BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 JB4 Stage2 Dyno Testing
      02-08-2013, 01:30 PM   #45
jamesems
Drives: 2013 335i msport f30
That link I provided suggests the various transmissions span the 3 series line. It may be possible the heavier duty tranny's could bolt right up. Replace the 335i with say the diesels tranny. That would address the tranny's rating. More weight and very expensive option. Ill be waiting this one out too despite the fantastic numbers.
      02-08-2013, 01:39 PM   #46
Rustyboy155
Rustyboy155's Avatar
Drives: BMW M2 LCI
Anyone have insight into the stock clutch on the 6sp? I'd be willing to bet that the factory clutch probably isn't rated anywhere near 500+ lb ft of torque.
      02-08-2013, 02:00 PM   #47
bosz
bosz's Avatar
36
Drives: F30 335i Ordered
all the above is why I will stick to JB stage 1 for now.
Does anyone know what the e90 auto tranny is rated at? I mean all those e90s with JB4s, Dp, exhaust etc have 10s of thousands of miles with such high output numbers yet apparently no major problems like tranny failure...
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
      02-08-2013, 02:46 PM   #48
verbs
Drives: 2015 M235i
Originally Posted by buildbright View Post
Where does it say crank?
Automakers and OEM part suppliers rate everything in crank horsepower, not rear wheel horsepower. Aftermarket performance community is all about rear-wheel.
      02-08-2013, 02:54 PM   #49
verbs
Drives: 2015 M235i
It appears them may not be direct bolt ons. If you look at the two tranny's spec sheets you'll see different dimensions. That could cause a whole host of bolt on issues including the need for a shorter driveshaft, etc.
No way I'm going to want to have to spend $5,000+ for a full tranny upgrade and possible drivetrain alteration. If that's what it takes to handle a stage 2 tune with a D/P vs. just a stage 1 with no D/P, I'm stage 1ing all day long.
http://www.zf.com/media/media/produc..._DataSheet.pdf
      02-08-2013, 03:08 PM   #50
jamesems
No argument here. Good info btw
      02-08-2013, 03:31 PM   #51
buildbright
buildbright's Avatar
92
Drives: F80 M3 MG
Most is the case with the US companies, European companies tends to differ. My whole point was no one knows for sure how much power these trannies can take. I have seen transmissions take 3 times their rated limits and I have seen transmissions bust under factory load. But ZF usually underrates their transmissions.
      02-08-2013, 07:13 PM   #52
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
Will the F80 M3 transmission be a possibility? What about the F10 M5 transmission?
johnsedlak.com - web developer, designer
      02-08-2013, 07:22 PM   #53
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
That's one thing the 6mt has going for it. Power and torque increase, throw in a clutch for about a grand and call it a day.
A stock auto handling 10% over it's tq rating is one thing, 30-40% is really pushing it.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      02-08-2013, 07:24 PM   #54
Jamesons Viggen
New m3 might be good as you might not need a custom driveshaft. F10 will definitely mean more custom fab work.
      02-09-2013, 01:12 AM   #55
buildbright
92
Drives: F80 M3 MG
The N54 6sp Steptronic has a lower rating and people have run over 450lbs without problems so yes it is very likely.
      02-09-2013, 03:02 PM   #56
pelo911
Drives: 991 GT3
i don't understand
burger ECU stage 2 already avilable for F30?
      02-09-2013, 03:08 PM   #57
jamesems
What's the rating for that series?
      02-09-2013, 04:17 PM   #58
buildbright
92
Drives: F80 M3 MG
400nm = 295 lb ft
      02-09-2013, 10:26 PM   #59
RollingLower42
RollingLower42's Avatar
43
Drives: 2012 BMW 335I
I don't understand what some people are saying with the engine tranny's on here..
Are you guys saying, if we want to run Stage 2, we will have to upgrade our transmission?
      02-10-2013, 03:51 AM   #60
nsquared
[Versatile]
nsquared's Avatar
44
Drives: (S)LOW.
Is the dyno graph showing power increases at the wheels or?!
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
      02-10-2013, 10:58 AM   #61
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
Back on topic of the tune...
Originally Posted by Mike@N54Tuning.com View Post
The F30 Stage2 is similar to the N54 and E90 N55 JB4 with the exception of functional dash control. So, no in dash gauges. But you can cycle through maps and disable the tune all together using the steering wheel controls.
So Mike-is there any feedback mechanism to tell you what tune you're running?
Are in-dash controls in the works, or is the F30 gauge cluster just to complicated to mess with
Does the stage 2 for the F30 clear codes?
Does the stage 2 handle the rear o2 sensor delete for running a castles DP? (does the stage 1 do this as well?)
-Also, I find it interesting that all 3 maps line up after 6k rpm. I guess at that speed we just run into the volumetric limit of the stock turbo
      02-12-2013, 02:41 PM   #62
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
For any addl info you'll need to check BMS' forum where they release updates, etc. But I know it has a DPFIX built in for the downpipe, and automatically deletes all hidden tuner codes.
Mike
****APRIL SALES AND COMBO DEALS!! - CLICK HERE!!****
N54 Catless Downpipes - 349.00 Shipped!! ER Products 10% OFF + FREE SHIP PURE TURBOS - ON CRAZY SALE JB4 SALE!! $50.00 OFF + FREE EXPRESS SHIP
      02-12-2013, 03:00 PM   #63
Mike@N54Tuning.com
Here is a video of how to enable/disable the JB4 using the beta software.
      02-12-2013, 03:49 PM   #64
nsquared
[Versatile]
nsquared's Avatar
44
Drives: (S)LOW.
Mike, were the dyno graphs showing power at the wheels?!
      02-12-2013, 04:11 PM   #65
m5 guy
m5 guy's Avatar
Drives: 2016 M5, 2017 X5
Do you know if they are planning to integrate with the p3cars gauge as well?
2016 F10 M5 Space Gray-Black JOURNAL
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2010 E60 M5 Saphire Black-Black SOLD
2013 F30 335 Estoril Blue-Black SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      02-12-2013, 04:39 PM   #66
ridin135
Drives: Depends on the day
It's to the wheels
