BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Torque Pro App
      01-22-2013, 04:48 PM   #1
mikew2069
mikew2069's Avatar
58
Drives: F30 335i MSport
Torque Pro App
Is anyone using this on their F30? I had it on a previous car and it was pretty cool. I first bought it to clear the CEL that would come on every once and a while from the cat delete but then started using it for other stuff once I learned what it could do.
I'm mostly curious if the code clearing function is the same as BMS's CAN tool. Does anyone know if the code clearing on the Torque app would clear 'hidden' codes resulting from something like the JB Stage 1 piggy back?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      01-22-2013, 06:30 PM   #2
buildbright
buildbright's Avatar
92
Drives: F80 M3 MG
I would like to know as well. The JB4 can bus is expensive.
      01-22-2013, 08:03 PM   #3
bosz
bosz's Avatar
36
Drives: F30 335i Ordered
wow this is awesome! 0-60 timer, boost gauge and everything, all through the OBD2 port WIRELESSLY! Just ordered the bluetooth OBD2 reader off ebay
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
      01-22-2013, 08:04 PM   #4
bosz
bosz's Avatar
36
boost gauge
      01-22-2013, 10:06 PM   #5
mikew2069
mikew2069's Avatar
58
Yup. Cool app with cool features but what about the code clearing? Anyone?
      01-23-2013, 04:32 AM   #6
bavarianf30
bavarianf30's Avatar
Drives: 335i 14 s1000rr 17
What's the name of the app? Is it available for apple?
      01-23-2013, 08:54 AM   #7
mikew2069
mikew2069's Avatar
58
Sorry, got to hit you with the ------>
It's the Torque Pro App. Not sure about iOS but I would guess it is? You can googe it.
      04-03-2013, 09:33 PM   #8
n54door
Drives: 09' 135i 6AT FBO - MHD Tuned
Im looking at this app. It looks like you can do logging, anyone know?
      04-03-2013, 11:44 PM   #9
GET A GUN
Drives: 2013 335i F30
Don't think this app will work if your running JB4 in the car.
Sweet though.
2013 335i F30 N55
      04-04-2013, 07:44 AM   #10
mikew2069
mikew2069's Avatar
58
I do use it with my JB4. Only problem is the boost readout isn't accurate b/c it gets it from the DME which is fooled by the JB. But code clearing, logging and a bunch of other features work great still.
      04-04-2013, 11:22 PM   #11
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Did not know about something like this. Can BMW deny any sort of warranty work if they come to know you plugged in an obd ii scanner into the port?
      04-05-2013, 02:19 AM   #12
Rustyboy155
Rustyboy155's Avatar
Drives: BMW M2 LCI
Lol, why on earth would plugging in a data logger void your warranty. I understand all the warranty worriers coming out of the woodwork for chips and suspension mods, but an android app?!?
Old: '06 Cooper S w/RMW 2.0L Stroker | '13 BMW 335i 6mt | '11 BMW M3 ZCP | '09 Porsche Boxster (FS)
New: '18 ///M2 LCI | '17 X1 xDrive | '17 Bolt EV Premier
      04-05-2013, 02:22 AM   #13
Rustyboy155
Drives: BMW M2 LCI
I used this app on my GTI and it worked great. Didn't track that many parameters though. I suspect it will read a lot more on our cars. It does reset codes, but I have no idea about "hidden tuner codes".
      04-05-2013, 02:53 AM   #14
rallybull
rallybull's Avatar
Because I'm not sure if this tool is a read-only tool. Can this not be used to write into the car? Such as clearing codes?
      04-05-2013, 12:46 PM   #15
Rustyboy155
Drives: BMW M2 LCI
Deleting codes on your car doesn't affect warranty. You're allowed to do your own work on the car/ have an Indy shop work on it without affecting the warranty. Nothing you do to your car can blanket void anything. The burden of proof is on BMW to explain why clearing a code on your car with a widely used obdII reader caused your adaptive suspension to fail. There's also absolutely no way they would ever know. You pull the obd II dongle out when you're not using it and that's it. Unless you walked in and told them they would have no clue.
      04-05-2013, 04:39 PM   #16
rallybull
rallybull's Avatar
I don't need it but I think I will try it out..just for kicks !! unfortunately it does not look that torque pro is available for iOS, though there are a few other similar apps, not sure if they are as good as torque pro.
Which OBD ii bluetooth adapter are you using?
      04-05-2013, 06:45 PM   #17
mikew2069
mikew2069's Avatar
58
I just bought a cheap one on ebay for $20ish
