BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > DAB to be standard on all BMW's from January
VIBE Motorsports
      11-23-2012, 01:23 PM   #23
NISFAN
NISFAN's Avatar
Drives: The best kind of F30 :)
With Chris Moyles going and Scott Mills on afternoons Radio 1 which I have been listening to for ever has to go. I ordered DAB for mine for that very reason, because there are way too few nationwide radio stations in the UK.
      12-11-2012, 09:45 AM   #24
Rajput
Drives: BMW F30 320d 2012
Interference when listening to radio 4 FM
This is my first posting, and i don't think i can start a new thread just yet.
Collected my new F30 in October this year, and only have the standard radio. Since then, Iíve tried out playing mp3s via a usb stick directly plugged into the usb socket, and subsequently bought a Y cable off fleabay to use with an iPod.
My first reaction to the usb stick was Ďgood soundí, and better than the Y cable set up with an iPod, but Iíve stuck with the iPod in order to update my playlists. Iíve selected Ďbass boosterí as the iPod EQ setting and also turned the bass down about 3 bars in the car setting. I feel that Iíve now got an acceptable sound, and I can hear bass which I couldnít before in my E46. I hasten to add that Iím not expecting hi f in the car with the set up i have!
Anyway, my issue is when I listen to radio 4, as this is mostly speech. I can hear, what sounds like static and also electrical interference, like you used to be able to hear when turning the tuning dial on old radios. Itís bad enough to give me a headache within 15 minutes or so, and bad enough to make listening to this station on FM unlistenable. I told the dealer that maybe the aerial wasnít properly connected or that there was some loose connection.
I tuned into radio 4 using the RDS set up, and then also manually with RDS off, and itís as though the frequency is just off the optimum one, and hence the interference. The radio also seems to be prone to picking up Ďsnaps, crackles, and popsí, none of which I had in my old E46 radio, and which I thought disappeared in the 70s/80s. I get intermittent static too like before a thunderstorm.
The dealer checked and couldnít find the problem with the radio (not surprising really considering they tuned the radio to some non-stop music channel), but also that they couldnít find a fault with the wires in the rear windscreen either.
On collecting my car I tuned into radio 4 (94.3 MHz) and demonstrated the problem first hand, and the dealer agreed that there is a problem present. The dealer had me book the car in again for a whole day for them to try and fix the problem. They didnít manage it, and now want the car back for a whole week to do various tests like make up an new aerial cable, etc. The dealer has raised a PUMA.
Thing is, Iíve noticed the SAME problem in the courtesy mini bus they dropped me at home in, and also in the car that they came to collect me to take me back to the dealership, on the same radio station. I therefore think that the problem is not specific to my car, and that it is a common fault with the standard radio.
Itís good that BMW are now going to offer DAB as standard fit on 2013 beemers, but even if I got this as an replacement/upgrade, it still wouldnít solve the current issue of poor radio reception quality for those times when the DAB signal doesnít work.
Anyone confirm that they also have the same problem? Or if they managed to fix this?
      12-11-2012, 12:32 PM   #25
RobUK
RobUK's Avatar
Drives: 340i EBII
I also have the standard (non-DAB) radio but haven't experienced any interference on Radio 4, or any of the other stations.
Unfortunately, they won't be able to replace/upgrade your non-DAB radio to the factory fit DAB radio the only option seems to be the retro-fit DAB which is a little different (and as it's effectively a bolt-on solution, it may not help).
340i in Estoril Blue
      12-12-2012, 04:38 AM   #26
Redbaron1973
Drives: G12
I have moved my build from week51 to week 2.. So I will get dab. Wonder how many cars will get built early as I suspect many will do/ try the same?
      12-12-2012, 05:19 AM   #27
rich1068
has left the building
Drives: F30 330d M Sport
This F31 loaner has DAB. I'll have to see if it's any better than the units fitted to the myriad of Minis I've been driving recently. In Sheffield I only seem to be able to get BBC Asian Network and Absolute 80s
      12-12-2012, 05:31 AM   #28
MarkW83
I thought there was a price rise from Jan 1st which worked out at more than the cost of adding the DAB as an option? If so, you'd be better amending your spec now to add the DAB, and you'll also get to keep your current build week as well (if your car isn't 'Confirmed by Production Control' yet, which I assume it isn't or you wouldn't have been able to move your build week either)... Just a thought
F30 330d M Sport Mineral Grey / Coral Red
Pro Nav/Visibility Pack/Comfort Pack/Harman Kardon/Head-Up Display/Electric Seats/Comfort Access/Adaptive Suspension...
      12-14-2012, 06:07 AM   #29
Redbaron1973
Drives: G12
Im not paying for it... so couldnt care less
      12-14-2012, 06:14 AM   #30
MarkW83
I doubt they would add the features for you that have come into effect along with an associated price rise; without at least trying to charge you for it, unless there was a genuine delay on BMW's end (i.e. not just you requesting your build date to be put back). I would check you won't be paying the higher price when you get the car - standard practice for price rises, finance offer changes etc., that are in place when the car is actually delivered rather than ordered - if you haven't already.
Or if they've already confirmed you're getting the new feature(s) and definitely not paying a penny more: result
      12-14-2012, 06:42 AM   #31
Redbaron1973
Drives: G12
I am not paying for it. Arval are. It is their problem not mine. I have no interest in the retail price of the vehicle.
      12-14-2012, 06:43 AM   #32
MarkW83
Right lol, lucky you then I thought "I am not paying for it" meant "I will *not* be paying for it if they try to charge me", rather than you actually aren't paying for your car, lol
      12-14-2012, 07:02 AM   #33
Redbaron1973
Drives: G12
Nope. I wouldnt be buying a 320d if it was my money. I wouldnt be buying an F30 tbh.
Would be in 6er if it were my money.
      12-19-2012, 02:48 PM   #34
Rajput
Does the standard radio do anything more than just play music? I mean, does it control anything else not related to playing music? Trying to figure out why it can't be just swapped for either the 'factory fitted model' (assuming BMW even made it available) or some other make/model.
      01-02-2013, 05:45 AM   #35
rich1068
Just found out mine is coming with DAB as standard. Result! It was a £££ option when I ordered!
      01-02-2013, 07:20 AM   #36
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
Drives: 2018 540i M/Sport MPerformance
Can't get mine to make phone calls
Live for now, life is too short.
2017 M3 CP in YMB.
