BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 JB4 Stage2 Dyno Testing
      04-10-2013, 08:01 PM   #331
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Originally Posted by Jeff_in_Oviedo View Post
Eek, just installed the stage 2, and now I get a drivetrain malfunction, reduced performance. Anybody have any ideas?
Why would you make a post on the forum rather than emailing in photos of the install to BMS for assistance?!?!
Mike
      04-11-2013, 07:16 AM   #332
lazycat
Drives: f80 m3 CP
Any ETA on the official version of JB4 for the AT 335i? Whats the difference between the alpha/beta and the official release?
      04-11-2013, 07:55 AM   #333
mikew2069
mikew2069's Avatar
59
Drives: F30 335i MSport
They leave the 'beta' tag until all bugs are worked out. I haven't had any issues with mine (other than me accidentaly holding the volume down on the stearing wheel and putting it back to Map 0 without me knowing).
Keep in mind that gmail had a beta tag for quite a while before they took it off.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      04-11-2013, 10:07 AM   #334
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
2014 Audi SQ5  [0.00]
When running an E85 mixture should I continue to run map 2?
      04-11-2013, 12:36 PM   #335
mikew2069
mikew2069's Avatar
59
Yup yup
      04-11-2013, 04:01 PM   #336
RollingLower42
RollingLower42's Avatar
44
Drives: 2012 BMW 335I
I thought someone said that you should use high octane gas over E85 mixed with regular gas? Or maybe I misinterpreted it?
      04-11-2013, 04:43 PM   #337
tdizzle
Drives: 2017 F80 ZCP
E85 is, in effect high octane gas. Somewhere in the neighborhood of 105-110 depending on various factors.
It's real power is that it helps resist detonation because of of how it helps keep the engine cooler, therefore allowing for higher boost, timing, etc. I guess you could liken it to high octane gas + meth combined (slightly exaggerated but you get the idea)
      04-11-2013, 05:18 PM   #338
RollingLower42
44
So we should be on map 2 with race fuel?
And we should be on Map 7 if on a 60/40 E85 mixture?
      04-11-2013, 05:21 PM   #339
RollingLower42
44
Interesting, I feel when I use a mix of 100 Octane race fuel mixed with regular 91, feel the most power.
When I use a mixture of E85 with 91, it feels slower and not as fast as the 100 octane..Still quicker than stock, but still not as good as the 100 octane.. why is this?
      04-11-2013, 05:28 PM   #340
tdizzle
Hmmm. The tune needs to utilize E85 to get the most use out of it. I'm sure there is a map that takes full advantage of it (guessing 2 on the N55 F30). That said, pants dyno's can be off. I know the biggest actual dyno performers the JB4 crew has put out usually use E85.
In theory, the same E85 mix you referred to should put more power down than the 100oct mix but it won't be that much more, I'd suspect they'd be pretty close (93 alone vs a E85 mix is a difference of about 15 hp). This may be better directed to the tuning experts though. I bet someone from BMS or someone on their board can give you a better answer.
      04-22-2013, 06:17 PM   #341
Kyu
Kyu's Avatar
Drives: 2012 X6M
sorry if I missed it some where,
I have the previous JB4 Stage 2 for the E9X
Would it work on the new F Series 335 ? maybe just with a adapter for the plug ?
      04-22-2013, 06:50 PM   #342
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
Completely different DME. No.
      04-22-2013, 07:40 PM   #343
Bowser330
Drives: i3 REX
Are you doing several pulls to calibrate the different fuel before you do a comparison pull?
Where the E85 mix and 100 mix can produce the same octane rating (example 95 octane) it will take more e85 mix to make the same power than the 100 mix. So the car has to learn that it needs more e85 mix vs. 100 mix...
I felt something similar driving back from the e85 station and feeling the power difference as the JB4 adapted...pull one....pull two then once it adapted pull three, holy shit it was FUN. Effortless acceleration...and I only have JB4 & DCI!!!
      04-22-2013, 08:21 PM   #344
RollingLower42
44
What kind if E85 mix do you do? I am going to go back and add more E85 in the mix this time. I think maybe the last time, I only put like 3 or 4 gallons. Next time I will put more and will see how it is. Also I will let it adapt and see how it goes..
      04-22-2013, 11:29 PM   #345
buildbright
buildbright's Avatar
92
Drives: F80 M3 MG
I am running 5.2 gallons of E85 on a full tank.
      04-23-2013, 01:23 PM   #346
CulPetty88
Drives: 2012 335i Sport line
Anyone have the figures or a dyno for a 6MT 335i? Just curious..
      04-23-2013, 01:38 PM   #347
Bowser330
Drives: i3 REX
I usually put in 5 gallons of E85
      08-17-2013, 02:46 PM   #348
Bizall
Bizall's Avatar
Drives: 2018 M3-Alpine White/6MT
Mike,
Any updates on the intake as well? I'm looking to do the stage 2/intake combo...thanks.
2018 BMW M3 - Arrived (Alpine White/6MT)
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph
2008 BMW 135i (Sold) 12.8 @ 106mph
      08-17-2013, 04:04 PM   #349
jetbill
jetbill's Avatar
58
Drives: F80
Anyone know what could be expected with a stock downpipe running the E85 with the JB4?
I'm not sure if this would be considered stage two because it's a stock downpipe?
Thanks.
      08-17-2013, 04:57 PM   #350
J-boogey
J-boogey's Avatar
Drives: F30 335xi Msport
Thanks.
all I know is its not recommended to run stage 2 with a stock down pipe
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
      08-21-2013, 08:53 AM   #351
Jeff_in_Oviedo
Delivered!
Jeff_in_Oviedo's Avatar
Drives: '13 F30 335 M Sport
I believe you might be referring to Stage 2, map 2. Map 1 is for stock vehicles, as far as I know. Map 2 is for those with an aftermarket downpipe.
See here: http://www.n54tech.com/forums/showthread.php?t=18588
Text:
Map 0: Stock performance, JB4 off
Map 1: Peak boost 12.5psi, suitable for stock and mildly modified cars on pump gas
Map 2: Peak boost 14.0psi, suggested for those using a downpipe and 93 octane (USA) or higher fuels
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
      08-21-2013, 07:21 PM   #352
JNM3
JNM3's Avatar
215
Drives: Moonstone F80 ///M3
I'm thinking I might head to BMS when I upgrade to stage 2
-Justin N.
IG: @MoonstoneM3
