BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Odd problem today - low power
VIBE Motorsports
      11-16-2012, 05:07 PM   #1
gmazzu
Drives: 335 M-Sport X-Drive 6 speed
I had an odd problem today on my 2013 335 xdrive. I pulled onto an onramp and hit the gas and had almost no power and acceleration into second gear. I shifted to third and same thing. I pushed the pedal to the floor and almost no acceleration. I got off the highway and at the next light shut of the car and turned and back on and all way well. Anyone seen this?
      11-16-2012, 06:15 PM   #2
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Sounds like limp mode.
Did you run cheap Gas by accident?
Did a hose clamp around your intake come loose?
SOLD: 2012 335i Mineral Gray
      11-16-2012, 06:19 PM   #3
gmazzu
I've been using 93 at name brand pumps
It sure felt like limp mode but it didn't throw any codes and they car said it was ok in the information in the NAV
I will check for loose clamps.
      11-19-2012, 01:44 AM   #4
ybbiz34
Moderator
323
Drives: 2013 C63 AMG Sedan
Did you trigger the traction control by chance?
Not too long ago I lost traction and the TC intervened, cutting the power. There must've been some sort of glitch because the power cut remained until I turned the car off and then re-started it.
I didn't experience any error codes or warning lights.
'13 Iridium Silver C63 AMG Sedan (540 hp; 500 lb-ft)
Review of F82 M4: http://f80.bimmerpost.com/forums/sho....php?t=1008143
[SIGPIC][/SIGPIC]
