BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > photo of unmod-ed 335i exhaust spring
      01-01-2013, 07:06 PM   #1
akamomo
akamomo's Avatar
Drives: 335i
I should have taken a picture but trying to find diagram or photo of the spring in place that people take out for the exhaust mod (to put spring back)
THANKS!
      01-01-2013, 07:38 PM   #2
akamomo
akamomo's Avatar
Drives: 335i
I think I have it back correctly...
      01-01-2013, 08:57 PM   #3
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
flip it... you have it wrong. leave the U on top the way it is. just flip horizontally. the side that wraps around goes on the exhaust side.
      01-01-2013, 08:58 PM   #4
UhhItsANT
how did you manage to get the to snap back into place on the motor side. After i removed mine. i look back down there. the groove for the motor and the exhaust never line up.
      01-03-2013, 02:40 PM   #5
akamomo
akamomo's Avatar
Drives: 335i
If you compress the spring so that it is in the exhaust-flap side groove and laying on top of the motor pin (sorry not sure what to call it) - so basically the only thing you are missing is the two to line up - it will be off by what seems like the diameter of the spring or so, very little - then start car. I suppose there is a small movement or the motor is stopped out of place, not sure but starting the car, immediately I could hear the spring snap into place as I'm assuming the motor turned. Not sure how lucky I got but it wasn't that hard to compress the spring up there if you have pliers and are gentle.
      01-03-2013, 02:54 PM   #6
akamomo
akamomo's Avatar
Drives: 335i
Ok thanks.
      01-06-2013, 09:33 PM   #7
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Drives: 2018 Audi S3
Originally Posted by akamomo View Post
Ok thanks.
Just curious why are you putting the spring back in?
FBO-PS1 and stuff
      01-07-2013, 11:59 AM   #8
akamomo
akamomo's Avatar
Drives: 335i
I personally didn't find it to make much of a difference. Maybe I'm crazy.
I didn't feel like having to unclip wire and deal with that if, for instance, my car fails and gets towed in from somewhere. It just wasn't worth dealing with in my mind for the 2% sound increase I might have heard.
Not to knock the mod, its easy enough and makes sense. I just changed my mind after having it that way for a couple of days.
      01-07-2013, 04:49 PM   #9
Jadar
Dejan
Jadar's Avatar
Serbia
1751
I hear you, makes sense. These days BMW does not play with the warranty. They see mods and aftermarket they're quick to void. That's why I chose the BMW exhaust no warranty issues.
FBO-PS1 and stuff
      01-10-2013, 09:48 AM   #10
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
Here's a photo off mine - unmolested
