BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > New Software Update UPD05004 for NBT!
      01-29-2013, 02:10 PM   #1
jdong
Drives: 2013 BMW ActiveHybrid 3
http://www.bmw.com/com/en/owners/nav...update_vin.jsp
Put in my AH3's VIN and got an update for it:
Software update (MN-1.23.4, TN-1.23.2)
Content
> Telephone: Improved Bluetooth connection stability. Improved transfer of contact data of the rear-seat telephone. Improved call lists in China.
> Multimedia: Improved performance with video display lists with iPOD devices. Improved music playback and stability with iPOD devices and large USB devices.
Supported devices
The software update improves the compatibil- ity of the following devices:
Multimedia
> All USB devices
> Apple: iPod touch, iPhone 3GS, 4, 4S, 5 (iOS 6)
Phone
> Apple: iPhone
> Nokia: All devices (use in China)
> Samsung: All devices
> Rear-seat telephone
      01-29-2013, 03:01 PM   #2
jdong
If anyone is a *nix software geek, check out what kind of file the update .bin is, and what's inside.
Out of respect for BMW and the software license agreement I won't say much more than that, but the payload of the update is pretty easily inspectable, and makes me like this nav system even more.
I will say it's definitely an Intel x86 architecture.
      01-29-2013, 03:04 PM   #3
SamS
SamS's Avatar
Drives: 2016 M3
Nice find! I will update later tonight.
Can some remind me, what formatting needs to be used for the USB stick?
You sure you can't tell us more about what's in the bin? Maybe PM me?
2018 X3 M40i - on order
2016 M3 - sold
2013 ActiveHybrid 3 - sold
2012 M3 coupe - sold
      01-30-2013, 03:14 AM   #4
SuriF30
SuriF30's Avatar
Czech_Republic
Drives: BMW F30
How?
How do you upgrade it? I have downloaded *.bin to root of my flashdisk, but it does not regignise it in centre usb. And I dont have any USB port in glovebox ????
      01-30-2013, 03:25 AM   #5
ducatiboy72
Norway
Drives: F31 M-Sport
I downloaded and upgraded the software yesterday. I put the bin file in the root directory of the BMW USB stick I got when I purchased the car and inserted it into the USB port under the arm rest.
I also used tar and rpm2cpio to extract the contents of the update. The update contains changes to bluetooth and the mediaserver components. And yes, they are i386:
[root@arthur bin]# file Connectivity
Connectivity: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), not stripped
      01-30-2013, 03:36 AM   #6
Haarschmerzen
Drives: 320i xdrive
Is this update for the new navi only? Can someone tell me if there are any features or bugfixes that are not available in the old navi? Whats about emails sms?
      01-30-2013, 04:47 AM   #7
JonoNZ
New Zealand
20
Drives: F30 335i M Sport, M Perf
Thanks for the heads-up. I wish you could register and get an email when these are posted.
Anyway, installed now and no issues so far -- haven't noticed anything new but hopefully the bluetooth internet tethering in BMW Live is a bit more reliable.
F30 335i M-Sport with Estoril Blue II, M Performance Aero Kit, M Performance Exhaust, M Performance PPK, Adaptive Suspension, Variable Sport Steering, Revised NBT Pro Nav, Sunroof, 19" 403M, HUD, Rear Camera, DAB+, Comfort Access (20121250 Build, Delivered 25 January 2013)
      01-30-2013, 07:18 AM   #8
ducatiboy72
Norway
Drives: F31 M-Sport
Got the chance to test my car today and they have certainly fixed some problems with iPhone connectivity via USB that I had before.
If you are wondering what's in the bin file, here is a listing of all the filenames:
/fs/sda0/repository/SWUP_000014B0_001_023_004
/fs/sda0/repository/SWUP_000014B0_001_023_004/info
/fs/sda0/repository/SWUP_000014B0_001_023_004/info/manifest_SWUP_000014B0_001_023_004.xml
/fs/sda0/repository/SWUP_000014B0_001_023_004/info/manifest_SWUP_000014B0_001_023_004.xml.sign
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/bin
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/bin/MediaPreStarter
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/bin/NBTMediaEjectRetractApp
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/bin/PrepareMedia
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/bin/persistTraceNBTMediaMainApp.bin
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/bin/zipped
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/bin/zipped/NBTMediaMainApp
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/mme.conf
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/mme_without_gracenote.conf
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/mmlauncher_B069.cfg
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/mmlauncher_B069_without_gracenote.cfg
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/mmlauncher_B075.cfg
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/sql
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/sql/mme_custom.sql
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/update
/fs/sda0/repository/SWUP_000014B0_001_023_004/opt/mm/etc/update/mm_custom_migration.sh
/fs/sda0/repository/SWUP_000014B1_001_023_002
/fs/sda0/repository/SWUP_000014B1_001_023_002/info
/fs/sda0/repository/SWUP_000014B1_001_023_002/info/manifest_SWUP_000014B1_001_023_002.xml
/fs/sda0/repository/SWUP_000014B1_001_023_002/info/manifest_SWUP_000014B1_001_023_002.xml.sign
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/bin
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/bin/ConnStarter
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/bin/Connectivity
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/data
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/data/ConfigGen_Options.ini
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/data/label.txt
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/data/persistTraceConnStarter.bin
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/data/persistTraceConnectivity.bin
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/etc
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/etc/FwImage
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/etc/FwImage/sd8688_ap.bin
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/lib
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/lib/libmediaservice.so
/fs/sda0/repository/SWUP_000014B1_001_023_002/opt/conn/lib/libpal_bt.so
      01-30-2013, 09:41 AM   #9
SamS
SamS's Avatar
Drives: 2016 M3
New Nav only. No email notification, i.e. behavior with iPhone is the same as older Nav.
Here are the release notes: http://www.bmw.com/_common/shared/ow...D05004_ENG.pdf
I did the updated (you need FAT32 formatted USB), and notice slightly improved times for Bluetooth phone pairing with the car. No other noticeable improvements, but I wasn't having any problems to begin with.
Still no ability to have streaming app audio override iPod playback when iPhone is connected via USB. If you've started iPhone/iPod playback, you'll need to disconnect the Lightning cable, then reconnect, then launch your app (Spotify, Live365, etc). Not too much of an inconvenience. Everything is now working to my satisfaction.
2016 M3 - sold
      01-30-2013, 09:45 AM   #10
SamS
SamS's Avatar
Drives: 2016 M3
i386 is super old, how did they even clock it to 1.3Ghz per the press release specs on the NBT?
2016 M3 - sold
      01-30-2013, 12:21 PM   #11
ducatiboy72
Norway
Drives: F31 M-Sport
It is not a old i386 CPU, it uses a CPU with the i386 CPU architecture, eg a i386 compatible CPU. Just as all new PCs are i386 compatible.
      01-30-2013, 02:06 PM   #12
jdong
i386 is just the RPM's architecture. ELF binaries don't mark the variant of x86 any more detailed than that either. Since the OS running on it is not exactly Linux, I expect they just picked i386 arbitrarily for their RPM architecture.
      02-02-2013, 12:07 PM   #13
Travel4surf
Travel4surf's Avatar
Drives: code F10
Glad to see someone got it working.
We are getting install errors on the 2013 F10's trying to install this update.
      02-02-2013, 02:41 PM   #14
JonoNZ
New Zealand
20
After a few days of usin the updated version it seems like Bluetooth internet tethering via the iPhone is much more reliable, in fact no failures since the update.
      02-02-2013, 02:50 PM   #15
jdong
You can tether the iPhone to the car? Is this a feature not available in the US?
      02-02-2013, 03:44 PM   #16
JonoNZ
New Zealand
20
Yes, the Internet browser and BMW Live (weather, news, etc) use the iPhones data connection.
      02-02-2013, 04:45 PM   #17
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
Anybody have their VIN rejected? I've downloaded 2 updates in the past and now it says "invalid VIN".
F30 Sapphire Black 335i 6MT|2PE|4AB|LCSW|ZDH|ZMM|ZPP|ZCW|ZDA|ZDB|ZTP|5AC|4 15|688|Dinan Stage 1 Suspension and Shockware ECU tune
Previously - F30 335i, E46 M3, E39 530i, E46 325i
      02-02-2013, 04:47 PM   #18
matt_435xi
matt_435xi's Avatar
Drives: F36 435xi M-Sport
Send a message via AIM to matt_435xi
same with me.
'15 435xi GC Glacier Silver w/coral red leather & ash wood trim/ZM2/ZDA/ZLP/ZPP/ZTP/park assist/HK sound/hot seats/27% tints/DINAN stage 1/DINAN exhaust/carbon fiber side mirrors/carbon fiber rear spoiler/19" e46 M3 CSL wheels
*RETIRED* 2012 335i [f30] | 2009 z4 35i [e89] | 2007 335i coupe [e92] | 2001 325Ci [e46] *RETIRED*
      02-03-2013, 12:30 AM   #19
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
DITTO bad vin.. but my car was recently updated per s recall at the delaer just last month. I wonder if that has something to do with it.
M Sport Line Estoril Blue
      02-03-2013, 12:22 PM   #20
arnsbrae
arnsbrae's Avatar
Drives: BMW 520d
The Browser and BMW Live use the SIM in the car here...
August 2012 F10 520d SE sport automatic, Jet Black, Oyster\Black Leather, light ash wood trim, Professional media/ navigation, mobile apps, Internet, DAB radio.
      02-04-2013, 10:26 PM   #21
Travel4surf
Drives: code F10
The BMW VIN sql server was down over the weekend..
It is back-up, try again.
      02-04-2013, 10:56 PM   #22
john08135i
john08135i's Avatar
Worked now..thanks
