BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Steering Rack Issue Poll
European Auto Source
View Poll Results: Does your F30 have the steering rack noise/issue?
Yes :-( 76 60.32%
No :-) 50 39.68%
Voters: 126. You may not vote on this poll
      04-24-2017, 05:25 PM   #155
adge7
adge7's Avatar
Australia
Drives: F30 330i MSport
Originally Posted by Sherweeeny View Post
Originally Posted by adge7 View Post
You read my reply about three years late, and as a result, you missed both the sarcasm and the fact that my previous F30 exhibited the steering rack issue not once, but twice.
I'll overlook your snarky reply, mate.
Well you didnt do a very good job at expressing your sarcasm now did you?
and yeah im not on here near as much enough as I should be, so expect some delays with responses
My sarcasm was both perfectly structured and contextual. It merely required a continual reading of the text. 36 month delay is on you.
      04-25-2017, 08:24 AM   #156
Sherweeeny
New kid on the block
Sherweeeny's Avatar
Australia
Drives: 340i
how about we agree to disagree and you can refrain from being tooshy
      04-28-2017, 06:26 AM   #157
frackje
frackje's Avatar
Belgium
30
Drives: AH3
My car has the clunk/knocking noise in the steering. Took it to the dealer: Steering rack. They quoted 2500$.
Hopefully it can be repaired under warranty (still have 14 months). They will confirm later today.
      07-09-2017, 08:56 AM   #158
gee38l
Australia
Drives: 2012 320D Modern Line
Just in case anyone still has this issue and out of warranty, worth a try?
http://www.bimmerfest.com/forums/sho...d.php?t=908819
      07-12-2017, 07:03 PM   #159
turo329
Drives: 2012 BMW 335i Sportline
After 2 visits and no results finally had my rack replaced. 7/12 build. Fortunately the car is CPO and it was covered. Went in this time for a different reason. Since it was in there I figured I would see if someone could figure out the clunking noise.Drivetrain malfunction is why I went in. It was the Vavltronic Eccentric Shaft Position Sensor. Had to pull off valve cover. All under warranty thankfully. All and all Service Advisor said it would have been roughly $9k out of warranty. Car only has 43k miles by the way.
      07-12-2017, 07:42 PM   #160
scostu
Drives: 2014 F31
YIkes!
Wife's ride....2016 Dodge WD R/T
Retired:2013 Audi Q5 3.0T,
2013 Jeep WK2..Hemi, 2011 E90, 2008 E70, 2004 E46
      08-17-2017, 03:30 PM   #161
D041987
Drives: 2012 328I 6speed
Time to swap my springs to stock, take off the cold air intake and remove the wheel spacers. I got a turbo rattle now so want them to replace the turbo and also got the steering rack noise. Verified it is coming from the driver side steering rack location. All other suspension components are tight with no play. I even check the inner tie rods as I thought this could be a quick fix but those have no play so it is indeed something inside the rack itself. After further looking up this issue seems like this is a common with any BMW that is equipped with electric steering.
Can anyone confirm that the new rack and or steering shaft you receive today fixes this issue for good?
      09-24-2017, 07:07 AM   #162
juld0zer
Drives: E82 135i 7DCT
My rack was replaced about 5k ago and is still going okay. I have now developed a supercharger whine that is directly correlated with engine speed (anyone that's had a recent Audi turbo will know this whine well)- to which they reckon is normal...
That is your oil pump chain drive module. The oil pump chain gets stiff and/or the oil pump sprocket teeth have wear marks from the chain. You will hear it between 1300 - 2200rpm roughly, in gear and revving it in neutral/park.
For the rack issue, there have so many revisions it's really concerning.
Another test is to drive into a driveway at an angle. In Australia, it will occur on the driver side.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
