BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Burger Motorsports Rear Spacers on 18's with M Performance Suspension (20mm drop)
      02-13-2013, 09:52 PM   #1
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I installed the 12mm Burger Motorsports Spacers tonight, was pretty straightforward, and just did the rears because that's where the biggest queries have been coming from.
I ordered a host of fun stuff from them (since this is my first BMW and I didn't have all of their elite parts...like their BMW Wheel Saver Socket and their Jack Pads):
Installed on the rear hub...I didn't need a wire brush since I only have 8000 miles on the car, but the amount of rust in the hub is almost comical...(almost as bad as the rusty seat frames ):
The build quality is pretty nice...lightweight aluminum, minimal additional to unsprung weight, and the bolts are a HUGE upgrade from the stock ones.
Everything clears nicely:
Here's the before pic:
And after:
I'm going for a test drive right now...BTW, directions were insanely detailed, it's kind of funny that people bitch about the lack of instructions for their piggy back unit.
I'm probably going to leave the front ones off until the Spring comes around since I'm too lazy to swap 'em tonight...
SOLD: 2012 335i Mineral Gray
      02-13-2013, 10:28 PM   #2
shivaswrath
Drives: 2012 335i
So came back from the test drive, re-torqued everything to about 88-90 lb's...everything sits nice and FLUSH.
12mm is literally perfect for our rears...anything wider would be ricey IMO.
      02-13-2013, 10:56 PM   #3
's Avatar
71
Drives: ✚
Thanks for being the first. Can you take one more pic? I just want to see an up close pic of where the spacer contacts the hub. I want to be sure it nicely touching.
      02-13-2013, 11:08 PM   #4
shivaswrath
Drives: 2012 335i
Sure I'll snap in the morning when there's more light out...
It meets up flush, there are only gaps where the pry tabs are.
I'll need to probably lightly sand and put some anti-seize on them in the spring after all this bloody salt on the streets from the daily snow...
      02-13-2013, 11:20 PM   #5
's Avatar
71
Drives: ✚
I look forward to the pic. While you're at it, snap some pics of the whole car. I bet it looks proper now.
      02-15-2013, 11:55 PM   #6
335i-SG
335i-SG's Avatar
Drives: 2013 335i M-Sport
I thought we could only fit 5mm or 15mm+ on rear for not having enough lip?
Did Burger tell you there 12mm rear was ok and safe?
If they did, I don't understand why H&R says they don't make 10mm to 12mm for rear.
      02-16-2013, 12:29 AM   #7
jamesems
Drives: 2013 335i msport f30
Nicely done Shiv. Look forward to more pics
      02-16-2013, 01:26 AM   #8
's Avatar
71
Drives: ✚
Burger told me that a 10 or 12mm absolutely would not fit the f30 rear. The reasoning behind it is sound. So I'm wondering how well Shiva's 12mm fits.
Hey Shiv. More close up pics please.
      02-16-2013, 10:39 AM   #9
shivaswrath
Drives: 2012 335i
That's so odd that they would say that, when I slipped the Spacer over the brake hub, it was snug and flush.
When I torqued the bolts down, it was snug and flush.
I wanted to take pictures this weekend, but alas, my car is back with BMW (again) for an annoying rattle in the dash, a dead horn (fuse?), and for some M Performance goodies (sneak peak!)
I'll post on Monday when I get it back...it fits perfect.
      02-18-2013, 01:53 PM   #10
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
What was the reasoning behind them saying the 12mm wouldn't fit? Currently working on producing spacers (Tarmac Solutions; coming soon) and we haven't run into any issues so I'm curious what their reasoning is. Thanks for the info!
Also can't wait to see a stance photo of what the 12mm does, I am thinking about running them on stock wheels with h&R sport springs for this spring.
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
      02-18-2013, 04:03 PM   #11
's Avatar
71
Drives: ✚
I'm not quite sure what the reasoning was... But it had something to do the the F30 hub lip protruding a few mm further than before. So there was not enough space for a lip with enough strength on the spacer. Of course I've always had my doubts.
      02-18-2013, 05:21 PM   #12
shivaswrath
Drives: 2012 335i
Just got the car back, I'll take pics tonight...there are no protrusions, I literally installed with my hand and it's flush.
      02-18-2013, 08:21 PM   #13
's Avatar
71
Drives: ✚
thanks. I look forward to the pics. BTW, what wheels are those?
      02-19-2013, 03:14 PM   #14
shivaswrath
Drives: 2012 335i
They are the standard 18's (397 style).
Here they are on the left and right hubs, flush:
hope this helps!
I bought a wire brush today at home depot, so might tackle the fronts tonight since I'm dying to get them looking even...I don't think i'll need the anti-seize given I'll be changing the rims/tires every 10k and I don't want to put crap on the brake hubs.
      02-19-2013, 03:28 PM   #15
's Avatar
71
Drives: ✚
Thanks Shiva. I'll be ordering a set soon.
      02-19-2013, 03:29 PM   #16
shivaswrath
Drives: 2012 335i
12 or 15mm? No problems bro..
      02-19-2013, 03:35 PM   #17
's Avatar
71
Drives: ✚
The 12mm for sure. I was reluctant to try the 15mm since I think it would be too agressive with my drop.
Even with the 12mm, it might be really close; as the tires on the 19"s are much wider than the rim itself.
      02-19-2013, 03:44 PM   #18
shivaswrath
Drives: 2012 335i
Nice...yeah, $ wise, the Burger ones workout well because they are the only ones on the market with lugs included, and they are def high quality lugs.
I'll update post with pictures when I get the front's done tonight...with the wife out of town, I'll have time to play! Play with the car that is...*ahem*
      02-20-2013, 12:01 AM   #19
shivaswrath
Drives: 2012 335i
Thumbs up Fronts are sitting nice and flush too
Despite the rain, I decided to mount the spacers tonight.
Def get a set of wire brushes from your local hardware store, I regret not doing this for the rears, it really cleans down the surface of the hub (why is there so much rust in there?!?!)...but I'll be swapping winters out in a month, so not stressed about it.
angle shot is funny, but here is the driver's side:
      02-20-2013, 02:59 AM   #20
dcg71
Australia
32
Drives: F15 X5 25d / Ducati Monster
Nice, so no rubbing with the fronts? It's a good idea to use the same size spacer all round. Maintains the ratio between front and rear track widths. Widening just the rear leaves you more prone to under steer I think.
And you need to take some pics outside your garage
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      02-20-2013, 11:30 AM   #21
shivaswrath
Drives: 2012 335i
Yup, no rubbing, it's damn near perfect with my drop.
I do need to get out of the garage, but it was snowing/raining last night when I was doing this at 21:00h! When the $hit weather stops, I'll be doing a nice photoshoot :-)
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
