BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Dealer install or independent mech
European Auto Source
      01-06-2013, 05:38 PM   #1
jamesems
Drives: 2013 335i msport f30
Need some input. I'm havimg the m performance brake and suspension installed on my 335i Msport. Should I do a dealer install or independent mechanic. I have a trusted independent and the price to install is less than 1/2 of the dealer price. I'd still maintain the 2 years parts warranty Any thoughts or suggestions? Mostly concerned about warranty. I have read that the brakes require a coding also.
Thanks
      01-06-2013, 06:25 PM   #2
Jbrock22
Jbrock22's Avatar
81
Drives: 340i
Do you have adaptive? If so please review one the suspension is done. I had the brakes installed at the dealer a software update is needed for the brakes.
      01-06-2013, 07:03 PM   #3
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
*M Performance parts carry the New Vehicle Limited Warranty if they were installed prior to delivery to the client. If the installation is made after the retail sale of the vehicle, the accessory will be warranted for the balance of the New Vehicle Limited Warranty period or two years from its date of installation, whichever is greater.
I'm sure this carries over on extended BMW warranties too...so the extra cost of keeping warranty is worth IMO.
SOLD: 2012 335i Mineral Gray
      01-06-2013, 08:51 PM   #4
bmrm396
Drives: 2016 F80 M3
Originally Posted by jamesems View Post
Need some input. I'm have the m performance brake and suspension installed on my 335i Msport. Should I do a dealer install or independent mechanic. I have a trusted independent and the price to install is less than 1/2 of the dealer price. I'd still maintain the 2 years parts warranty Any thoughts or suggestions? Mostly concerned about warranty. I have read that the brakes require a coding also.
Thanks
yes, please review when the suspension is done. also i see ur in SD, id luv a chance to go for a ride if you had time one weekend. im debating on whether to add this to my order or not. really weighing the ups and downs
Formerly addicted to e46fanatics
Formerly addicted to e90post
      01-07-2013, 12:20 AM   #5
infinitigor
Drives: 13' 335i
Independent shop
Stock... with MPS
      01-07-2013, 12:45 AM   #6
clarence
Drives: F30 328i M-Sport
The M-performance brakes need coding after installation.
      01-07-2013, 03:21 AM   #7
jamesems
I will update when things are installed. Thanks for the advice. I'm leaning toward dealer install because of warranty and coding. Hope I can get a reasonable price. The suspension is due for delivery the 9th so it may be a couple weeks before I can post an update.
      01-07-2013, 04:19 AM   #8
EB_F30
Drives: 13' M Sport 335 6MT
I read before the M performance suspension did not come with the springs needed and you had to order seperate. Was this the case for you?
      01-07-2013, 11:05 AM   #9
nano10
nano10's Avatar
151
Drives: 2018 F80 M3
Where did you order suspension from?
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
      01-07-2013, 11:25 AM   #10
shivaswrath
Drives: 2012 335i
There are two components to the M Perf Suspension:
1. Suspension Kit - struts/bump stops/etc: $1500 or so.
2. Spring Kit - $500 or so.
You need both, as I learned the hard way...
      01-07-2013, 12:00 PM   #11
clarence
Yes, & if the car didn't come with sports suspension from the factory then u'll also need both anti-roll bars.
      01-07-2013, 12:25 PM   #12
jamesems
Suspension kit ordered from Tischer. Gave them my vin and info. I'm sure they'll get it right. They ordered the springs as well. It's scheduled for delivery tomorrow.
I don't have adaptive. Figured I'd be lowering the car and didn't want to hassle with electric dampening. The ride is pretty cozy as it is for me. I think I can stand the increased stiffness from this kit just fine. Should get rid of some body roll and lower the car 10mm.
