BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > Car wash
Extreme Power House
      01-10-2013, 11:55 PM   #1
bonedoc98
Drives: f30 328 sport (soon)
Car wash
Wanted to have suggestions for car washes in the winter. I usually hand wash in the summer. Was looking at the petro Canada season pass but the one close to me (don mills) is soft cloth. Probably not a good idea? (Although the vehicle is leased...). Thoughts?
      01-11-2013, 12:22 AM   #2
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
i usually go to coin washes
best bang for the buck
      01-11-2013, 01:09 AM   #3
Temptazn
Drives: 2013 328i xDrive
Hand wash or Touch less from Esso on the days I feel lazy.
2013 328i BSM xDrive Sport/ Black Dakota Leather/ Brushed Aluminum/ Prem Pkg/ Exec Pkg/ 8 spd
      01-11-2013, 11:59 AM   #4
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
I find that the Esso ones never dry your car properly and you'll end up with lots of water marks in the end.
Best way to wash your car is by hand. Sometimes if it's too cold, I'll just wash it in the garage.
      01-11-2013, 08:11 PM   #5
CHCCubs
CHCCubs's Avatar
Latvia
82
Drives: 2013 BMW 328i xDrive Sport
I generally hand wash in the warmer months, but in the winter usually use touchless carwashes. I've found Esso and Canadian Tire generally have pretty good touchless washes (at least the locations I frequent in North York and Scarborough)
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
      01-11-2013, 11:13 PM   #6
Shep1
Drives: 335i msport;135i m convertible
I go to coin operated hand spray washes but I don't use the soap or the brush. I just put it on rinse mode to blast away the muck. After I blast all the muck off, I wash it at home in my garage with Optimim No Rinse car wash. Here is a thread about this:
http://www.f30post.com/forums/showthread.php?t=786764
And here is where you can order it as well as other detailing supplies:
http://www.eshine.ca/
      01-11-2013, 11:48 PM   #7
Photoman
Photoman's Avatar
Drives: 2012 F30
2012 BMW 328i  [5.00]
THIS!!!
2012 F30 | IB | SB | ///M-Sport Front | ///MPE | ///M3 Lip Spoiler
| /// 437M OEM Wheels| H&R Springs | Custom Sport Grills | CQuartz
Pics here: http://f30.bimmerpost.com/forums/sho...=703355&page=8
      01-12-2013, 08:39 PM   #8
bonedoc98
great suggestions. now i am really intrigued by ONR. i think i will order!
      01-14-2013, 12:47 AM   #9
WonderWoman
WonderWoman's Avatar
Drives: BMW 328XI MW F3O
The Esso touch less washes aren't bad. Gets pricey though, especially if you have a white car. You're better off getting a seasons pass if you're the type to always want it clean.
      01-14-2013, 09:04 AM   #10
bonedoc98
i know what you're saying wonder woman! it does get pricey at 11.99 a pop! i really want to get a seasons pass, but the close ones we have here are all soft cloth!
      01-14-2013, 09:55 AM   #11
jtuds
Drives: 335rwd Dinan S2
I think this is the safest bet. If you can live with just spraying off the most visible dirt during the winter, go to the coin op place and use their presure washer.
The other option if you want the whole treatment is to go to a true touchless place wherer you don't even put a wheel in the track....the ones where you just drive in and stop. The only danger with those is that they recycle the water. It is filtered, but still...
If you want to avoid swirl marks, never apply a product to the car if it isn't totally clean. So don't use any quick detailer in the garage. And in all cases, avoid scrubbing to get things off, and avoid circular motions.
      02-08-2013, 03:51 PM   #12
335BBS
Drives: 2009 335 coupe.
Except you dont get under the car the way a regular wash would. I trust you don't use those brushes or dry car after?
      02-08-2013, 03:54 PM   #13
335BBS
Yikes. Hello swirl................
      02-08-2013, 08:47 PM   #14
SPACEMANRICK
Drives: 2016 M3 6 speed manual
I ordered some Optimum No Rinse for myself for Christmas and used it twice and have decided to go back to just use the regular water wash with Meguiars Gold Class car wash. I found that the amount of time and effort required to spray down, soak, and wipe off the ONR was just too much compared to using a hose and regular car wash. With the ONR it took about 40 minutes and with the regular water wash it takes about 30 minutes.
Also if the car is really dirty if you are going to rinse it off before you use the ONR you are half way through the amount of work required to do a regular water wash anyways. I also found with the ONR that unless I really soaked my black car down there would be some spots of residual hazing. Keep in mind I am in Vancouver and it rarely gets below freezing so if I was in Toronto or Edmonton I would think using the ONR would be a greater advantage.....
One last thing, I ordered 2 grit guards for a 2 bucket wash system with the ONR. These are a must have for any kind of car wash product to help prevent scratching your paint job.....
http://www.eshine.ca/grit_guard_buck...xmas.php?cat=9
Anyone from Vancouver that wants a nearly full 32oz bottle of ONR for cheap let me know........
      02-09-2013, 02:54 AM   #15
Chris@codemybimmer
Sometimes I bring my battery powered leaf blower and air dry the car if im in a rush
If not I usually drive straight home so I can microfiber cloth it dry and detail it straight after
      02-09-2013, 08:45 AM   #16
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
Yeah, I find this a lot. Especially on the f30 rear. It just looks horrible if pass through the dryer and drive away.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
