BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Juice box on AH3?
Extreme Power House
      02-24-2013, 06:48 PM   #1
Jparker82
Drives: 2014 335 M sport 2014 X6
Juice box on AH3?
Has anyone added a juice box to the New AH3? Of what I have read it would get the horse power up to 440.
      02-24-2013, 06:55 PM   #2
Bowser330
Drives: i3 REX
I would contact Terry Burger the owner of Burger Motor sports and ask him directly. I emailed him and he told me there were AH3 owners with the stage 1 tune out there...but I would reach out to hear it from him personally.
      02-24-2013, 07:47 PM   #3
Jparker82
Thanks
      02-25-2013, 06:26 PM   #4
Boosted John
Internet Ninja
Boosted John's Avatar
45
Drives: 13 AH3
anyone reach out to him yet?
2013 BMW ActiveHybrid 3 /// Msport Pkg. M performance fornt lip, Black Kidney Grills, H&R Sport Springs, BBS CH-R
      03-18-2013, 07:23 PM   #5
Jparker82
No I have not reached out yet. But I will soon.
      03-24-2013, 02:13 PM   #6
Jparker82
Terry at BMS said the N55 stage 1 chip will work for AH3.
      03-25-2013, 07:08 PM   #7
TN_3
TN_3's Avatar
Drives: 2016 M3 F80
Does it affect the hybrid system and its integration at all?
2016 M3 F80 l SSII l SO l CF l EXEC l LED l DCT l BLK 19 l ADAPT M l MPE (PCD 4/1/16)
2017 X5 xDrive35d F15 l GS l BLACK l ALUM HEX l M-SPORT l PREM l CW l DA l LED l HK l ADAPT M l BLACK 20"
      03-26-2013, 05:51 PM   #8
Jparker82
I have no idea. I think it's to much of a risk.
      03-26-2013, 07:06 PM   #9
tdizzle
Drives: 2017 F80 ZCP
Doubtful. Think it just turns up boost 3.5 psi.
      03-26-2013, 11:52 PM   #10
zenmaster
Drives: '17 M2
In what manner? Is that the one that modifies the temp sensor?
      04-11-2013, 01:37 AM   #11
Boosted John
Internet Ninja
45
Drives: 13 AH3
I have a JB4 sitting in my office. I am just afraid to install it. I'm hoping someone does it first..lol...
      04-14-2013, 10:20 AM   #12
Jparker82
Yea it's a scary thought. What would this engine cost to replace? 20k.... IDK but I am in the same boat as you. My thought is its gonna confuse the Hybrid system and maybe blow something. I might check into to M performance kit and see what that does or even if its possible to instal.
      04-14-2013, 01:19 PM   #13
SamS
SamS's Avatar
Drives: 2018 X3 M40i
Dealer won't install PPK on the AH3.
2018 X3 M40i - current
2016 M3 - sold
2013 ActiveHybrid 3 - sold
2012 M3 coupe - sold
      04-14-2013, 05:50 PM   #14
DarkTrigger
Professional
DarkTrigger's Avatar
Drives: 335i MPPK
That's a bummer. But don't u get more go anyways with the electric motor?
      04-15-2013, 08:27 PM   #15
Jparker82
Yep. Electric engine has 55 HP. Think it adds 40 in eco boost.
      09-10-2014, 01:57 PM   #16
franzzz
franzzz's Avatar
Italy
100
Drives: BMW M4
Installed ?
BMW F82 M4 Black -BPMSport-CS Map - GTS DKG - Navi -Performance Brake - USB-DivX-DVD- Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      09-18-2014, 02:12 PM   #17
RLSinCO
Drives: BMW AH3
I've added the JB4Stage 2 tune to my AH3.
It works flawlessly, I'm using Map1 as I have no other modifications.
I notice a difference in power over stock and this does not in any way interfere with the hybrid operations of the vehicle.
Just make absolutely certain to disconnect the battery BEFORE attempting any kind of installation. You should be able to do the installation yourself.
Some tips:
1) Print out the installation instructions in color for reference.
2) If stage 2, ignore the tapping location in the install guide for the two can wires and instead access them from the plastic shielding (this simply reduces visible detection of the pinhole splice)
3) Note for the stage 2 install, this requires power and you will need a T50 torx bit to loosen the power bolt, but if you don't have or want to buy this part, just get some thick, double-sided adhesive tape and wrap it around the bolt, and then use vice grip pliers to loosen.
4) remember to disconnect battery before any work!
5) You might get an error when reconnecting battery and turning vehicle on, - this is normal and a simple switch off, then on again of ignition clears it.
6) Find a plastic food bag, and wrap the JB4 prior to installation to protect from potential water exposure...I simply used tape to seal it around the wires.
7) I placed the JB4 underneath the rear plastic cover ( this can be easily lifted off by turning the plastic locking bolts a quarter turn) for increased protection.
8) Enjoy!
      09-18-2014, 02:16 PM   #18
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
      09-18-2014, 02:25 PM   #19
franzzz
franzzz's Avatar
Italy
100
Drives: BMW M4
Ordered JB stage 1 for my AH3
Stay tuned for review, pics and performance analysis
      09-18-2014, 02:27 PM   #20
RLSinCO
Drives: BMW AH3
By the way, I should add that I find it incredible that I can still average 42+mpg on my commute to/from work, but still have the ability to unleash a beast from within this car.
My car brethren are in awe of the combination of fuel efficiency and power.
      09-18-2014, 02:28 PM   #21
RLSinCO
Drives: BMW AH3
Arrgghhh, forgot to add in my tips section: find a plastic food bag and wrap the JB4 prior to installation...just tape around where the wires exit. This is to reduce likelihood of water damaging the unit.
I'll modify my post, above...
      09-18-2014, 02:35 PM   #22
RLSinCO
Drives: BMW AH3
If you are planning to capture performance analysis, did you also get the USB cable? You can easily run this from under your hood, through a crack in the passenger door (while still being able to close the door) in order to connect to a laptop. You will need to do so to capture data during WOT runs. In addition, this is the most simple way to determine which map is currently active...
