BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > First F30 Limp Mode
Vorsteiner
      12-31-2012, 12:07 AM   #1
DarkTrigger
Professional
DarkTrigger's Avatar
Drives: 335i MPPK
First F30 Limp Mode
UPDATE:
"Limp Mode" affects only 335i MSports, 6MT/8AT, X-drive/RWD, & regardless of build date.
Symptoms:
1) Loss of power and car will not rev. past ~3,000 rpm (no fault codes on dash)
2) Radiator electric cooling fan on max (very loud)
3) Engine Oil Temp. approx. 205 degF or lower (while limp mode is occurring, temp. is usually not at normal operating temp of 245 degF)
The problem goes away once car is turned off and back on (it resets). Many users have reported that it seems to happen after a long comfort mode drive on the freeway followed by city driving and switching to sport mode.
Repair attempts:
1) Auxiliary electric Cooling Fan Replacement (mounted to the radiator and fan shroud) - Biggest Culprit (The fan is tested directly and will fail the test but may or may not have a fault code stored in the ECU)
2) Fan relay Replacement
3) Thermostat Replacement
4) DME Replacement with software update
As far as we can tell, there is no SIB yet but plenty of PUMA cases have been filed. Some users have also reported that the MPPK will not solve the issue. A few people have had their cars bought back and replaced by BMW.
Most importantly, there have now been 50+ members of F30Post who have reported the exact same problem on this thread.
Photo from a member while on full throttle in limp mode:
Photo from a member showing the repair invoice:
Name:  Error Invoice.jpg
Original Post:
I don't believe I've seen anyone else on this forum enter into limp mode with their F30 yet. I believe I have for the first time.
I spent the day driving around LA on and off the freeway. The engine was strong all day and I always waited for the oil temp to reach a comfortable level before revving.
About 1 stop sign away from my house (coming back home after a long day) my car won't rev. past 2.5k rpm. I notice a loud fan noise. I do not get any error messages on screen though. I restarted the car as soon as I got home but the fan noise went away and the car was back to normal. Has anyone else experienced this yet?
Is this limp mode? Should I bring it in?
Last edited by DarkTrigger; 07-10-2013 at 09:56 PM. Reason: Update per new information from member posts.
      12-31-2012, 12:17 AM   #2
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
yeah bring it in.
and if there were error codes, ALWAYS snap pictures. the tech's are lost without it if the limp mode isn't noted in the ECU error list.
SOLD: 2012 335i Mineral Gray
      12-31-2012, 12:23 AM   #3
justinnum1
Drives: 2015 328i Msport 6mt
had something very similar happen to me the other day on my way to work.
-was chilly outside
-i always drive real easy to work eco pro the whole way
-this time tho i noticed the oil temp stayed real low, was weird(usually is around 240 by the time i get to work, this time it was around 180
-when i got to work i too heard a very loud fan noise, at first i thought there was an 18 wheeler near me, it was that loud.
-never happened again.
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      12-31-2012, 12:38 AM   #4
DarkTrigger
Professional
Drives: 335i MPPK
-was chilly outside
Never happened again? Well, I hope it's a one off for mine too. I'm still going to bring it in though. I really have not been driving it all that hard.
      12-31-2012, 01:20 AM   #5
justinnum1
to be honest, unless you bring it in with the problem, its pretty much a waste of time, from my experience at least
      12-31-2012, 01:24 AM   #6
M3@Apex
M3@Apex's Avatar
17
Drives: 2008 M3 Sedan 6MT
Was this with a 328? Or 335?
2008 M3 Sedan 6MT || Project Technik
      12-31-2012, 01:57 AM   #7
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Hmmm, could the loud noise be an unprimed HPFP?
      12-31-2012, 02:57 AM   #8
pkimM3r
pkimM3r's Avatar
136
335i. Craziness with 335i's again?? Oil temp didnt even budge on my 328i on any track sessions.
This is bot good to hear.
      12-31-2012, 03:21 AM   #9
DarkTrigger
Professional
Drives: 335i MPPK
335i, 2,800 miles, 2 months old.
      12-31-2012, 03:55 AM   #10
Mak135i
Drives: ATS-V
There was a thread on this some weeks ago. It happened to me once and I was told by the dealer to bring it in when it happens again!
Scanned with my BT cable and I had an error for " Electric fan" in the electric module and another error in the transmission module. It has not happened again but if it does, I will just scan with BT cable and wrote down the error codes and take it in to the dealer.
Gone but not forgotten: 2008 BMW135i Vert
Gone but not forgotten: 2011 MB C63 AMG
Gone but not forgotten: 2011 BMW z4 3.5is
Gone: 335i
Added: 2015 Z4 3.5i
      12-31-2012, 03:59 AM   #11
DarkTrigger
Professional
Drives: 335i MPPK
So they didn't change out anything? I guess maybe I should not bring it in. Keep me updated if it happens again. This is my first!
      12-31-2012, 04:20 AM   #12
Mak135i
Drives: ATS-V
Like somebody else on this thread, I was advised by the dealer to bring it in while it was happening which seems ridiculous since it could happen at night or on a Sunday or when I'm out of town!
Anyway, I do not tell the dealers I have the BT cable. But, if it does happen again, I'll simply take it in and ask them to look for codes. If they say they can't find any, I'll "point them in the right direction".
Gone: 335i
Added: 2015 Z4 3.5i
      12-31-2012, 08:35 AM   #13
Falafel Combo
I can't heel toe!
Falafel Combo's Avatar
Drives: X5 xDrive50i
Most likely a Fan/Thermostat error
2015 ZF8 f15 X5 M-Sport
2015 6MT f80 M3
2013 6MT f30 335i M-Sport
2012 6MT e92 M3 ZCP
      12-31-2012, 11:04 AM   #14
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [5.00]
2013 X5  [0.00]
2013 335i F30  [4.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Yes this happened to me twice already when the car had 400 miles. Now the car has 780 miles and it hasn't happened since. Fan full blast and dead throttle. 335i
I'm wondering if it cleared itself in my car with increasing drive cycles. No codes either and restart it went away
      12-31-2012, 11:08 AM   #15
Mak135i
Drives: ATS-V
ES_TRADER:
How do you know there were no codes? Or do you mean no error messages in the dash?
Gone: 335i
Added: 2015 Z4 3.5i
      12-31-2012, 11:44 AM   #16
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
ES_TRADER:
Right I mean no codes on idrive and check control was OK. There could be stored faults inside but I can't be sure since I did not scan the car.
I want to see it happening on a consistent basis before bringing it into the dealer because they could waste my time with the usual could not duplicate customer concern.
      12-31-2012, 02:48 PM   #17
DarkTrigger
Professional
Drives: 335i MPPK
Wow, I can't believe this has happened to so many people. Any 328i drivers had this problem yet?
      12-31-2012, 03:44 PM   #18
Cfichman
Drives: '13 F30 / '16 F80 AW Ordered
Thumbs down video
This happened to me a few weeks ago , I just uploaded a video of it.
      12-31-2012, 03:45 PM   #19
ybbiz34
Moderator
321
Drives: 2013 C63 AMG Sedan
It's the electric cooling fan guys.
I was experiencing the same symptoms. The dealer found some fault codes and saw that the fan was toast.
Dealer replaced the fan and my car has never felt stronger.
'13 Iridium Silver C63 AMG Sedan (540 hp; 500 lb-ft)
Review of F82 M4: http://f80.bimmerpost.com/forums/sho....php?t=1008143
[SIGPIC][/SIGPIC]
      12-31-2012, 04:22 PM   #20
Falafel Combo
I can't heel toe!
+1.
2015 6MT f80 M3
2012 6MT e92 M3 ZCP
      12-31-2012, 09:41 PM   #21
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
I also forgot to mention when this happened to me the oil temp gauge on the right was right at the notch between 160 and 250 and I know for a fact the car was fully warm. The temp was stuck there after driving for 40 mins too.
Everytime my fan went on Max, engine temperature was stuck and never at the middle mark
      12-31-2012, 10:29 PM   #22
nsquared
[Versatile]
nsquared's Avatar
37
Drives: (S)LOW.
I'm experiencing lack of power in my 2nd gear completely and a loud fan turning on... Is this the same problem? 1 / 3 - 6 gears are awesome though I believe...
I've also noticed my temperature going from being in the middle and going down a bit then back to normal. Is that normal?
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
