BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Is anyone having trouble with A.S.S? Mine isn't working
Vorsteiner
      12-17-2012, 11:41 PM   #1
momo3605
Drives: 2016 M4
A lot of the threads are saying that their cars will turn off even when their engines are cold. But my 2013 rarely turns off. Even if I've been driving for over 30 minutes. The dash just shows a picture of the A.S.S button with a line through it in the dash. I wonder if something is wrong with my car. Today it turned off once, and then the next time I came to a stop sign it didn't come on again. Does anyone know the conditions at which is should come on? The oil temperature sits around 200 and it's around 50 degrees F outside.
Thanks
      12-18-2012, 01:56 AM   #2
TrueBlue12
TrueBlue12's Avatar
Drives: Imperial 328i
Get it reprogrammed.
      12-18-2012, 09:43 AM   #3
Michael Schott
Drives: 2017 VW GTI Sport
Sounds like it's already reprogrammed to remember the last setting which in this case is off.
      12-18-2012, 11:02 AM   #4
Falafel Combo
I can't heel toe!
Falafel Combo's Avatar
Drives: X5 xDrive50i
Wait, you're trying to get it to work?
2015 ZF8 f15 X5 M-Sport
2015 6MT f80 M3
2013 6MT f30 335i M-Sport
2012 6MT e92 M3 ZCP
      12-18-2012, 11:07 AM   #5
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [5.00]
2013 X5  [0.00]
2013 335i F30  [4.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Be glad it's not working. My problem is I forget to push the OFF button when I start the car.
Constant startup shudders and vibration would probably wear out the motor mounts much faster
      12-18-2012, 11:21 AM   #6
tdizzle
Drives: 2017 F80 ZCP
I'm pretty sure if there is a line through it, then it's turned off, which would explain it not turning the engine off.
      12-18-2012, 12:04 PM   #7
mjc919
Drives: 13 335i msport
Same with mine, been that way since day 1. It barely shuts off... Or when it does, it may or may not do it again for the rest of the ride....
anxiously waiting to take delivery: 2013 335i m-sport blk/blk 403M prem cw tech zda zdh sport-8AT HK sound.
      12-18-2012, 11:05 PM   #8
JamesMA
JamesMA's Avatar
20
Drives: 2013 F30 335i M Sport
+1
2013 F30 335i 6MT M-Sport - Blk Saph. / Beige Lthr / Wood Tr. - Tech Pk - VSS M-Adp. Susp. M-Perf Stainless Exhaust M-Perf. brakes
      12-18-2012, 11:19 PM   #9
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
lit is OFF.
SOLD: 2012 335i Mineral Gray
      12-19-2012, 03:25 AM   #10
RPM90
Drives: 340i M-sport AT
Thanks
Just a reminder, if you're in manual trans mode or sport trans mode ASS won't shut the engine off.
Remember to make sure that ASS is activated by pushing the on/off button right on top of the engine start/stop.
      12-19-2012, 04:47 AM   #11
Sprocket
Drives: BMW F31 328i
RTFM.
There are a number of conditions under which ASS won't trigger. They include (among other things):
- low outside temperature
- cold engine
- the AC is working to get the interior temperature up or down to a reasonable level
Again, check the manual to see what applies to your car and market (this is from the swedish manual, but I have read in other threads that at least some of these conditions apply elsewhere).
Melbourne Red F31 328 M sport
