BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Best offset for F30 front 19x8.5 & rear 19x9.5
VIBE Motorsports
      11-28-2012, 11:06 AM   #1
kc-e93
Drives: E93 335i
Dear all,
My buddy has a F30 335i and he wants to know what's the best offset for the above said wheel size. He wants the wheel to line up perfectly with the fenders without rubbing.
He is gonna lower his car with KW V2 as well. Maybe 2.5' to 3' drop.
It will be great if you can post some pictures of yours. Thanks!!
      11-28-2012, 01:21 PM   #2
nano10
nano10's Avatar
148
Drives: 2018 F80 M3
I have seen alot do ET 35 front and ET 38 in rear. Challenge has et 40 in rear and looks very good. I am about to try et 32 front and et 32 rear. Wish me luck!
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
      11-28-2012, 01:27 PM   #3
kc-e93
Drives: E93 335i
Thanks Nano10!!
What kind of wheels are you getting?
Please post pictures once you have the wheels installed!!
Good luck!!
      11-28-2012, 01:34 PM   #4
nano10
nano10's Avatar
148
Drives: 2018 F80 M3
Originally Posted by kc-e93 View Post
Thanks Nano10!!
Good luck!!
Wheels are BBS, they will go on car as soon i get time off work. I still need to take delivery of my car first. Pics for sure. Make sure your friend gets a quality wheel. Check out Alufelgen they are et 35 front and back and are offering sponsorships.
      11-28-2012, 01:37 PM   #5
nick2013328i
nick2013328i's Avatar
Drives: 2013 328i
Dear all,
i have f10 reps in black and they are +35 in front +38 in rear it is Perfect stance. flush even with the car body. tires are front: 235/35/19 rear: 265/30/19.. im pretty sure. they are 8.5 width front, 9.5 width back.
      11-28-2012, 02:05 PM   #6
martinf79
martinf79's Avatar
78
Drives: F30 335i M Sport
You really should have gone w/ 235/40R/19 Front and 265/35R/19 Rear (which is a lot closer to stock diameter).
235/40R/19 = 1.22%+ Diameter vs. Stock
265/35R/19 = 1.07%+ Diameter vs. Stock
Your setup:
235/35/19 = 2.34%+ Diameter vs. Stock
265/30/19 = 2.96%- Diameter vs. Stock
2013 335i ///M-Sport | + 2015 X3 28i xLine
      11-28-2012, 02:13 PM   #7
rxander
rxander's Avatar
Drives: F30 Alpine White
Your setup:
I'm going this route when I get rims. it also has more of a bulldog stance to it vs the thinner looking tires.
      11-28-2012, 02:49 PM   #8
nick2013328i
Drives: 2013 328i
Your setup:
What's your point? My car looks sick
      11-28-2012, 03:41 PM   #9
gtabfknkdnme
5 Star General
gtabfknkdnme's Avatar
Drives: E82, F30
No it doesn't
And his point is your speedometer and mileage are going to be further off. Plus, those tires look way to small unless the car is lowered
      11-28-2012, 03:54 PM   #10
nick2013328i
Drives: 2013 328i
Originally Posted by gtabfknkdnme View Post
No it doesn't
lmao
make sure to help the OP get his right fitment there clide
      11-28-2012, 05:34 PM   #11
s1k0ne
Drives: ..
All about the drop and the tire you're getting.
Will you be dropping the car? an inch? 2 inches?
What tires are you set on?
For example, you can get a +22 offset rim and put 215 tires or get a +35 and get a 235 or 245 tire
      11-28-2012, 05:37 PM   #12
martinf79
martinf79's Avatar
78
No it doesn't
^ That was my point. The further off diameter you are ... the more you are mialigning your speed + mileage.
Sometimes ... its not JUST about asthetics. You can accomplish your asthetic preference by doing a little math.
      12-01-2012, 02:18 PM   #13
jrob
Bimmer God
Drives: 2003 BMW 330i
If you can tell a 1mph difference at highway speeds then you are much more attuned to your car than me.
      12-01-2012, 02:20 PM   #14
nick2013328i
Drives: 2013 328i
aha
      12-19-2012, 03:36 AM   #15
nano10
nano10's Avatar
148
Drives: 2018 F80 M3
I just installed 19x9.5 et32 in rear with 265/30/19 Michelin PSS. No rubbing now but worried about drop. How do you guys think I can make this work? Or am I worried too much and the drop will fix how the rear tire sticks out?
      12-19-2012, 01:18 PM   #16
s1k0ne
Drives: ..
drop it and your rear will camber in.
BTW, OEM 19"s are 35/30 sidewall
F80 M3 '18 | ordered
F30 335i 6MT | modified
      12-28-2012, 10:47 PM   #17
Tra08R
Money never sleeps
Australia
Drives: e92 - 2007
19x9.5 +38 in the rears.
      12-29-2012, 12:36 AM   #18
slmdgee
Usofstance
Drives: 328I 6SPD
no u cant rock 35 offset in the front you will rub the coil over!!!!! i learned the hard way
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      12-29-2012, 12:40 AM   #19
dcg71
Australia
41
Drives: F15 X5 25d / Ducati Monster
If you drop it will camber in a bit, but personally i think you will still rub on hard cornering . PSS have really square sidewalls. I've had 265s in other brands that were less beefy than 255 Michelin PSS. 255 is as wide as I'd go at et32.
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      12-29-2012, 02:36 AM   #20
nano10
nano10's Avatar
148
Drives: 2018 F80 M3
Thanks guys, for now, I like the wheels and like the comfort feel of stock. I do wish I had better stance and less body roll. Just got the car 2 weeks ago so gonna see if something comes out with 20mm to 25mm drop over the M sport. On side note, anybody ever ordered custom offsets from BBS?
      01-20-2013, 02:56 PM   #21
pkimM3r
pkimM3r's Avatar
136
Looking for a square setup for the track 18x8.5. What offsets will fit both front and rear?!
      01-20-2013, 03:58 PM   #22
RollingLower42
RollingLower42's Avatar
30
Drives: 2012 BMW 335I
@ slmdgee, What do you mean you learned the hard way? Was it really rubbing? Was it rubbing when you turned only or what?
I ask because I am running 19 x 8.5 + 35
19 x 9.5 +45
@ OP, I have had no trouble with those offsets, and I have KW V2 with about the same drop as you are requesting..
