BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 Ride Comfort with 19" Wheels & RFT
      01-07-2013, 07:10 PM   #1
MotoEV
MotoEV's Avatar
Drives: BMW Active Hybrid 3
Looking to purchase a 19" summer tire package with a wheel slightly larger than the current 18" wheel and a tire with a bit more depth and bite in the corners.
My F30 Active Hybrid 3 has the 'standard' suspension and looking for ride characteristics similar to the E90 335i. Any recommendations on an OEM wheel and tire set?
      01-07-2013, 08:46 PM   #2
TreDirtyFive
Drives: 335i Coupe
with the current soft-monger boaty boat-king suspension it will still feel soft. I'm on 19's with stock M-SPort suspension and it's still wallows around like a banana mobile. My stock 135i felt like a lambo compared to this thing.
M235i F22: Prem.Tech.+
335 F30 MSport: Prem.Tech.NAV.+
X-135 DCT:N55.Prem.Sport.+
X-335 E92: Prem.Sport.+
Audi A3: FBO.
      01-07-2013, 09:04 PM   #3
jtuds
Drives: 335rwd Dinan S2
What could it have been like before if it is so bad now?
      01-07-2013, 09:06 PM   #4
Mak135i
Drives: ATS-V
+1000
Gone but not forgotten: 2008 BMW135i Vert
Gone but not forgotten: 2011 MB C63 AMG
Gone but not forgotten: 2011 BMW z4 3.5is
Gone: 335i
Added: 2015 Z4 3.5i
      01-07-2013, 09:47 PM   #5
PK2348
Drives: 2015 F30 335 xdrive M-Sport
imagine 328xi
      01-07-2013, 10:35 PM   #6
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
Originally Posted by Mak135i View Post
+1000
+1000 again on that!
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      01-07-2013, 11:25 PM   #7
TreDirtyFive
Drives: 335i Coupe
obviously I'm over-exaggerating a bit but if you get to do a relative comparison to any E9x you'll notice how much more taut the steering and suspension is. Yes, the F30 chasis is more rigid, perhaps, but they have softened things up so much it is not that apparent over normal driving.
In my F30, I float and bounce over the same bumps on the way home from work where my older E9x and E8x took those bumps with aplomb and comfort yet still felt sporty and tight. It's too bad, really. I understand the need to cater to the old Gen-Xer's, who continue to be loyal and who are much older now, but it really does push away those who who began buying these cars in the late 90's and are used to the sporty and no-compromise driving feel.
Funny thing is, I actually do have friends who are now older and are happy that the new 3er's are bigger and softer as they now have kids and aren't as inherent to do too much spirited driving anymore. It is what it is I guess...I say it sucks.
Audi A3: FBO.
      01-08-2013, 12:42 AM   #8
buildbright
buildbright's Avatar
115
Drives: F80 M3 MG
I can only tell you I have 19" avant garde M310's on Continental DWS's. On the adaptive suspension it is super smooth in comfort mode. In sport plus it is stiff. I hear so many complain about the F30 suspension except those with DHP. Guess that is a option people wanting a stiffer suspension should have checked. That or put on the M Performance Suspension.
      01-08-2013, 01:20 AM   #9
steveL77
Drives: 2013 335i M-Sport
I'm on 19's with msport and in comfort mode it's like you're riding on 17's with high profile tires. Living on Long Island our roads are terrible and I was worried about bumps and such but it is very comfortable. In sport mode it stiffens up a bit and is still pretty good over bumpy roads. I would really like it to be a little stiffer but it still handles very well.
      01-08-2013, 04:38 PM   #10
TreDirtyFive
Drives: 335i Coupe
Do you have DHP? Most don't have DHP and Sport mode does "nothing" to the suspension...it only sharpens throttle, holds gears longer, and unnaturally tightens steering so that it feels more on-center.
Audi A3: FBO.
      01-08-2013, 05:22 PM   #11
sean10mm
sean10mm's Avatar
Drives: '13 335i xDrive 6MT ZDH
Don't people do test drives? How do you not know that the base suspension is soft before you buy the car? If you want to corner and you don't spring for a line with the sport suspension or DHP and spec summer tires you have nobody to blame but yourself.
Worse ride doesn't mean better handling necessarily, by the way. F30 328i sport line on all-season run flats puts up the same acceleration and lateral g numbers as the E46 330i ZHP on staggered summer tires that everyone jerks off to around here.
      01-08-2013, 05:44 PM   #12
MotoEV
MotoEV's Avatar
Reply to sean10mm...
  1. Having a bad day? No one to talk to at home?
  2. The question was about a larger wheel and tire on a standard suspension for asthetics, ride quality, and tire grip.
  3. Thanks for a worthless, self-serving comment that adds little value but highlights your 'shortcomings'
Wheel diameter, tire depth, sidewall height, and rubber compound impact ride quality. If you are intellectually bankrupt on these factors, take a hike.
      01-08-2013, 09:46 PM   #13
G3333
AH0S
G3333's Avatar
Drives: F80 M3
looking for a custom 1m bumper?
F80 M3 | Velos, Meisterschaft, RKP, iND
F82 M4 | ER, JB4, Vorsteiner, Akrapovic, iND SOLD
E92 M3 | ESS, Vorsteiner, HRE, iPe Innotech, KW, iND SOLD
F30 335i | Adv.1, KW, Vorsteiner, iND, Meisterschaft SOLD
F30 335i | Slek, Meisterschaft, KWH&R, MORR SOLD
      02-17-2013, 01:13 AM   #14
f1rst 1
f1rst 1's Avatar
Drives: '09 Cayman S
Thinking of M310s for my EB 335i xDrive when it gets here, do you have pics of your car/wheels?
Current: 2009 Cayman S
Former:
2013 BMW 335i XDrive M Sport 6spd:::::Cobb Tuned '09 135i
      02-17-2013, 01:48 AM   #15
's Avatar
73
Drives: ✚
Haha. Best response ever.
Anyhow, to answer your question... the 19's with lower profile tires (especially RTFs) will make you hit bumps harder. But if you're looking for the panted feel that an E90 M-Sport has, then you need to change the suspension on the F30. Tires will give you more grip but won't help too much in the body roll department.
      02-17-2013, 02:18 AM   #16
buildbright
115
Drives: F80 M3 MG
Yes I can take some for you. Just PM me and I will hook you up.
