BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > LSD for the F30?
Vorsteiner
      12-12-2012, 04:22 PM   #1
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
LSD for the F30?
Anybody heard/know what WaveTrac's plans are to build a torsen LSD for the F30? Does the F30 have the same horrible ring gear welded to the differential carrier that the 2007+ E90's had?
      12-12-2012, 05:33 PM   #2
RSXDC5
RSXDC5's Avatar
137
Drives: M3
I would like an answer on this too! The F30's open diff is really a bummer to drive with :/
2015 M3 - Alpine White 6Spd
LED's, CCB's, Adaptive Dampers, Swifts, VRSF DP's, GC Camber Plates, 275/305 AD08R, Signature Wheels SV103 19x10.5/11.5
      12-12-2012, 06:30 PM   #3
PGT
Drives: 440i X-Drive in Snapper Rocks
even with 255's in the rear? seriously?
| '13 328i M Sport - Estoril Blue | '12 300C SRT8 | '12 Wrangler Rubi Unlimited - COD MW3 Edition|
      12-12-2012, 10:15 PM   #4
RSXDC5
RSXDC5's Avatar
137
Drives: M3
Coming out of slow speed corners, damp surface, having just your inside tire spinning is no fun, seriously
      12-13-2012, 12:24 AM   #5
utenigma
+1
Worse with DTC juddering away trying to fix it
      12-13-2012, 12:29 AM   #6
gtastray
Drives: 2013 335i M-sport
Yeah im wondering in the same thing. LSD is a must for a RWD car.
      12-13-2012, 01:00 PM   #7
Bold Vitalic
Drives: F30 320d
Originally Posted by utenigma View Post
...Does the F30 have the same horrible ring gear welded to the differential carrier that the 2007+ E90's had?
Sad but yes it does. So the only way is to switch the rear shaft completely?
      12-13-2012, 03:22 PM   #8
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Umm....for manual trannies only, correct?
SOLD: 2012 335i Mineral Gray
      12-13-2012, 05:27 PM   #9
utenigma
Post 2007 E9x's wavetrac had a kit where you'd send your dif/ring gear assembly to them, and they'd separate the ring gear from the diff with a CNC machine, then they'd drill and thread it to allow bolt mounting to the wavetrac diff - super fun, like an extra $700 fun or something like that
      12-13-2012, 05:43 PM   #10
utenigma
I'd hope they'd offer one for both manual and auto with different gear ratios (being that the final drive ratio's are different between the two)
328i MT - 3.91:1
328i AT - 3.15:1
335 MT - 3.23:1
335 AT - 3.15:1
      12-13-2012, 05:46 PM   #11
shivaswrath
Drives: 2012 335i
328i MT - 3.91:1
328i AT - 3.15:1
335 MT - 3.23:1
335 AT - 3.15:1
Doubt they'll tweak FG's...that'll impact fuel economy.
Have they ever offered an LSD for auto's? Usually past will dictate outlay for new existing models.
      12-13-2012, 06:06 PM   #12
utenigma
Yeah, They've got diff's for MT and AT E9X's
http://wavetrac.net/application_bmw335.htm
      12-13-2012, 07:38 PM   #13
RSXDC5
RSXDC5's Avatar
137
Drives: M3
We need to start emailing wavetrac to begin developing a differential for the F30!
      12-14-2012, 03:24 AM   #14
Bold Vitalic
Drives: F30 320d
This is quite a money saving approach. Respect to wavetrac if they'll manage to do it the same way for F30
Нere in Moscow the only way available now is to install a complete rear shaft with Quaife diff. The price is 5k$ incl. labor hours.
