| 02-18-2013, 08:19 PM | #1 |
Rep 659
My HUD isn't compatible with my Sunglasses!!!
So today was a very sunny day and I was driving early on in the day headed East, and sun was right in my eyes, so I decided to put on my Ray Ban shades. Everything was fine, until I looked at my HUD to check my speed, and it wasn't there! I panicked for a second, thinking it broke, but then when I looked really hard I could barely see the outline of the words. I took off my shades, and voila everything was back to normal.
I wondered if it was just shades overall, so I tried on my wife's Gucci shades, and I could see the HUD perfectly fine through them. Now, I'm pretty sure that my sunglasses are polarized while hers are not, and that this is probably what's causing the problem. However, before going out and dumping another 100-200 on a new pair of shades, I'd like to confirm this first. For those of you with the HUD and shades, can you see if you can CLEARLY see the HUD with shades on? If you can/can't, are your shades polarized, just mirrored, a certain shade, or what? Thanks! |
| 02-18-2013, 09:28 PM | #2 |
Rep 1,044
My shades are polarized and although the HUD gets much dimmer with the shades they are not gone. If you tilt your head slightly to either left or right (a slight angle) you should be able to view the brightness of the HUD change as seen through your shades.
| 02-18-2013, 10:01 PM | #4 |
Rep 4,320
I stopped using polarized glass when I drive because most of the dash or LCD elements get phased out (as expected from polarization).
![]() SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
| 02-18-2013, 11:45 PM | #6 |
Rep 1,892
I tried several technique to avoid replacing my prescription polarized sunglasses and they all failed.
I ended up getting a new pair with non-polarized glass just for my F30 and have never looked back. The place I went asked if I was a pilot as they run into the same issue with the aircraft displays too. It's a very common issue. |
| 02-18-2013, 11:57 PM | #7 |
Rep 623
Like someone already said, I tilt my head. Usually I look at the HUD only for nav instructions so it doesnt bother me so much. I dont want to give up the glare free vision just to stare at the current speed all day long
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara |
| 02-19-2013, 01:36 AM | #8 | |
Rep 1,892
I never look at the cluster speedo anymore, I only use the HUD, so I now just quickly glance down to read it. It's amazing how fast you get used to it. I really miss it when I drive our other car. |
| 02-19-2013, 02:17 AM | #9 | |
Rep 219
| 02-19-2013, 05:19 PM | #11 |
![]() 1607
Rep 2,180
Drives:
I have polarized prescription sunglasses (with every upgrade possible - non glare, etc) and I can see the HUD perfectly.
| 02-19-2013, 05:56 PM | #12 |
Rep 659
So it seems like some people ( a very few) with polarized can see HUD, but most can't. Guessing it's probably something about if its horizontal vs vertical polarization. I think I'm just going to pick up a pair of non-polarized shades for driving (pretty much only time I wear sunglasses anyway)
| 02-21-2013, 10:06 PM | #14 |
Estorilblau Member
Rep 252
I suspect that polarization is not the same between brands. I have a set of Rx Oakleys that are polarized and I can see HUD displays clearly. I've worn RayBan and Maui Jim (non Rx) and they've filtered differently than my Oakleys (never tested them on a HUD though).
There may be a factor related to individual physiological differences, but I'm not a doctor so I don't know. |
| 02-22-2013, 02:04 AM | #15 |
![]() ![]() ![]() ![]() 15
Rep 606
I picked up my car yesterday and my SA actually told me that if you go to the HUD menu the last option on the menu is ROTATION, if you slide that scale up slowly it does make the HUD visible with polarized sunglasses. I tried it and while not perfect it does work.
| 02-22-2013, 02:58 AM | #16 |
Rep 219
| 02-22-2013, 10:56 AM | #17 |
Seismoguy
Rep 180
I think polarized glasses are built to block light reflected at a high angle off glass, like the HUD, or the Sun coming off the hood or pavement or bodies of water. So the better your polarized glasses are doing their job, the dimmer the HUD will be.
| 02-23-2013, 09:34 PM | #18 |
Rep 659
Well guess my Ray Bans are amazing at doing their job LOL.
Went out and picked up a pair of Versace non polarized ones. Will be my dedicated driving glasses. |
| 02-27-2013, 01:10 PM | #20 |
Rep 4,264
Depends on polarization.
The orientation of the lens will matter a huge amount. I tilting your head doesn't, then the lens could be a circular polarized like some camera filters. YMMV. |
| 02-27-2013, 08:24 PM | #21 |
Seismoguy
Rep 180
My quick read suggests circular polarization effectively scrambles polarization, which is useful for sending light onto a camera lens, and lacks the benefit of linear polarization. Circular polarization has little relevance for sunglasses.
So sunglasses are either linearly polarized or not, those are the two choices. |
| 02-27-2013, 09:35 PM | #22 |
Rep 5,103
My Maui Jim's also mess with my HUD. HUD brightness/tilt does nothing to improve. Thanks BMW.
E90 Business Pro stereo suffered from same. At least pre-LCI did. However same type of display in A/C control was unaffected. Seems BMW can do better if they tried.
current 2024 i5 | 2024 530i | 2026 X5 M60i
retired 2023 840GC | 2021 740i | 2019 540i | 2019 X3 30i | 2017 540i | 2016 535i | 2015 535i | 2014 335i | 2013 335i | 2010 335i | 2007 750Li | 2006 330i | 2003 330iC | 1997 M3C |
| Bookmarks |
