, but they do similiar jobs. The actuator pushes the flap open when the turbine gets to the set boost to allow for some of the exhaust gases to bypass the rear turbine wheel, so it doesn't keep spinning to infiniti and blow the engine / the turbo up.
