BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Dent on The Rear Wheel Arch
      02-09-2013, 03:20 PM   #1
OL1V312
Drives: 328i M Sport
Hey guys someone dented my 328i on the rear wheel arch so i went to get it checked. His suggestion is he have to drill small hole in the wheel well so he can get his tools behind the dent. My question is is it a good idea to drill a hole.
      02-09-2013, 03:25 PM   #2
F30AM
F30AM's Avatar
Drives: F30 330d M Sport sDrive
Are you talking about Paintless Dent Removal? Then that should be ok. I presume the paint surface is not damaged.
Picture?
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys
      02-09-2013, 03:37 PM   #3
OL1V312
Yes PDR.. The pain is not damage at all but the location is really on the bad spot .How bout long term effect like corrosion?
      02-09-2013, 03:53 PM   #4
F30AM
F30AM's Avatar
He'll paint the edges of the drill hole to prevent corrosion and put a bung in it. Should be fine.
I had a similar thing happen to my Golf and the fix was perfect.
      02-09-2013, 03:56 PM   #5
OL1V312
Thanks imma go get it done now
      02-09-2013, 04:25 PM   #6
F30AM
F30AM's Avatar
Best of luck. Watch him like a hawk.
      03-22-2013, 02:56 AM   #7
rtb001
Drives: 2013 328i - 2016 X3 28i
pdr hole?
I have a small dent in my right rear door, probably from a door from a neighboring car in the parking lot.
I noticed that all four doors have a quarter sized hole on the end with a rubber plug. I pulled the rubber plug off, and could see some of the window/lock mechanisms inside the door.
Are these holes put there to allow access for paintless dent repair? Or are they there for some other reason, but maybe the repair guy could use it to get their tools in behind the dent?
Unfortunately my dent is all the way on the other side of the door close to where the door hinge is, but maybe the local PDR guy could get to it through that hole on the other side of the door.
      03-22-2013, 09:38 AM   #8
bananachipz
Drives: F30 Mineral Gray 335i
There should already be a plug in the arch... Had one similar removed without any drilling.
      03-25-2013, 04:53 PM   #9
Gray_Panther
Gray_Panther's Avatar
313
Drives: 128i
Youtube pdr with compressed air can and hair dryer.
I am going to try it on my golf.
2012 BMW 128i 6MT Deep Sea Blue Metallic
