BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > changing sport display to show HP.TQ
Extreme Power House
      12-30-2012, 07:05 PM   #45
300hp
Drives: X5 & 335xi
Mine is German built. Build date is October 2012, took delivery last weekend, it has hp and tq
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs
Deep Sea Blue Metallic 2013 X5 35d Sport
Prem, Convenience, Cold and Premium Sound packages
      12-30-2012, 07:07 PM   #46
Frogman
Frogman's Avatar
Drives: 2012 F30 328i
Originally Posted by RJK993 View Post
mine is NOT in horsepower.
took delivery 12/14. the car was a 11/6 US build 335xi msport from regensberg
do i need to code my car?
Did you do ED?
You can either just take it into the dealer and they *should* be able to switch it to HP/ft-lb, or you can just code it to allow you to select the units you want.
      12-30-2012, 07:28 PM   #47
Sladester100
Sladester100's Avatar
Drives: F30 320d ED
What is this "do ED" you talk about?
Mine is KW and Nm and would like HP and lb/ft if I can. Where is the setting usually?
Also is TPMS standard if you have full prof nav ? Mine's a UK car tho
On order/Its Here! F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
      12-30-2012, 08:07 PM   #48
BMWFanatic2008
BMWFanatic2008's Avatar
156
Drives: M4
Originally Posted by Jamesons Viggen View Post
Nope.
No Navi here as well and I don't have this option altogether. Doesn't make much sense, every sport/msport should have it IMO.
F82 M4 | Yas Marina Blue | SO Extended Leather | DCT
F80 M3 | Sakhir Orange | SO Extended Leather | DCT (Gone)
F30 335xi | MSport | Estoril Blue | Sport 8AT (Gone)
F30 335xi | MSport | Estoril Blue | 6MT (Gone)
E92 335xi | MSport | Le Mans Blue Metallic | AT (Gone)
      12-30-2012, 08:15 PM   #49
Frogman
Frogman's Avatar
ED = European Delivery.
See if you can change the power units in Settings -> Language/Units menu. If not, then coding can be done to enable the power unit selection.
RE: TPMS; I think UK builds only get FTM, not TPMS. This means that you can't display the tire pressure & temperature on the iDrive display. I don't think it has anything to do with nav or not. If you have metal valve stems, you have TPMS. If they are rubber, then you have FTM.
      12-30-2012, 08:16 PM   #50
Frogman
Frogman's Avatar
Agreed, it's weird that the sports display is tied to having the prof nav system.
There's some conjecture that the sports display is dependent on the combox which is only available on navi equipped cars; but no one has confirmed it yet.
      12-31-2012, 09:32 AM   #51
chugster
B0$$
chugster's Avatar
Drives: 13' AW 328i Sport/Coral Red
My says kw and nw and my is a 7/12 build and i picked it up in 8/12. This is a 2013 328i sportline btw. So I guess I have to go in and get a software update? Is that update free?
      12-31-2012, 11:38 AM   #52
tdizzle
Drives: 2017 F80 ZCP
Same here 2012 335i sportline 'sporting' metric units.
      12-31-2012, 11:59 AM   #53
vern
Drives: 2012 F30 335i Sport 2006 X3
Anyone doing coding like " Frogman" in the NJ area?
cheers
vern
      12-31-2012, 12:17 PM   #54
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
cheers
vern
Check the NY/NJ regional section as we are trying to line up a date.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      12-06-2017, 09:46 AM   #55
Titan_br
Titan_br's Avatar
Brazil
Drives: M3 E92 with AA Stage 3 SC
2011 BMW M3  [0.00]
Originally Posted by Frogman View Post
We coded TreDirtyFive's car last night and got the sports display to show HP/ft-lbs.
We activated the EFF_DYN_SPORT_UNIT value. That enables the Power units to be changed via the Settings -> Language/Units screen. We changed them to HP and ft-lb.
We also coded the TPMS and that showed up in metric units too. Adding TPMS also adds pressure units to the Language/Units screen, so we just switched to psi/F.
Thatís true thank you
