BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Alpina F30 B3 Bi-Turbo Revealed with 410 HP. Debuts at Geneva Motor Show
Vorsteiner
      02-14-2013, 07:30 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Lightbulb Alpina F30 B3 Bi-Turbo Revealed with 410 HP. Debuts at Geneva Motor Show
BIMMERPOST NEWS
Alpina B3 (F30) Revealed with 410 HP. Debuts at Geneva Motor Show
165
COMMENTS
Alpina has revealed some initial specs and first full photo of its new B3 Bi-Turbo, based on the F30 335i sedan.
Updated with newly released specs (2/27/13):
The F30 B3 boasts more power and torque than the E90 B3, yet is 20% more gas efficient.
The new B3 Bi-Turbo delivers 410 HP (301 kW) starting at 5500 RPM (compared to the US F30 335i with 300 HP), and and 442 lb-ft (600Nm) torque. Transmission comes in the form of a ZF 8 speed automatic.
0-100kmh (0-62 mph) takes only 4.2 seconds.
Top speed is 305 km/h (189 MPH).
Emissions decreases by 7.6 L per 100 km, to 177 g / km CO2.
Full specs (and photos) of the car will be revealed when it debuts at the 2013 Geneva Motor Show early next month. Unfortunately, like the previous B3 model, we do not expect this new B3 to be made available in the U.S. (though it's always possible down the line if Alpina sees a business case for it).
      02-14-2013, 07:44 PM   #2
verbs
Drives: 2015 M235i
I want to know if it's the same ZF tranny model in the standard cars or a beefier one. Might give us some insight if Alpina feels a 100hp and likely sizeable torque increase is safe on the current tranny we have which isn't rated to go that much higher torque wise.
      02-14-2013, 08:30 PM   #3
bimmerjph
bimmerjph's Avatar
Drives: 2002 BMW 325i
It would still be the HP8,but ZF makes version of that transmission that can handle more power. So its the same basic tranny, but it is beefier.
      02-14-2013, 08:35 PM   #4
FotiosF80M3
FotiosF80M3's Avatar
Drives: 2015 F80 M3 AW/SO 2015 X5 Msp
wow, this car is impressive. I wonder what the've done to the n55. 0-62 in 4 seconds! Thats fast.
2018 M3 COMPETITION Mineral white, Black,
carbon roof, black 20's, Mperf splitters/Blade, carbon spoiler, mirrors, etc
      02-14-2013, 08:35 PM   #5
bmwMcrzy
bmwMcrzy's Avatar
Drives: 2002 M5 DINAN S2
So peak power is 1500 rpm before the redline?
Does power just fall off a cliff?
      02-14-2013, 08:50 PM   #6
timmyc
SW20 to BL to E92
timmyc's Avatar
Taiwan
Drives: 07 E92 335i
That's how most cars are, you might be confusing power with torque
      02-14-2013, 08:56 PM   #7
bmwMcrzy
bmwMcrzy's Avatar
I'm not, most N/A engine make peak power much closer to redline.
I've seen other boosted (S/C) BMWs make peak power much closer to redline.
Those turbo might not be up for the task.
      02-14-2013, 09:00 PM   #8
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
It's faster than a 911 and Cayman. And has 4 doors.
And is fuel efficient.
And isn't being sold in the US...
This is like an epic win and fail post all in one
SOLD: 2012 335i Mineral Gray
      02-14-2013, 09:03 PM   #9
motorsport_cat
motorsport_cat's Avatar
Drives: 1995 740iL
1995 BMW 740iL  [0.00]
Nice!!! 4.0 seconds to 60mph!!! I have a question...
Does BMW own alpina or is it an independent company?
///Meow
      02-14-2013, 09:05 PM   #10
AcidMal
Drives: 2012 E92 335i
So your saying this is faster than the m3?
By that much?
I think there is a typo here
      02-14-2013, 09:05 PM   #11
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Independent, but very close relationship.
Here's an Alpina history lesson and some more insight into the company:
Alpina BMW Model Design, Production and Manufacturing Process
Alpina History Lesson
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      02-14-2013, 09:17 PM   #12
buildbright
buildbright's Avatar
92
Drives: F80 M3 MG
I dont trust Alpinas numbers. The reviews of the new B7 are lack luster.
      02-14-2013, 09:23 PM   #13
TheBingoBalls
the B7 was lack luster because it's just too big of a car. I think it's much more easier for Alpina (or any other tuner for that matter) to use the 3-Series chassis and make it a better car.
      02-14-2013, 09:24 PM   #14
buildbright
92
Drives: F80 M3 MG
I meant it was lackluster because it did not make the power it advertised.
      02-14-2013, 09:30 PM   #15
motorsport_cat
Drives: 1995 740iL
Thank you
///Meow
      02-14-2013, 09:32 PM   #16
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
The ZF transmission is modular and can be had with a torque converter, automated clutch or electric motor.
      02-14-2013, 10:02 PM   #17
bimmerjph
bimmerjph's Avatar
Didn't they do the dyno on an AWD dyno with a RWD car, or something like that. If I am remembering that correctly that could be a reason for the difference.
      02-14-2013, 10:03 PM   #18
verbs
Drives: 2015 M235i
It's kind of the same tranny. The beefier tranny versions of what is currently in the 335i cars have different dimensions than our current tranny. A swap would likely require drivetrain modification (shorter driveshaft, etc).
      02-14-2013, 10:09 PM   #19
verbs
Drives: 2015 M235i
No, he's got a point. Our cars make peak hp at 5800 rpm and redline at 7000 rpm I believe. That would mean the Alpina makes peak hp at an even lower 5500 rpm assuming the same redline. My guess is they're tapering off boost a little early to promote longevity, and/or the turbos just can't breathe up there.
      02-14-2013, 10:11 PM   #20
buildbright
92
Drives: F80 M3 MG
Yes alot of the dynos used today are AWD. They are setup to do both RWD and AWD. They used a correction factor but it still came in way below.. Not to mention driving it against the S8 also helped prove how over rated it is.
      02-14-2013, 10:15 PM   #21
iconfat
Member
iconfat's Avatar
Drives: '11 E92 335i
Gotta be an n54 but definitely not an n55. Bi-turbo (twin turbo). Unless they somehow fit 2 turbos on the n55.
      02-14-2013, 10:26 PM   #22
BavarianFanatic
Too much is never enough
Drives: Too Many
It IS a bi-turbo. So yes, they've fitted two turbos.
These numbers are very believable. You don't need a hell of a lot of an increase in boost to find 100 HP.
