BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > First F30 Limp Mode
      02-01-2013, 04:50 AM   #89
impossiblesrock
BRAR_///M
Drives: 2017 M4 ZCP
Experienced this twice today. I picked up my 335i msport yesterday with 100 miles on it due to a dealer transfer. Also car is pulling to the right and vibrates slightly from 40-60 mph. I am in love with the car but these problems are nerve-racking for the 2nd day.
      02-01-2013, 11:11 AM   #90
DarkTrigger
Professional
DarkTrigger's Avatar
Drives: 335i MPPK
That's unfortunate. Just bring it in and they'll replace the aux. electric cooling fan. Should have the faults in the ECU. My car pulls to the right too, but someone was saying that all BMW's pull to the right for some reason. Vibration problem, did you get the DHP with VSS?
      02-01-2013, 08:53 PM   #91
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [5.00]
2013 X5  [0.00]
2013 335i F30  [4.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
I haven't had the fan issue since 800 miles ago but yesterday driving all day in 80deg temps I noticed that the oil temp gauge was reading at the quarter mark between 160 and 250. All my other n55s go a hair to he left of 250 unless it is over 100 degree heat. I was expecting the fan to come on but nothing. No dead throttle but in comfort mode when I floored it without hitting the kickdown button, I noticed there was maybe a 1 second lag before the car took off...maybe just turbo lag in comfort mode? Or less throttle response? Sport mode seemed fine
I hope the previous fan faults are still stored because I think I'll take it in in a few weeks
      02-02-2013, 03:27 AM   #92
NordicBob
NordicBob's Avatar
Drives: '16 M4 Sapphire Black metallic
Originally Posted by NordicBob View Post
UPDATE: Our car was brought to our local BMW dealer today to check out our problem. They are keeping it overnight. It has performed flawlessly since I originally posted my problem. Our car now has 1278 miles on it now.
I will post what our dealer finds, if anything, once we get our car back.
BTW, I am new to this forum but not new to BMW. I really appreciate forums such as these to learn and share our experiences about "The Ultimate Driving Machine."
Bob
UPDATE:
Our dealer found a fault code and replaced the "cooling fan" earlier this week. Only happened once, but our dealer said that they did not want to take any chances so they ordered the part and replaced it under warranty.
335i M Sport to M4
      02-02-2013, 04:45 PM   #93
DarkTrigger
Professional
Drives: 335i MPPK
UPDATE:
Nice. Seems like there needs to be a recall!
      02-03-2013, 12:31 AM   #94
impossiblesrock
BRAR_///M
Drives: 2017 M4 ZCP
Yeah I got the DHP. I like it but it definitely takes some getting used to. My car is at the dealer right now and told them what's wrong and what I've read here so hopefully they figure it out . They're also doing alignment and balancing the tires.
      02-06-2013, 08:46 PM   #95
ybbiz34
ybbiz34's Avatar
429
Drives: 2013 C63 AMG Sedan
My electric cooling fan has been bitten the dust twice.
I just got a call from my SA yesterday. He said the culprit was a faulty relay.
He also said that the car needed a new water pump.
I'm currently waiting for one to be delivered from Germany. Cruising around in a F30 328i base model at the moment. I really believe that the F30 328i is a huge improvement over the E90 version. JMHO.
'13 Iridium Silver C63 AMG Sedan (540 hp; 500 lb-ft)
Review of F82 M4: http://f80.bimmerpost.com/forums/sho....php?t=1008143
      02-20-2013, 01:16 PM   #96
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
Limp Mode Once Again
Happened this morning. Aux fan already replaced once at around 1000 miles mid January. Have 3k on it now. This is BS!
I guess I'll wait and see if it happens again before taking it in.
F30 Sapphire Black 335i 6MT|2PE|4AB|LCSW|ZDH|ZMM|ZPP|ZCW|ZDA|ZDB|ZTP|5AC|4 15|688|Dinan Stage 1 Suspension and Shockware ECU tune
Previously - F30 335i, E46 M3, E39 530i, E46 325i
      02-20-2013, 04:37 PM   #97
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
is there a bulletin on this? finally took mine in today for the fan on max and dead throttle. about the 6th time its happened so i caved and went in. will post the results
      02-20-2013, 04:43 PM   #98
snowghost
snowghost's Avatar
I don't know, but I left a message with my SA to do some research before I bring it in again. Seems unlikely the aux fan would fail again in one month.
      02-20-2013, 05:33 PM   #99
marseille82
marseille82's Avatar
Drives: F30 335i / E60 535i
This is crazy. Just read the whole thread and kind of worried since I also have Msport. 4500 miles, but have not experienced the issue yet.
      02-23-2013, 11:17 PM   #100
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [5.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
UPDATE:
Car fixed, dealer scanned car, found codes, didn't know what to do, PUMA'd it, replaced the relay, Whatever that that is.
Whoever has this issue I urge you to bring it in and have them scan it. At least get the issue documented. Gl
I haven't driven the car yet so I can't report if this is really resolved. Time will tell I guess. Will report back on this thread if it pops up again.
      03-01-2013, 06:53 PM   #101
snowghost
snowghost's Avatar
UPDATE:
Mine is still in the shop and they say the fault code is that same as the first time and are waiting to hear from BMW about what to do next instead of replacing the aux fan again. I kept saying "relay", but it falls on deaf ears. This is really BS.
      03-02-2013, 09:50 PM   #102
ybbiz34
ybbiz34's Avatar
429
That's frustrating.
Welp. It happened . . . again.
BMW has replaced my electric cooling fan twice. They have replaced my relay and water pump.
Yesterday, my electric cooling fan crapped out for the third time.
Good thing my replacement is awaiting a shipping vessel.
      03-03-2013, 04:37 PM   #103
DarkTrigger
Professional
Drives: 335i MPPK
Originally Posted by ybbiz34 View Post
That's frustrating.
How many miles do you have on it now?
I've only had that one electric cooling fan replaced at 3,000 miles, I'm at 5,000 miles now. It hasn't gone into limp mode since, knock on wood.
      03-03-2013, 09:21 PM   #104
M3takesNYC
Drives: m3
Limp mode problems again! So even with HPFP fixed apparently now its a different issue! I was sure bmw would absolutely guarentee no limp mode problems given the fiasco with the e90 335s. Shocking.
Doesn't bode well for the turbo m3 coming up. You can hate on the S65 V8 but man is it bullet proof in 100 degree track use all day long and that says something to me.
Driving on the roads at 80 and the car is in limp? Imagine on a track this thing will be obliterated
      03-03-2013, 09:57 PM   #105
snowghost
snowghost's Avatar
Dangerous. Serious liability. IIRC the 7s had something similar, around the time of the Bangle Butt.
      03-03-2013, 11:25 PM   #106
ybbiz34
ybbiz34's Avatar
429
6,000 miles.
I'll keep my fingers crossed for you.
      03-04-2013, 12:03 AM   #107
M3takesNYC
Drives: m3
what are you talking about? In the old V8 engine? Not sure what you are bringing up
      03-04-2013, 12:47 AM   #108
fafs
First time Bimmer
fafs's Avatar
Brazil
Drives: 2013 335i EBII M Sport XDrive
Not good news for someone taking delivery of a 335 mSport this week...
      03-04-2013, 07:40 PM   #109
snowghost
snowghost's Avatar
Update
That's frustrating.
BMW engineers told the dealer to road test, check some wiring and see if any more faults. So now they're releasing back to me without anything done for the last limp mode.
I phoned BMWNA and said I'm picking up the car but if it happens again we are going to talk about a replacement.
      03-04-2013, 11:30 PM   #110
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
For the most expensive line this is embarrassing for bmwna.
And what's holding up the bloody PPK!
Ack, would they figure it out already.
SOLD: 2012 335i Mineral Gray
