BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 Wipers - How to Get Them Away from the Windshield
European Auto Source
      02-13-2013, 01:41 AM   #1
TopDown
TopDown's Avatar
Drives: 2017 G30 540i M Sport
So I've RTFM, and the directions on how to get the F30 wiper blades away from the windshield (to clean the glass) aren't doing it. So can anyone solve the mystery - how do you do it?
Mine
G30 540i M Sport
Hers F36 428i Gran Coupe
      02-13-2013, 02:29 AM   #2
David328M-Sport
Australia
62
Easy. Switch the ignition on and then off. Lift up the wiper switch till it won't lift any more. Let go. Wait until the wipers sweep across the screen twice. They will come to rest in a vertical position. Carefully lift each blade back off the screen and clean.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      02-14-2013, 12:23 AM   #3
TopDown
TopDown's Avatar
OK, so here's the missing step in the owner's manual - after shutting off the ignition, you also need to shut off the electronics. Won't work with ignition off but electronics on. Thanks.
Mine
G30 540i M Sport
      02-15-2013, 02:21 AM   #4
LDSM
LDSM's Avatar
Drives: ...
The fact that we have to go through this just to raise the wipers irks the hell out of me.
I can understand it's probably for aerodynamics, but it's very possible someone may try to raise the wipers without knowing the procedure and damage them.
Is this how it is for all BMW's? What about Mercedes,Audi, Lexus?
      02-15-2013, 02:56 AM   #5
kon
Singapore
Drives: F30 316i
For Audi, on the mmi screen (idrive equivalent) there's wiper service option to move the wiper up or down for replacement. No brainer.
      02-15-2013, 09:02 AM   #6
David328M-Sport
Australia
62
I've had my one side of my car foamed a couple of times up before I remembered to lift the wipers off the screen. So annoying having to go through the routine.
It's pretty obvious that neither wiper can be lifted terribly high in the off position, so unless one is very heavy handed, I believe there shouldn't be terribly many 'injuries' to the hood.
The F30 is the first model since the E36 (cannot comment on the E30 and earlier as I never owned one) I have had to go through this routine. All wipers on the E36, 46 and 90 lifted off from the horizontal off position.
My wife's C180k's wipers lift off from the horizontal off position.
      02-15-2013, 09:19 PM   #7
TopDown
TopDown's Avatar
At least for the F30, BMW reverted to a physical thumb wheel to control interior lighting. On the wife's E92 it was controlled through iDrive...not good.
Mine
G30 540i M Sport
      02-15-2013, 09:22 PM   #8
justinnum1
Drives: 2015 328i Msport 6mt
pisses me off that it will dry sweep the windshield twice.
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      02-15-2013, 09:28 PM   #9
TopDown
TopDown's Avatar
I had a 2002 Z3 where the only way to get the wipers off the windshield was to first lift the hood, then pull the wipers away - under the open hood! The first time I did that I shut the hood forgetting the wipers, and bent one of the wiper arms.
Mine
G30 540i M Sport
      02-15-2013, 09:55 PM   #10
TopDown
TopDown's Avatar
Look at the upside...you're driving an Estoril Blue MSport.
Mine
G30 540i M Sport
      02-15-2013, 10:16 PM   #11
Buzzman
Drives: 2016 F26 M40i
Unless you have a nice wife, who wants to be helpful and tries it, without knowing that it is not as simple as it seems
2016 F26 Alpine White M40i
2014 F25 Alpine White 35i Sport - Retired
2012 F30 Melbourne Red 335i Sport Line - Retired
2007 E92 Space Grey - Retired
      02-15-2013, 10:45 PM   #12
justinnum1
True.
