BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > New member- just dropped f30 off at dealership
Vorsteiner
      12-19-2012, 12:24 PM   #1
Mikegtr
Mikegtr's Avatar
Drives: F30 328i
I'm new here but I know that the topic has been discussed over and over again, but my situation is a little bit different.
So I just dropped my US Spec July build F30 328i off at the dealership for a couple of things.
Steering wheel vibration
Left inner tail light loose
And auto start stop to remember last setting
I went on a test drive with the service advisor and he said that there's nothing that they can do about the steering wheel vibration and that it's "normal" so they aren't going to do anything about it.
And they had no Idea what to even think when I showed them the service bulletin number for the tail light fix.
Will BMW NA be able to help me out with my car since I'm US military stationed in Germany and I have a US Spec car?
Thank you in advance.
      12-19-2012, 02:40 PM   #2
EB_F30
Drives: 13' M Sport 335 6MT
Sorry to hear about your issues...sounds like there being pretty shady. I'm also Military (USAF) in Italy and hope I don't run into problems while I'm here. I still have about 2 years here...just enough to cover the euro 2 year warranty unlike the states 4 year so I was hoping to be worry free.
      12-19-2012, 02:49 PM   #3
Mikegtr
Mikegtr's Avatar
Drives: F30 328i
I only have about 5 months left. Not sure yet where I'm going but if they don't help me out here, when I get back to the states I'm going to throw a fit.
      12-19-2012, 03:07 PM   #4
BMWgasm
Hooah!
BMWgasm's Avatar
Drives: 2011 335i M Sport
Since your car is not yet registered with BMWNA there is nothing they can do for you.
'11 E90 335i M Sport Black Sapphire
'13 F30 328i M Sport Black Sapphire
      12-19-2012, 03:19 PM   #5
Mikegtr
Mikegtr's Avatar
Drives: F30 328i
When does it get registered with them? Only when I bring it into the states?
      12-19-2012, 04:11 PM   #6
dc_bmw
Netherlands
Drives: BMW 330e
You should not let them gat away with that is there is a solution called a new steering rack. my car is currently in t dealership for a new rack and according to the dealer all customers with a new rack are free of vibrations.
(road forced balancing did help, but did not solve the issue. I hope this major change does )
      12-19-2012, 04:23 PM   #7
BMWgasm
Hooah!
BMWgasm's Avatar
Yeah. You have to do some paperwork. I can't recall if it's done online or you need to go to a dealer. Either way you need to do it so your warranty will kick in. Keep in mind that the NA warranty is four years, but you will have to subtract the time in Germany from the four years.
      12-19-2012, 07:17 PM   #8
LAnderson23
Drives: 2015 M4
What's this about the left-tail light being loose? Is that a common problem? I hadn't heard of it.
      12-20-2012, 02:40 AM   #9
Mikegtr
Mikegtr's Avatar
Drives: F30 328i
http://www.f30post.com/forums/showthread.php?t=735941
When I notice it I googled it and found this. There's more threads related to the topic as well.
      12-20-2012, 08:17 AM   #10
claykin
Drives: 2016 535i M-Sport
Print this page and take it to dealer. Your car has the 3rd generation rack, but it seems the 4th generation has finally resolved the vibration.
Dealers in the US are ordering this new rack to handle vibration cases. Its on a case by case basis and requires BMW approval.
Something else to note, along with the steering rack changing for November+ builds, BMW also changed the steering column, column lower joint and wheel hubs. Its possible that more than just the rack needs to change to fully resolve the vibration.
http://www.realoem.com/bmw/showparts...71&hg=32&fg=12
Don't take no for an answer. If need be, speak with service manager or ask dealer to make you an appointment with their area factory rep.
      12-20-2012, 02:17 PM   #11
EB_F30
^ well my 335 just started production last week so hopefully I have the updated steering rack and will avoid this issue...I can just see Italy being a pain for warranty issues.
      12-20-2012, 03:11 PM   #12
BMWinGE
My previous experiences here in Germany found it to be much more difficult get the same level of customer service as in the US. If its clearly malfunctioning there shouldn't be a problem to get it fixed under warranty, but it sounds like they didn't agree that something is wrong, at least during the initial assessment. I would say give it a try, but it may be easier to take care of it back in the US.
      12-20-2012, 09:41 PM   #13
LAnderson23
Drives: 2015 M4
Thanks.
      12-22-2012, 05:23 AM   #14
Mikegtr
Mikegtr's Avatar
Drives: F30 328i
So I just got back, they said they checked everything and on the front wheels the weight was off by 15grams between the wheels. So they rebalanced them and it seems better, but I only drove it for about 2 miles so far.
My tail light is all fixed now too they said that it was just remounted not replaced like some other members. So we'll see how it goes.
Thank you for the responses and I'm going to get everything looked over and taken care of when I get back to 'Merica where the customer service is better.
      12-22-2012, 06:13 AM   #15
Drk280
Drk280's Avatar
Australia
Drives: 2012 F30
Here in Australia I was told that my car being 2cm lower on the rear driver side and 1 cm lower on the rear passenger side was normal and that it will not affect the driving of the motor vehicle. They will not fix it so I just have to drive with a leaning car. Funny how a Mazda that is 1/5 of the price is level all round.
      12-22-2012, 09:04 AM   #16
claykin
Have you gone to lot and measured other cars for comparison? If your car measurements are atypical they should do something. Ask for BMW rep to look at car.
I assume you have not changed/customized car in any way?
      12-22-2012, 09:13 AM   #17
fshubert
fshubert's Avatar
84
Drives: 2015 F30 335i
My production date was July 2012 (delivered as a MY2013 F30). No vibrations. I wonder if I was just lucky or if the newer-generation rack was installed in the MY2013 cars.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      12-22-2012, 09:16 AM   #18
claykin
Do you have DHP?
If not, then you're simply lucky. Enjoy.
      12-22-2012, 09:24 AM   #19
fshubert
fshubert's Avatar
84
Originally Posted by claykin View Post
Do you have DHP?
Nope, no DHP. I'm usually not lucky unless bad luck counts and then I'm almost always lucky. Sounds like a reversal this time. Phew!
      12-22-2012, 01:45 PM   #20
Mikegtr
Mikegtr's Avatar
Drives: F30 328i
Well after more driving its the same. Just the placebo effect of getting my car back I guess.
I planned on buying the extended warranty when I got back anyway. So hopefully the dealer that I buy it from is more inclined to fix it then.
At least my tail light is fixed.
      12-22-2012, 01:46 PM   #21
Mikegtr
Mikegtr's Avatar
Drives: F30 328i
Mine is MY13 as well.
