BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 Wind-Noise Issues
      12-14-2012, 02:28 PM   #1
SamGh
The Mechanic
Drives: 2016 F30, 340 MSport
Just like many other users complained about wind-noise, I went from E90 to F30 and noticed excessive wind noise in the cabin above 50 mph. This is noticeable on both Driver and Passenger side.
You would hear this noise if you pay a little attention without Steroe on.
I took it to my dealer and the shop foreman told me that there is no defect in the car and its likely to be from the size of the side mirrors. Although I can't agree with that, I have to say it is possible, specially in combination with aerodynamics (Shape of the mirror and position etc.) At any rate, it seems like a design flaw.
He also mentioned that earlier production had a problem with a window seal, but that is resolved.
My car is a 335 Msport, Sep production from Germany. To prove/disprove the shop foreman, I test drove one 335 and one 328 from two different dealers and they also had this issue.
I have read on other threads that there has been attempts to repair this issue by other dealers, which seems to not have fixed a issue. Hence, I advise against this action if you notice this issue, unless the issue is beyond normal for F30.
As a final attempt, I reached out to BMW NA, and the rep said they will relay this to manufacturer, and if there are enough complaints about it, they might attempt to fix and retrofit.
So do your part, and reach out to BMW if you care about this issue.
Thank you,
Drive Fast Not Furious
      01-07-2013, 04:19 PM   #2
Sharp_Cai
Sharp_Cai's Avatar
64
Drives: 2013 BMW 335i
My car has the same issue. I took it to the dealer last Saturday, and had a tech drove my car around, and they admit there is a wind noise going on during 50mph+. Scheduled an appointment for next week, and I will see how it goes.
2013 BMW 335i EBII ///M Sport MPPK MPE MPS 405M
2016 BMW X5 MW M Sport MPPK MPE
2018 BMW M3 YMB on order.
      01-07-2013, 05:13 PM   #3
SamGh
The Mechanic
It is interesting that they are taking an action. Be very careful as what they are going to do. I have driven 4 f30s 335s and 328s and they all have it. Some people say they dont have it simple because they are not sensitive to the noise. My conclusion is that the mirrors direct the air towards the windows and creates the wind noise. My dealer did test with high pressure water in my car and there was no leaks any where
      01-07-2013, 05:21 PM   #4
Sharp_Cai
Sharp_Cai's Avatar
64
The issue has been confirmed in my case. BMW service is going to fix it for me by this Saturday. I will let you know the results.
      01-07-2013, 10:29 PM   #5
KY52PNN
China
Drives: BMW 320i (F30)
I have a 320i in China, and I also found this issue, does it sound like whistle when the speed goes up to 80 km/h (50mph).
      01-07-2013, 10:37 PM   #6
rayusaFL
Drives: 2013 F30 335i (Alpine White)
Oh boy... Here we go again. Lol
My advice people? Don't even bother with this issue. I wish I had never taken my car to the dealer and here is why:
http://www.f30post.com/forums/showthread.php?t=777871
      01-08-2013, 05:52 AM   #7
ThomasF30
South Africa
Drives: BMW 320d F30 Mineral White
Same issue here
I have the 320d F30 in South Africa. We have a plant here at Rosslyn - but I also experience the exact same problems with wind noise. At speeds above 90 kph, a whistling noise enters the cabin from all the doors, mainly the front ones. So I think it's a design issue rather than an assembly issue, since this seems to happen all over the world.
I've had mine back to several dealers multiple times - next week it's going in for the 5th time in 4 months
So far they've done the following, with no difference to the noise levels:
  • Refitted Windshield
  • Replaced all the door seal rubbers
  • Realigned all the doors (and in the process messed up the one to the extend that it needs to be slammed extremely hard to close)
The tech from BMW also said it is because of the side mirrors' design not allowing air to flow off of it, but rather routing it over the windows, causing more wind noise. What a pity. BMW should seriously recall this issue - it's not very German like...
      01-08-2013, 05:57 AM   #8
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
I don't have a whistle, or noise that bothers me in any way. But there are two things that stick out for me when it comes to this problem...
* There is a noticeable space between door panel and B pillar where I can see door/paint.
* The door doesn't look like it sits exactly flush with the B pillar when closed. It doesn't look bad or off by a lot, but if you look in a side mirror you can notice it.
johnsedlak.com - web developer, designer
      01-08-2013, 06:24 AM   #9
Tsuvoi
Drives: 2013 F30 328i
If the noise is due to seams in the car body such as bad seals or a seam between the door and pillar, it's easy to test for. Just use painter's tape and cover up the seams to negate their impact and drive away.
      01-08-2013, 07:47 AM   #10
gator15
I have no doubt that your car has significant wind noise. However, if it is due to the design of the mirrors, there is really nothing BMW can do about it at this point besides changing the design for future models. What can they do at this point? Rip off the mirrors from the body? It definitely sounds like there may be a design flaw, but it in no way is a safety issue, which is the primary reason that a recall is issued. My advice is to leave it alone and turn the music up a little louder.
      01-08-2013, 08:43 AM   #11
ducatiboy72
Norway
Drives: F31 M-Sport
My stepfather also complained about wind noise on the passenger side, but I am unable to hear anything myself. Other people also are unable to hear anything. Maybe only people with exceptionally good hearing can hear it?
      01-08-2013, 01:35 PM   #12
Boosted John
Internet Ninja
Boosted John's Avatar
Drives: 13 AH3
I don't have any wind noise issues in my car..
2013 BMW ActiveHybrid 3 /// Msport Pkg. M performance fornt lip, Black Kidney Grills, H&R Sport Springs, BBS CH-R
      01-08-2013, 01:46 PM   #13
m1kal
Drives: F30 335i M-Sport
I will try today and listen closely.
2013 F30 335i Alpine White M Sport
      01-08-2013, 03:16 PM   #14
SamGh
The Mechanic
No here we are not going there again The point of the thread is exactly making people aware that there is DESIGN FLAW NOT A DEFECT
You can call BMW and raise your concern, so they f'ing fix it with a retro or at least fix it in future.
      01-08-2013, 03:56 PM   #15
normsbimmer
Drives: 2012 328i
Will brig my car in for the 3rd time. 1st one they fixed the first time on the passenger side.
But the driver side isn't fixed yet. Will bring it in tomorrow again for the same problem
      01-08-2013, 04:21 PM   #16
Sharp_Cai
Sharp_Cai's Avatar
64
isn't 320i bulit in China???
      01-08-2013, 04:21 PM   #17
Sharp_Cai
Sharp_Cai's Avatar
64
I have to give it a try before I give up on it~~~ lol
      01-08-2013, 04:23 PM   #18
Sharp_Cai
Sharp_Cai's Avatar
64
That is excatly what my dealer is going to do at first.
      01-08-2013, 04:24 PM   #19
Sharp_Cai
Sharp_Cai's Avatar
64
Turn off ur radio first~~~ lol
      01-08-2013, 04:25 PM   #20
Sharp_Cai
Sharp_Cai's Avatar
64
Your reply is worthless then. lol jkjkjk
      01-08-2013, 04:26 PM   #21
Sharp_Cai
Sharp_Cai's Avatar
64
How did they fix your passenger side??
      01-08-2013, 04:36 PM   #22
MotoEV
MotoEV's Avatar
Drives: BMW Active Hybrid 3
I have zero wind noise as well.
As other have mentioned, if you feel this is a problem warranting attention get your facts in order. Pinpoint specifically where the noise is coming from and at what speed. BMW tends to be very strict on what corrections dealers can perform.
BMW has a PUMA database and I would ask your service team to research any other vehicles having the same problem and the prescribed correction from corporate.
It took BMW six months to correct a part defect in a product I own and I learned the hard way that BMW follows a strict problem remediation process.
noise, wind noise, wind-noise, windnoise
