BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Loss of Power Malfunction
Evolution of Speed
      12-10-2012, 11:07 PM   #1
ybbiz34
ybbiz34's Avatar
416
Drives: 2013 C63 AMG Sedan
The problem described below has occurred now three times, with the most recent event being this morning.
Symptoms: Loss of power/dead throttle (power loss is present irrespective of driving mode [i.e., Sport+, EcoPro, etc.]); Heard the cooling components/fans in the engine bay working overtime (very loud); Vibrating/pulsating steering wheel at idle; NO ERROR messages).
Below is a detailed account of what happened the first time I experienced the problem. The first time the power loss occurred was after a loss of traction event. The second and third times I experienced the power loss/dead throttle, there was no preceding traction loss event.
The problem seems to go away after I shut the engine off and restart it. However, the last two times I have done that, I have received an "Adaptive headlight malfunction" error message upon restart.
I am taking the car to the dealer on Wednesday but in the meantime, any thoughts, ideas, etc. would be appreciated.
I was on my way home today, driving in Comfort mode, when all of a sudden I noticed that I could feel my steering wheel pulsating.
The pulse started out as very minimal, but noticeable. However, over time, the pulsating became more severe (noticeable at idle as well).
Next, I noticed that the engine started to sound like it was working overtime. This was maybe 2-3 minutes after I noticed the pulsating steering wheel. For example, I could hear what sounded like a cooling fan straining. It sounded as if I had just tracked the car on a 110 degree day.
Finally, the throttle went almost completely dead. If I mashed the pedal to the floor in Comfort, Sport, or Sport Plus, the car accelerated as if I was lightly applying the throttle in EcoPro.
No warning lights, codes, etc. Loud engine, pulsating steering wheel, nearly completely dead throttle.
Completely baffling. Once I got to a point at which I could safely pull over, I did so and shut the engine off. Upon restart, everything seemed fine but at that point I was less than a mile from home.
'13 Iridium Silver C63 AMG Sedan (540 hp; 500 lb-ft)
Review of F82 M4: http://f80.bimmerpost.com/forums/sho....php?t=1008143
[SIGPIC][/SIGPIC]
      12-11-2012, 05:16 AM   #2
Koca
Drives: In the factory
Could be a thermostat issue - the cars computer could be thinking the engine is getting too hot so to prevent any damage, it cuts the power
      12-11-2012, 07:03 AM   #3
ybbiz34
ybbiz34's Avatar
416
Interesting. I hadn't considered that. That would explain the power being cut and the fan going crazy. Pulsating steering wheel and light malfunction components still have me puzzled.
[SIGPIC][/SIGPIC]
      12-11-2012, 10:39 AM   #4
mocohead
mocohead's Avatar
31
Drives: '16 M235i 6MT & 12 128i Msport
weather conditions?
      12-11-2012, 08:08 PM   #5
ybbiz34
ybbiz34's Avatar
416
Originally Posted by mocohead View Post
weather conditions?
Once in the rain. Twice in bone dry conditions. Temperature has never been above 45 degrees.
[SIGPIC][/SIGPIC]
      12-11-2012, 08:55 PM   #6
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
Same happened to me today..
Light rain 70degres.
Floored it up an on ramp thru two gears and then BAM.. limp mode.. iDrive shows drivetrain malfunction car lost power when i gave it gas car would shake.. turned it off and back on and its fine...
better not keep happening.
M Sport Line Estoril Blue
      12-12-2012, 10:44 AM   #7
mocohead
mocohead's Avatar
31
OP I was wondering if it could have been related to FEM issues people are encountering, hence the weather question. Any other odd electrical symptoms?
Have you noticed any change in fuel economy? Is the car cranking longer than normal to start?
All of my previous 335i's encountered similar symptoms, although they were N54 cars. Without fail it was related to HPFP's and injectors. Whether or not that is your issue can only be determined by having a dealer read the codes. I do recommend having that done.
I sincerely hope it is none of the above! Sorry you all are experiencing this issue but I look forward to hearing what codes were stored. Best of luck!!!
      12-12-2012, 11:42 AM   #8
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [5.00]
2013 X5  [0.00]
2013 335i F30  [4.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
I've had the fan issue and dead throttle happen to me. Fan goes on full blast and throttle feels numb. I also noticed the engine temp stuck on the left side. Happened three times already. I'm thinking its thermostat as well but also wondering what else it could be
No codes thrown and restart of car it went away. Car has 500 mls on it
      12-13-2012, 12:47 AM   #9
ybbiz34
ybbiz34's Avatar
416
Your problem sounds different than mine in that when my throttle died, no codes were thrown.
Good luck getting your issue resolved.
Thanks! My fuel economy continues to increase. No long cranks either.
Well my dealer found the problem today.
I can't remember the name of the failed component my SA said that it was "toast."
The dealer ordered the replacement part and will be installing it tomorrow. I'll update the thread when I figure exactly what was wrong.
[SIGPIC][/SIGPIC]
      12-13-2012, 08:14 AM   #10
Falafel Combo
I can't heel toe!
Falafel Combo's Avatar
Drives: X5 xDrive50i
Roh Noh! Subscribed!
2015 ZF8 f15 X5 M-Sport
2015 6MT f80 M3
2013 6MT f30 335i M-Sport
2012 6MT e92 M3 ZCP
      12-13-2012, 06:58 PM   #11
ybbiz34
ybbiz34's Avatar
416
Well the culprit was a faulty/busted electric cooling fan. Pretty much had failed in every way conceivable.
Just got my car back and wow did it feel strong.
[SIGPIC][/SIGPIC]
      12-13-2012, 08:36 PM   #12
s1k0ne
Drives: ..
same thing happened to me today!
F80 M3 '18 | ordered
F30 335i 6MT | modified
      12-13-2012, 10:31 PM   #13
ybbiz34
ybbiz34's Avatar
416
Take it to the dealer and have them check out your electric cooling fan.
They were able to do some code-reading and even though my car did not display any error messages when it got toasted the first time around, they showed me some pretty interesting/devastating data.
[SIGPIC][/SIGPIC]
      12-14-2012, 02:38 AM   #14
s1k0ne
Drives: ..
what data?
      12-16-2012, 12:45 PM   #15
mocohead
mocohead's Avatar
31
PHEW! Great news OP! I am really happy to hear it was nothing serious.
      12-16-2012, 01:31 PM   #16
Mak135i
Drives: ATS-V
Same thing seemed to happen to my car yesterday, so I hooked up my BT cable and sure enough...electric fan fault code. will take to dealer tomorrow and see what they say. There was also a fault code in the transmission area: "Forced up-shift related to cooling and driving condition..." Probably related to the fan issue
Gone but not forgotten: 2008 BMW135i Vert
Gone but not forgotten: 2011 MB C63 AMG
Gone but not forgotten: 2011 BMW z4 3.5is
Gone: 335i
Added: 2015 Z4 3.5i
      01-26-2013, 09:28 AM   #17
Dinh335
Drives: 2004 RX8/2015 M3/2017 X5 35i
When were your cars built? Wondering if this is still a potential issue or happening in late 2012' MY2013 cars too?
2015 Tanzanite Blue M3 /19 silver/exec/SS full leather/hk/cams/6speed_Wife 2017 x5 xdrive 35i
      01-27-2013, 07:22 PM   #18
ybbiz34
ybbiz34's Avatar
416
Mine was an August 2012 build.
My brakes are squealing again (after already having been replaced twice).
My electric cooling fan also malfunctioned again (after already having been replaced once).
My dealer has been in contact with BMW regarding buying this car back. What I will do next remains a mystery to me. Another M-Sport 335i? C63? S4?
[SIGPIC][/SIGPIC]
      01-28-2013, 09:57 AM   #19
johnofcross
johnofcross's Avatar
Drives: Superman 2013 F30 335i M Sport
Wow this happened to me yesterday, and I'm also an August 2012 build for a MY13. If it happens again, I'll take it to the dealer. Should I wait till another incident, or just go now and get it looked at? Also have the squealing brakes so I might turn it in for both.
2013 BMW 335i Sedan Estoril Blue II M Sport 19" 403M|6MT|Dynamic Handling|Tech Package|Coral Red Leather|Park Distance Control|Harmon Kardon
      01-28-2013, 11:19 AM   #20
ybbiz34
ybbiz34's Avatar
416
Take it to the dealer so a record of this malfunction can continue to be built up.
[SIGPIC][/SIGPIC]
      02-01-2013, 04:22 AM   #21
impossiblesrock
BRAR_///M
Drives: 2017 M4 ZCP
This happened to me tonight! I just got my 335i msport last night and it had 100 miles on it because it was a dealer trade and had to drive down from the Ventura area to Orange County. So I was driving normally from a stoplight then acceleration basically became limp and the fan started going really loud. This happened twice within 20 minutes.
I am going to turn it into the dealer tomorrow to get it checked out. I just hope the first 100 miles on the car werent too harsh. Also my car pulls to the right when I let go of the steering wheel and has a slight vibration from around 40-60 mph. I have the dynamic handling package so Im thinking it has something to do with that. Anyone else have that problem?
I love this car to death but these problems are definitely putting a damper on my excitement
      02-02-2013, 03:23 AM   #22
ybbiz34
ybbiz34's Avatar
416
BMW is buying my car back. My electric cooling fan has crapped out twice. The brakes still squeal (worse than ever now, after 5,000 miles and two complete rear brake replacements). They want to order me another car in - identical to the one I have. Not too excited about that option at this point.
[SIGPIC][/SIGPIC]
