Bimmerpost for iPhone and Android have just been updated with a host of bug fixes. If you've ever had trouble logging into it in the past, give it a try now!
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 335i Chargepipe blown w/ stage 1
      03-05-2013, 12:18 PM   #23
TT6mT
Drives: 2013 AW F30 M Sportline 6mt
Originally Posted by Number View Post
That should be covered under warranty. What happens when the CP blows anyways? Does it go into limp mode?
The car would surge when I was just maintaining a steady speed. With an obd2 scanner, I could see the MAF spike from 4~5 up to 10. It wasn't a good feeling.
      03-05-2013, 05:18 PM   #24
Monstr6
Drives: 2013 335i M sport
Would this cause a check engine light to come on as well??
When im cruising in 8th gear on the highway my car seems to surge back and forth. And i have a check engine light on but i thought it was just form putting the catless down pipe on, BUT it shouldn't because i have the BMS stage 1 tune.
      03-05-2013, 06:40 PM   #25
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
Stage 1 doesn't clear codes.
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      03-05-2013, 06:42 PM   #26
tdizzle
Drives: 2017 F80 ZCP
What do you mean by surge?
      03-05-2013, 07:28 PM   #27
TT6mT
Yes, the check engine came on. It gave off 2 P00BD codes. By surge, I mean the car suddenly jolted like the turbo spiked for a split second. All is well now, I'm not sure if the CP broke or just came loose.
Don't be alarmed, I was told it was a freak incident.
      03-05-2013, 07:57 PM   #28
mikew2069
mikew2069's Avatar
64
Drives: F30 335i MSport
I too through a P00BD code yesterday but it went away. I should have my Stage 2 upgrade by the end of the week so I'm hoping that solves that issue...
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
      03-05-2013, 11:19 PM   #29
Monstr6
while maintaining a steady speed ex 65mph It feels like and sounds like the turbo starts spooling up and then stops, spools up then stops over and over again. I have to step on the gas to go away. I only notice this in 8th gear around 2k rpms.
but from reading other posts it now sounds like the check engine light is from the DP
      03-05-2013, 11:55 PM   #30
tdizzle
I'd agree the engine light is probably the DP. But the surging issue probably is something else that needs to be checked out.
I'm wondering how people with DPs get warranty work done. Do you have to remove it so they don't try to pin any issues to the DP?
      03-06-2013, 08:53 AM   #31
mikew2069
mikew2069's Avatar
64
If you google that code, it's not from the DP.
Type Powertrain - Fuel and Air Metering - ISO/SAE Controlled
Description Mass or Volume Air Flow "A" Circuit Range/Performance - Air Flow Too High
Also, the DP doesn't void the warranty except for the exhaust system.
      04-25-2014, 12:10 PM   #32
DanielBimmer
DanielBimmer's Avatar
51
Drives: YMB M4
Originally Posted by lazycat
a "Drivetrain problem" message appears on the screen with an advice to "Drive at moderate speeds"
You lose all boost and the engine feels NA. Because the turbos are still spooling, the engine sometimes stutter when you accelerate. Typically not more than 10% throttle acceleration before you feel the jerk/coughing. Feels like a 30.6hp car.
My car stutters a lot! Ill floor it and I'll feel this weird loss of power with a stutter, I'll let go out the accelerator and try it again and it's fine, is this a blown chargepipe?
      04-30-2014, 06:37 PM   #33
Michael A
Michael A's Avatar
Drives: 2009 BMW 135i M-Sport
When I had my 2009 135i n54 I had the burger jb+ turned up 75% + and under high load conditons, flooring it on the highway for more than 10 seconds the charge pipe occasional popped off. It didnt break just popped off. I woukd take the metal ring holding the charge pipe on and bend it a bit to and it woild seem to hold a bit better.
2011 VW GTI 2009 BMW 135i 2009 Pontiac G8 GXP 2009 VW CC VR6 Sport 2008 BMW 135i 2006 Lexus is350 2008 VW R32 2007 Nissan 350Z 2006 VW GTI 2006 Civic SI 2004 Acura TL 2003 Mitsubishi Evolution VIII 2000 Honda S2000 1994 Nissan 300ZX Twin Turbo 1993 Toyota MR2Turbo 1996 Ford Probe GT 1994 Acura Integra GS-R 1992 Honda Prelude 1990 Nissan 300ZX 1990 Mercury Cougar XR7 1990 VW Corrado 1990 Eagle Talon TSI Turbo 1990 Ford Mustang GT 1985 Dodge Daytona Turbo Z 1986 Mitsubishi Starion ESI-R 1986 Ford Mustang SVO 1985 VW Scirocco
