BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Which Steering do you have on your F30?
European Auto Source
      02-22-2013, 03:11 PM   #1
F30AM
F30AM's Avatar
Drives: F30 330d M Sport sDrive
*Standard Steering
*Servotronic Steering
*Variable Sport Steering
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys
      02-22-2013, 03:14 PM   #2
Captain Cow Pat
Captain Cow Pat's Avatar
England
35
Drives: VO F31 330d xDrive M Sport
I will have VSS
      06-28-2015, 06:56 AM   #3
antjos1
Drives: f30 330i msport
How can you tell which one you have.my car is the 328i msport
2013.
Cheers.
      06-28-2015, 01:07 PM   #4
F30AM
F30AM's Avatar
2013.
Cheers.
Check with your VIN No
http://www.bmwvin.com/?f=2&url=/x/in...in.com&ssl=off
      06-28-2015, 03:45 PM   #5
Jav124
Drives: F30 330d MSport +
VSS on mine
      06-29-2015, 02:40 AM   #6
335dJa
Drives: Yes
Had servotronic on my first and now have vss. The vss has noticeably less dead band, glad I went for it but it's not drastically different.
      06-29-2015, 03:30 AM   #7
John435D
Recruit
John435D's Avatar
Drives: 435D m-sport, MG & Coral Red !
VSS, I don't have any issues with it
      06-29-2015, 03:51 AM   #8
crowdedhouse
crowdedhouse's Avatar
Ireland
44
Drives: 2018 X3 20d mSport
I assumed Servotronic (on mine) was the standard steering.
Seven Worlds Will Collide
      06-29-2015, 04:50 AM   #9
rocketretro
rocketretro's Avatar
England
177
Drives: M235i Coupe
Originally Posted by F30AM View Post
*Standard Steering
Why would you be interested? have you seen the error of your ways? has the lustre of the Golf worn off?
BTW VSS it's superb on the 2 series and makes the Mercedes steering barge like.
      06-29-2015, 05:27 AM   #10
dopper99
dopper99's Avatar
England
2601
Drives: C63 S Coupe
He asked the question in Feb 2013 - he had a 330d then!
Current:
Mercedes AMG C63 S Coupe
Previous:
F80 M3 Competition Pack
      06-29-2015, 05:28 AM   #11
rokut
Drives: 335d GT M Sport+
I think 330d and above, and probably 328i and above, have Servotronic as standard. Lower engine models can have Servo or VSS added as an option (I think).
On my 335d it's Servotronic but this came as standard.
      06-29-2015, 05:31 AM   #12
rocketretro
England
177
Drives: M235i Coupe
That explains that then, I did not notice that the posts had the date on the top left corner, but there are a lot of resurrected posts going on at the moment, just like echo's from the past. Cheers and a small apology to F30AM for any perception of a slight towards his present choice of vehicle.
      06-29-2015, 05:36 AM   #13
SkyJawa
SkyJawa's Avatar
England
1674
Drives: 335d
they do!
      06-29-2015, 06:56 AM   #14
kilsajj
Drives: 328i f30
Hi all
which one is the better.
      06-29-2015, 08:02 AM   #15
JohnM
Drives: 330d M Sport PPK
I Have VSS
      06-29-2015, 08:14 AM   #16
dopper99
dopper99's Avatar
England
2601
Drives: C63 S Coupe
Originally Posted by kilsajj View Post
Hi all
VSS is better in terms of less arm twirling when going around mini roundabouts or pulling out of junctions etc......... I love it.
Current:
Previous:
      06-29-2015, 02:18 PM   #17
F30Andy
F30Andy's Avatar
Drives: F06 640d
Anyone know what the actual differences between the three are?
I have servo BTW.
      06-29-2015, 02:44 PM   #18
HighlandPete
Drives: BMW F11 535i Touring
I have servo BTW.
The basics of HPAS or EPS.
Standard power steering typically has a fixed amount of assistance, hence requires more effort at low speeds and can seem too light at speed.
Servotronic is electronically controlled and speed sensitive. More assistance at low speeds, as in parking and slow manoeuvres, less assistance as speed increases, more weight/stiffness at speed.
Variable 'sport' rack as in VSS, reduces the amount of steering wheel movement off centre. Better for turns and slow speed manoeuvres, not over sensitive driving straight at speed, still retains a similar steering ratio at mid position. 'Lock to lock' uses less turns of the wheel. Add in servotronic and VSS should be the best of both worlds. Not everyone gets the 'variable cut rack' concept, even if weighting is well judged.
M3/M4 has a version of VSS as standard, so view VSS as the top end steering option.
HighlandPete
      06-29-2015, 03:46 PM   #19
F30Andy
F30Andy's Avatar
Drives: F06 640d
HighlandPete
Pete thank you very much for answering my question.
Clear and concise as always.
Although VSS may be the top of the range steering option, In my personal opinion I am not a fan of it.
I had an M4 for a week quite recently and personally thought the servo steering in the 3d felt better.
Each to their own though I suppose.
      06-29-2015, 06:26 PM   #20
NISFAN
NISFAN's Avatar
Drives: The best kind of F30 :)
HighlandPete
Not the same, f30 VSS is made by Thyssenkrupp. The f80 steering and also Servotronic are both made by ZF
      06-29-2015, 06:33 PM   #21
F30Andy
F30Andy's Avatar
Drives: F06 640d
Would you go as far as to say the VSS in the F30 is better than the one in the F80?
      06-29-2015, 06:42 PM   #22
NISFAN
NISFAN's Avatar
Difficult to say.....I think there is more feel to the F30 VSS, but that could be due to the smaller tyres and different geo. Makes it feel a little more nimble.
