BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BMS JB Stage 1 vs. AFE Power Scorcher Module
Evolution of Speed
      02-24-2013, 12:57 AM   #23
dgzill
Drives: 2013 BMW 328i
Originally Posted by roup23 View Post
I started the other BMS vs AFE tune thread. I ended up going with BMS because most the other members had experience with it unlike the AFE tune which is relatively new. So it made sense to go with the more reputable one.
I made no mistake, get the BMS you won't be disappointed. I have shocked others with my "328i" , and It always puts a smile on my face . With the tune, plus a temporary muffler delete (I was really curious how it sounds), and sports +, it surprises me how we can get that power off a n26!
Awesome man...any info on the effects on the warranty?
2013 328i 6mt Sport Line
      02-24-2013, 05:19 AM   #24
VANOS
NFS
VANOS's Avatar
Drives: N/A
Originally Posted by Blake P
We need to line up some cars with BMS and AFE tunes (no exhaust, intake, IC, etc.) for some side by side comparisons, both from a dig and rolling. Ok, go!
That would be awesome and I totally agree with you! That's the only way you can truly know which of the tunes performances the best.
      02-24-2013, 05:26 AM   #25
VANOS
NFS
VANOS's Avatar
Drives: N/A
No way! Sounds like BMS is the way to go. Looks like I will be purchasing the tune very soon! And how long have you had it on your car? Run into any engine problems? Anything at all? I just want to know if the tune could possibly ruin the turbos or the engine. Because my car is a lease and i really wouldn't want to damage and pay for damages on the engine or turbos.
      02-24-2013, 05:32 AM   #26
///KM
Drives: E90 M3
I have the aFe tune, and I'm very happy with the results. It taps into two sensors (MAP & TMAP), which is different from BMS' method. By utilizing those two sensors only, I don't think boost pressure is touched. Instead, I think it modifies the AFR and TPS voltage to achieve results - pretty genius if you ask me, and it should be a very safe and reliable tune for these reasons.
Install is a 5 minute affair, very easy to install and remove.
Fuel economy has improved for me - in two full tanks since install, MPG went from 29.1 to 30.5 and 30.3 per tank. That's with the same driving behavior before & after - commute to/from work.
That being said, the aFe solution likely will not have an upgradeable Stage 2 like the BMS tune, as there aren't any accessible ports.
You can't go wrong with either choice IMO. I went with aFe for the ease of install and reliability in how it goes about achieving the power increase (not touching boost pressure).
E90 M3 6MT AW/FR
RAYS | Akrapovic | Evolve | Stoptech | Tecnocraft | CAE | Arkym | Swift
E91 328i Wagon 6MT Tiag/Blk
      02-24-2013, 08:27 AM   #27
David328M-Sport
Australia
75
Of course it might, if BMW can 'prove' the tune cause the problem. This is why Mike states the S1 does not throw any codes and the unit can easily be removed prior to taking the car in to the dealer for any warranty work.
You can read other threads, which discusses this and other mods & possible warranty ramifications.
Common sense should prevail.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      02-24-2013, 08:28 AM   #28
David328M-Sport
Australia
75
I agree. Both are fairly light boosts.
      02-24-2013, 12:18 PM   #29
mrtorque
Drives: '13 328i sport line
My car is a lease too! And I had the same exact concern as you guys with warranty and ruining the engine and turbos. I was also very worried about the car throwing any hidden tuner codes that BMW might be able to access, so I bought the CAN tool from BMS which apparently "automatically deletes" codes if they should appear, but ill never know about that one cause there is no light on the Can tool or indication that anything is going on cause of the limited support on the F30, sucks I know :/.
As for engine problems I haven't ran into any and I have had the tune for about 3 months now, turbos definitely are louder especially in sports mode (which is to be expected!).
But keep in mind this is a very mild tune, and tricks the Cars ecu setting within its own parameters, so it really shouldn't set off any flags with warranty. Just don't drive the car like a racecar redlining it alllll the time, you should be fine
      02-24-2013, 01:24 PM   #30
dgzill
Great..thanks for the reply...I will continue to research. I have had heavily modified cars in the past and I told myself I would not mod this one....that may be out the window especially for this tune which is easy to remove, fairly inexpensive and makes so much power. The aFe sounds intriguing as well now...good stuff guys
      02-24-2013, 07:23 PM   #31
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
No, it modifies the MAP and TMAP output, which are both boost sensors, to fool the car in to thinking its running a little less boost than it actually is. And the DME responds by raising duty cycle adding a little boost. The BMS JB Stage1 uses a similar technique to fool the DME but with addl sensor data available to it has a more sophisticated algorithm.
The Stage2 upgrade kit is basically a new control box and 4 extra wires that plug in to give the tune full CAN access. Which opens up a whole new world on the tuning end. I'm hoping they will do some dyno testing next week for me to share. Their 328 has had the Stage2 BETA on it for a couple weeks now.
Mike
****APRIL SALES AND COMBO DEALS!! - CLICK HERE!!****
N54 Catless Downpipes - 349.00 Shipped!! ER Products 10% OFF + FREE SHIP PURE TURBOS - ON CRAZY SALE JB4 SALE!! $50.00 OFF + FREE EXPRESS SHIP
      02-24-2013, 07:37 PM   #32
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: JB E84 xDrive28i & IB E85 Z4M
Mike
      02-24-2013, 08:18 PM   #33
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Mike
Originally Posted by tiltmode43 View Post
Man, I can't wait!
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      02-24-2013, 08:38 PM   #34
David328M-Sport
Australia
75
Great news. Thanks for the update and a little more info about BMS Stage 1.
      02-24-2013, 10:48 PM   #35
ixse
Drives: 2015 boxster s
do you need to have stg 1 prior to purchasing stg 2 when it comes out? or can u just buy into stg 2 right away?
      02-24-2013, 11:51 PM   #36
David328M-Sport
Australia
75
Step 1 - Stage 1
Step 2 - Plug Stage 2 into back of Stage 1.
Yep. Stage 1 first, then Stage 2 when it arrives to market. Or you could buy both at the same time, but install S1 first, then S2.
Cheers
      02-25-2013, 01:25 AM   #37
VANOS
NFS
VANOS's Avatar
Drives: N/A
Now if I were to take my car to service would they be able to see the codes from the aFe tune or would they be able to trace it to that? Because I know with BMS they wouldn't be able to know.
Thanks for the help btw!
      02-25-2013, 10:47 AM   #38
mocohead
mocohead's Avatar
31
Drives: '16 M235i 6MT & 12 128i Msport
I wonder if any of the tuners are willing to issue a written guarantee (instead of internet banter) that their tunes will not trip hidden tune detection codes? If they are confident their tunes are safe, they should be willing to stand behind their marketing fluff with something binding.
Anybody with these tunes willing to take their cars to their local dealership and have the car checked for hidden tune detection codes?
      02-25-2013, 11:40 AM   #39
mrtorque
Agreed!! Definitely a huge selling point for me lol
      02-25-2013, 01:10 PM   #40
Mike@N54Tuning.com
No one is going to want to be your partner in warranty fraud. But my advice if you are worried about tuner codes is to get BMS CAN Tool, the BT Cable, or the N20 Stage2 upgrade, all of which can read/delete hidden BMW tuner codes.
Mike
      02-25-2013, 02:07 PM   #41
mocohead
mocohead's Avatar
31
Mike
What you're saying is that you won't partner in warranty fraud, but if your customers want to commit it, you will gladly sell them a product to help. When you get a moment you might want to look-up the definition of hypocrisy...
      02-25-2013, 02:39 PM   #42
mrtorque
Mike
Mike, thank you for all the info you post on the forums, I just have to clarify something for everyone else from first hand experience. The CAN tool does not have the capability to read codes on the f30. I was misinformed about this from Terry, who said it can "read/delete" codes but in fact only auto deletes codes. You really don't know if its deleting anything, you just plug it in and hope it does what its supposed to do. If you really want to see/read if any hidden codes are thrown get the BT cable. Im sure The CAN tool works great on other bodys but not the F30
      02-25-2013, 02:51 PM   #43
Jamesons Viggen
Hypocrisy is one thing, law-suits are another. Welcome to America.
      02-25-2013, 09:00 PM   #44
bnekic
Drives: 2013 328i xDrive Sport Line
If your too much of a baby to mod your car then don't! Plus no one is going to take responsibility for your actions.
I got car warranty work performed on my car 3 times now and it has exhaust, intake and tune.
