BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Thoughts on fitment?
      01-26-2013, 01:43 PM   #1
TN_3
TN_3's Avatar
Drives: 2016 M3 F80
F30 335i M-Sport
Breyton GTS
Front 19x8.5 ET 30mm 235/35-19
Rear 19x9.5 ET 35mm 265/30-19
Tirerack doesnt list this fitment for the F30 (they suggest 19x8.5 all around) but do you guys see any issue with this setup? I'm a little worried about the 35 offset on those rears...
2016 M3 F80 l SSII l SO l CF l EXEC l LED l DCT l BLK 19 l ADAPT M l MPE (PCD 4/1/16)
2017 X5 xDrive35d F15 l GS l BLACK l ALUM HEX l M-SPORT l PREM l CW l DA l LED l HK l ADAPT M l BLACK 20"
      01-26-2013, 05:56 PM   #2
's Avatar
73
Drives: ✚
35mm on a 9.5 is pretty agro. But I would love to see these wheels on a lowered F30.
      01-26-2013, 06:24 PM   #3
bmwluvr24
Driving Mika all over California.....
bmwluvr24's Avatar
Drives: 2008 E60 M5
I just got my Stance SC-5ive installed today and they are the EXACT same dimensions. They look perfect with zero chance of rubbing. I do need to put the sport springs on when the weather starts to get better.
2008 E60 M5 Sepang Bronze Metallic, gloss black grills and gills, LED side markers, 12mm spacers all around, stud conversion kit, custom exhaust with Magnaflow mufflers and x-pipe.
      02-02-2013, 03:32 PM   #4
TN_3
TN_3's Avatar
Drives: 2016 M3 F80
How do you think this fitment would work if I bumped the tire sizes to
245/35
275/30
These are closer to the stock diameters, but I'm afraid the wider rears might rub...
      02-02-2013, 04:08 PM   #5
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
245/35
275/30
Well with the same offset, mine are clear, but anything wider would be pushing the limit. In fact, I am sure the rear fenders would have to be rolled if you were planning on dropping it at all.
      02-02-2013, 05:26 PM   #6
TN_3
TN_3's Avatar
Drives: 2016 M3 F80
you have 245/35 275/30 with same offset on stock suspension and it doesnt rub?
      02-02-2013, 09:28 PM   #7
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
No........I am running 235/35-19 front and 265/30-19 rear with 30 offset front and 35 rear. They are about as close as I would ever consider without rolling the fenders.
      02-04-2013, 03:29 AM   #8
KITT
Singapore
Drives: Black KITT F30 328i
Your tires ZP or non-ZP?
      02-04-2013, 12:44 PM   #9
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
My tires are Hankook V12 Z rated, but I don't know what ZP stands for.
      02-04-2013, 11:50 PM   #10
Buzzman
Drives: 2016 F26 M40i
ZP = Zero Pressure = Run Flat. I know this is what Michelin uses to designate their run flat series.
2016 F26 Alpine White M40i
2014 F25 Alpine White 35i Sport - Retired
2012 F30 Melbourne Red 335i Sport Line - Retired
2007 E92 Space Grey - Retired
      02-05-2013, 01:05 AM   #11
bmwluvr24
bmwluvr24's Avatar
Drives: 2008 E60 M5
Ok gotcha......they are non ZP then. Just normal Hankook Ventus V12s.
