BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Burger Stage 1 N55 installed!!!
      03-05-2013, 07:11 PM   #45
4DRS55
Drives: GT F80, E39 M5, F15 X5
Originally Posted by tdizzle View Post
Only way they could tell (that I can think of) is: 1) You left it on and they just happened to open up where you 'hid' it or 2) they checked the logs and saw abnormal boost levels.
With a flash tuner, if you returned it to stock, they could look for elevated boost levels (I presume they can do this) and see how many times the car has been flashed which would throw up a warning if it was higher than expected.
thank you
      03-08-2013, 06:38 AM   #46
Alexzander23
Alexzander23's Avatar
Puerto Rico
Drives: 2013 335i SPORT
WoW!!! That is all I can say....Just installed the Burger Stage 1 N55 and right out the bat I felt the diffrence...it is worth it and the best thing no issues so far, no check engine light no problems starting or anything. Hope it stays like that...but if you are debating on pulling the trigger....DO IT!!!
Delivered - 2013 F30 335i Jet Black Sport----MODS: Painted reflectors, H&R Springs, M Performance Grills, Matte Black 335i, 'NO HOLES' License Plate Bracket, Painted Key hole cover, BMW M Performance Spoiler...
      03-19-2013, 10:32 AM   #47
pnosker
ti fan
22
Drives: 2008 135i | 2008 535xiT
If anyone was interested-- M Sport 2013 335i with M Performance Exhaust in 14 F temperature, stock runflat summer tires
No tune: 0-60 5.0 sec
JB4 Stage 1: 0-60 4.7 sec
JB4 Stage 2: 0-60 4.4 sec
I tried several launches and the fastest was just putting it in drive and stepping on the gas. The traction was very low that day.
All times measured on a Passport GT1 G-Timer which I've used on my 135i at the strip and was within 2-3% accurate in the 1/4 mile in both MPH and time.
I will try again with no tune and Stage 2 when it gets warmer out.
      03-19-2013, 10:47 AM   #48
tdizzle
Drives: 2017 F80 ZCP
Wow, I really didn't expect a noticeable difference in stage 1 and stage 2. That's pretty huge given the dyno curves looked almost identical with no other mods.
I'll be putting my stage 1 on shortly and will be doing a similar test. Although, mine wont be as scientific as yours. I did the ole video then electronic stop watch method multiple times. I got 5.1 on my stock 0-60 using that archaic method, but I did it on a slight up hill and could've launched better, but I was worried about randoms driving by wondering what I was doing lol
How was the stage 2 install? Is it just installing a couple wires to the CAN? My concern with that was 1) I didnt expect much of a difference between stage 1 and stage 2 without at least DPs and 2) having to tie into wiring would leave at least questions when going in to the dealer even if you uninstalled it.
      03-19-2013, 11:06 AM   #49
SwnSng
Drives: 335i MSport - 6MT - GS
4.4 sounds very very suspicious, not saying you are BSing us but that seems awfully low for Stage 2 w/o a downpipe...even with one it sounds too good.
      03-19-2013, 11:06 AM   #50
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
2014 Audi SQ5  [0.00]
Nice!
      03-19-2013, 11:11 AM   #51
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
14 degrees Fahrenheit???
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      03-20-2013, 03:23 PM   #52
Bowser330
Drives: i3 REX
N54 335i's have been vbox documented getting 3.5 sec 0-60 with tune, dp, and drag radials....I don't think 4.4 is suspicious at all...
      03-20-2013, 03:25 PM   #53
tdizzle
Say whaaatttt?? That's like supercar all wheel drive times.
      03-20-2013, 04:30 PM   #54
Bowser330
Drives: i3 REX
I have to correct myself on that, 3.9 seconds not 3.5 seconds....
      03-20-2013, 05:16 PM   #55
tdizzle
Crazy quick. Said "only" a 12.4 quarter at 112?
      03-20-2013, 07:42 PM   #56
NICKTENN
NICKTENN's Avatar
Anyone running +4 psi w/93 octane on Stage 1? Thinking about making this change tonight for fun.
      03-20-2013, 07:47 PM   #57
tdizzle
Didn't think Stage 1 was customizable. Thought the fun stuff like that was reserved for stage 2?
      03-20-2013, 07:51 PM   #58
NICKTENN
NICKTENN's Avatar
I'll let you know shortly, Terry approved it for the 328i crowd on n54tech.
      03-20-2013, 07:58 PM   #59
mikew2069
mikew2069's Avatar
64
Drives: F30 335i MSport
Interesting. When I had stage 1 he said I couldn't change it even with my dp and 93. Let us know!
      03-20-2013, 07:59 PM   #60
NICKTENN
NICKTENN's Avatar
It was easy enough to change, but I don't have time to go driving right now. I'll report back in a day or two and let you know if I notice any difference.
      03-20-2013, 08:20 PM   #61
NICKTENN
NICKTENN's Avatar
Here's where he said it:
      03-20-2013, 08:27 PM   #62
tdizzle
How'd you change it?
      03-20-2013, 08:34 PM   #63
NICKTENN
NICKTENN's Avatar
Once you have Stage 1 installed and the Stage 1 interface on your computer, you just connect to the JB3 box with the USB cable. In the pic below, where the 3.5 is, I simply updated it to 4 and saved it. Only took a couple seconds.
      03-20-2013, 08:41 PM   #64
tdizzle
I thought only stage 2 could be changed. I bought stage 1 and got the usb cable, but don't see a connection on my box for it...
Looking at the pictures on the site, it looks like stage 2 has a connection on the back in while the stage 1 does not. Interesting thing is the boxes for the other stage 1's seem to have the connection also. Looks like the N55 Stage 1 is the only one with no connection.
I thought before they said Stage 1 N55 was not customizable.
      03-20-2013, 08:56 PM   #65
NICKTENN
NICKTENN's Avatar
It doesn't look like this?
      03-20-2013, 09:13 PM   #66
tdizzle
Nope. I think when they started working on the stage 2, they must've swapped out the stage 1 boxes so you can't customize it. Gives you more reason to buy the Stage 2 most likely.
