BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > are camber kits need?
      12-28-2012, 03:58 PM   #1
949
Drives: ?????
when these new 2013 bmw 3 series are lowered, are camber kits needed?
      12-29-2012, 01:02 AM   #2
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
When using the M performance kit, no.
SOLD: 2012 335i Mineral Gray
      12-29-2012, 01:50 PM   #3
949
Drives: ?????
i assume because it has a camber adjustment on the top hats?
what kit brands are considered good and which ones should we stay away from?
      12-30-2012, 03:10 PM   #4
shivaswrath
Drives: 2012 335i
I spoke with the tech who installed them and the M perf parts are within spec, so adjustment was done in I have no idea which fashion...
I'd give it a year for more parts to come on market, I would only trust Dinan/H&R camber kits if they become available. For now, for what it's worth, with a drop like below, I don't believe anything extraordinary was done:
      01-03-2013, 11:24 AM   #5
scott@bmwhn
Drives: Msport X3
I'm lowered on the H&R sport springs and no camber plates are required.
Though, I am waiting for someone to release some camber plates to help with clearence of my track wheels, Haven't had a chance to see how much camber can be derived through the factory setup but i'm not expecting much.
15' Msport X3 28i _Mperformance - ACschnitzer - H&R_
15' Sportline X1 28i _Mperformance - H&R - Recaro baby seat_
Previous:13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      01-03-2013, 11:47 AM   #6
's Avatar
61
Drives: ✚
I doubt the M-Perf suspension will have camber plates on the top hats. I was lowered on H&R Sport Springs (which is lower than the M-Perf springs) and when I got my alignment, there was more than enough adjustment room to bring it back to OEM specs.
      01-12-2013, 04:05 AM   #7
949
Drives: ?????
i believe there is an adaptive suspension on the new cars now. how does that work with aftermarket suspensions?
also with aftermarket parts like these, how does the warrenty work?
