BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Thoughts on Powder Coating Wheels?
European Auto Source
      02-06-2013, 01:37 PM   #1
Ryan9095
Ryan9095's Avatar
40
Drives: 2015 F33 428i Lux Convertible
Hi all,
I was thinking of possibly having my Sport Line wheels powder coated to switch things up a bit. I like how it's temporary since my car is a lease and I'm not interested in changing out the rims because I really like my current ones and I don't want to do anything that would potentially void my warranty.
I've never done powder coating before so I would appreciate any comments, tips, suggestions on the process. How easy is it to remove? Will it harm the rim underneath? etc.
Thanks,
Ryan
2015 BMW 428i Luxury Line Convertible - Imperial Blue/Saddle Brown
2014 BMW i3-REX - Andesite Silver/Giga Cassia Leather
2014 BMW 650i Coupe - Alpine White/Black Nappa loaded
2013 Maserati GranTurismo Sport- Nero Carbonio/Cuoio
2016 Bentley Conintental Flying Spur - Dark Sapphire/Newmarket Tan
      02-06-2013, 03:10 PM   #2
Cfichman
Drives: '13 F30 / '16 F80 AW Ordered
plastidip
      02-06-2013, 03:10 PM   #3
Cfichman
      02-06-2013, 03:23 PM   #4
335BBS
Drives: 2009 335 coupe.
Originally Posted by Ryan9095 View Post
Hi all,
Thanks,
Ryan
Powdercoating is like paint.....its not coming off. As seen above, I think you mean Plastidip.
      02-06-2013, 04:12 PM   #5
KneeDragr
Drives: Planning 2015 ED :)
If you are going to plasti-dip, do yourself a favor and take the wheel off.
      02-06-2013, 04:19 PM   #6
Ryan9095
Ryan9095's Avatar
40
EDIT: Thoughts on PLASTI-DIP for Wheels
Hi all,
I appreciate the corrections. I meant plasti-dip NOT powder coating!
"I was thinking of possibly having my Sport Line wheels plasti-dipped to switch things up a bit. I like how it's temporary since my car is a lease and I'm not interested in changing out the rims because I really like my current ones and I don't want to do anything that would potentially void my warranty.
I've never used plasti-dip before so I would appreciate any comments, tips, suggestions on the process. How easy is it to remove? Will it harm the rim underneath? etc."
Thanks,
Ryan
      02-07-2013, 07:57 AM   #7
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
The durability of plasti-dip as a wheel finish is still being debated. Many believe it will begin to peel off or chip due to heat and road debris while others say it's fine. Luckily, it's cheap enough where it may not hurt to give it a shot!
Plasti-dip will not void your warranty in any way, and you can always return the wheel 100% back to it's original state.
      03-27-2013, 03:50 AM   #8
redeu3
Drives: F30 328i Sportline
Hi all,
Thanks,
Ryan
Have you done it? post some pics here. :-)
      03-27-2013, 09:02 AM   #9
1GrayBulldog
Drives: 2013 135i
I plasti-dipped the stock 400M's on my 328i M Sport and have been completely satisfied with the results. The finished product looks exactly like what you'd expect from having the rims powder coated matte black, but for a fraction of the cost as well as the ability to reverse later.
Go check out the tutorials on the dipyourcar website and you'll have pretty much all the info you need to DIY. Some personal tips I can offer are: like others have said, be sure to pass on the lazy methods of spraying the wheels while still mounted and just take the wheels off the car to plasti-dip them. Its the only way you can get the full coverage needed to ensure an even finish across the rim.
I recommend applying a total of 1 can per rim, which will ensure the plasti-dip coating is thick enough to resist normal wear and tear. A thick coating also makes it easier to peel the plasti-dip off if/when you want to do that. Clean the wheels meticulously and once they dry, I recommend wiping the rim surfaces down with rubbing alcohol as it helps the plasti-dip bond to the glossy finish of our stock rims. From there its just a matter of simple spray-painting techniques to apply the plasti-dip. First coat should be ultra-light, and the following coats should be light enough to ensure no running or bubbling. Depending on the conditions I've found a good 20-30 mins of drying time is needed between coats, and once finished you should allow as much as 12 hours for the plasti-dip to cure before re-mounting the rims. Be careful with your breaker bar and torque wrench when putting the wheels back on; you don't want to rub against the rim and tear the plasti-dip surface.
Hope that helps and be sure to post some pics of the finished result!
      03-27-2013, 10:01 AM   #10
Ryan9095
Ryan9095's Avatar
40
I want to do plasti dip but haven't been able to find a shop who is willing to do it. They either don't do it anymore or don't know what it is! I don't trust myself enough to "DIY".
Your car looks great Stormtroop!
      03-27-2013, 11:58 AM   #11
1GrayBulldog
Drives: 2013 135i
Thanks man! And hey, when you don't feel like you can do it yourself definitely get someone else to do it for you. My suggestion would be to post on your local craigslist; I have no doubt you'll get a number of people who'll be willing to do the job.
      03-27-2013, 05:28 PM   #12
Ryan9095
Ryan9095's Avatar
40
That's a great suggestion I definitely will do that! Thanks! I contacted dipyourcar and some of their authorized sellers and shockingly either they don't respond or no longer dip. Hopefully I will have luck this way!
      12-24-2016, 12:56 PM   #13
artmuz80
Drives: Honda Civic
I'm new and I'm interested in this topic. Thank you!
walmartone login
      12-24-2016, 04:50 PM   #14
Slickz
Drives: 2016 340i xDrive 6MT
DO IT!! I have BMW style 415 turbine wheels with powdercoat black, love em !
2011 X5 xDrive 50i - retired
2016 340i xDrive
      12-26-2016, 01:12 AM   #15
tgmsocal
Drives: 2013 328i xDrive
Although you say in your follow-up that you're interested in plasti-dip, I will say that I had my sport line 18" rims powdercoated matte black (on a Melbourne 328iX). Guy did an excellent job, rims came out perfect and look great, and he even sanded/painted my rusty hubs for free.
From what I understand, power coating rims does not void their warranty. You may want to check regarding the lease rules. Powder coating is the way to go if you can - I can wash my rims with any chemicals I want and there is no peeling or inconsistencies in the finish.
Good luck!
-tgm
      11-16-2017, 05:29 AM   #16
Dezy152
Drives: black BMW
I'm new to this issue and you helped me.
