BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > JB4 Issues and Impressions (F30)?
      01-13-2013, 03:47 AM   #23
Koer
Drives: 335i 2012 luxury line white
Dont touch the intake sensor, from right to left looking from the front of the car,
-first goes the colorful connector into the IMAP sensor on the right side of the engine.
-Then on top of the intake manifold (black plastic on the right side on the top of the engine) lift up the insulation a bit and you will see the connector, in goes the coffee colored connector.
-ignore the purple connector, just strap it in and make sure it isnt in contact with any metal.
-blue soleniod goes on the left side of the engine on the engine wall, you will see it immediately since its the only blue cable on that side.( do not mistake it for the one on the right side of the engine wall attached to the release valve.)
Hope it helps!
      01-13-2013, 05:58 AM   #24
spideypm
Drives: 2013' 335i M Sport
Hope it helps!
Tks!!!!
      01-13-2013, 01:29 PM   #25
Alex@ONEighty
Alex@ONEighty's Avatar
Drives: 2011 E90 M3 CZP 6MT
I also have the JB tune installed on my car. Makes a huge difference I am very satisfied for the price. Highly recommend it
      01-13-2013, 05:25 PM   #26
J-boogey
J-boogey's Avatar
Drives: F30 335xi Msport
just installed the tune, installation went smooth, wish they had better directions on the webiste.. the car is actually fast now, before it was slow as shit. deff get it.
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
      01-13-2013, 06:51 PM   #27
bananachipz
Drives: F30 Mineral Gray 335i
Originally Posted by spideypm View Post
That would be awesome! I also found a 20-sec video clip on YouTube which was just as confusing...
ya.. lol the video is useless... gonna go see if I can film something shortly... stay tuned
      01-13-2013, 07:01 PM   #28
PeterM
Drives: bmw 335i
Nice might have to pick this up soon.
2013 EB2 335i 6MT
      01-13-2013, 07:55 PM   #29
bananachipz
Ok Guys,
Here is a quick video I did showing the connectors. I didn't actually install it (take mine out for the Winter), but this should give you enough confidence.
Remember, this is just informational. I'm not responsible for something happening to your car.
Here's the link to my video on Skydrive. I'll upload it to Youtube and embed it later
http://sdrv.ms/VV0G8r
Hope this helps!
      01-13-2013, 08:29 PM   #30
bananachipz
Here's the Youtube version. Sorry about the low bit rate, my phone compressed it when i uploaded. It should be good enough, but if not, let me know and I'll copy a higher res. version
      01-14-2013, 08:18 AM   #31
spideypm
Life-saver!!!! Try it first thing tomorrow!!!
      01-14-2013, 01:31 PM   #32
bosz
bosz's Avatar
36
Drives: F30 335i Ordered
Wow thanks... That's pretty simple. I think number going to order the JB soon
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
      01-14-2013, 01:33 PM   #33
bosz
bosz's Avatar
36
Bananachipz can you explain the can tool? And where that connects. That's my only worry before ordering the JB,I need to know for sure how to use the can tool. Correctly to remove any codes etc
      01-15-2013, 10:37 AM   #34
spideypm
Originally Posted by TreDirtyFive View Post
the Stg 1 on the F30 only uses 3 of the 4 connectors (or 2 if you do not choose to use the boost solenoid).
Hi, can you please tell mr what the difference is btw using/not using the solenoid? I just installed it today having connected the solenoid and honestly the difference wasn't that noticeably to me. Is it because I have to disconnect the solenoid? The instruction on BMS said to leave it...
      01-15-2013, 10:56 AM   #35
spideypm
My friend ran some reading off his lap top it seems I would momentarily lose the boost after the boost hits around 11 psi.... Is it due to the solenoid?
      01-15-2013, 11:56 AM   #36
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
Terry from BMS told me not to hook up the solenoid plug, just the tmap and map only. Everything has been working great!
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      01-15-2013, 12:17 PM   #37
bananachipz
That's the first I've heard of that.. Did he give you a reason why? I was running mine with it connected fine throughout the summer.
Maybe Mike from N54Tuning can chime in...
      01-15-2013, 12:37 PM   #38
bananachipz
The can tool plugs into the OBD port in the drivers footwell. It's basically a cable with a box on the end (looks similar to the box on the end of the jb), and a single button.
On E9x's the CAN tool works in conjunction with your gauges to show you what you're changing. Unfortunately this doesn't work with F30's, so you kinda fly blind. The good news is apparently it's set to auto-delete by default. So ever few minutes it will delete any hidden codes.
The real problem is that you have to trust that it's working. I just leave mine plugged in.
      01-15-2013, 12:54 PM   #39
NICKTENN
NICKTENN's Avatar
From Terry on n54tech:
New DME versions no longer require it. You are welcome to connect it if your car does not throw codes with it connected. If it does, then you have the newer DME version that needs it disconnected.
      01-15-2013, 01:31 PM   #40
bananachipz
Yep.. just got word from Terry as well:
"For simplicity we've updated the directions indicating all F30s can leave it disconnected now. If you have it connected and its running fine then fine. But the connector will not be used on a go forward basis."
      01-19-2013, 05:52 PM   #41
bulldog x6
bulldog x6's Avatar
45
Drives: '16 MB GLE
I have a stage 1 n55 harness B and usb cable for sale - pm if interested
      01-21-2013, 06:36 AM   #42
2013 335IS
Drives: 2013 335is black on black
Talking 2013 335is
Just purchased this, was wondering if there is a JB4 or any other chip out there for my engine yet? Also is my engine still considered the N54? Thanks.
      01-21-2013, 01:44 PM   #43
tdizzle
Drives: 2017 F80 ZCP
I know the '12 335is was the N54 and assuming the '13 didn't change it should still be. There is more tuning out there for the N54 than N55 right now (obviously since it's been out for longer).
      01-23-2013, 12:58 PM   #44
ratedpg909
BMW/MB Enthusiast
ratedpg909's Avatar
Drives: 2013 BMW M5
Just installed the jb stage1 on my 335i last night. NOTICEABLE difference in comfort and sport mode, got me grinning ear to ear going on empty freeway on ramps.
1999 Black Mercedes CLK430 (traded in 2/2014)
2012 Alpine White BMW 335i F30 (traded in 10/2015)
2014 Matte Grey Mercedes CLA250 (sold 9/2014)
2013 Black Porsche 911 Carrera (RIP 4/2016)
2013 Alpine White BMW M5 F10 (current)
