BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > iPod current Song Info won't update
Extreme Power House
      02-25-2013, 04:55 AM   #1
AntBabeee
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
I have an iPod touch 4th on 6.1 hooked up via USB. When I select songs on it through idrive it'll play but when I skip a song and go next. Sometimes idrive doesn't update the song info to the new song that playing its still stuck on the previous song. Sometimes stuck for a while. It happens more often if I use the steering wheel scroll button to change song. Apparently 6.1 allows me to change the song and select song on the iPod at the same time it's connected to car through USB. Doesn't show the accessory screen that blocks are controls.
Anyone else have this problem?
What did you do to fix it?
F30 BMW 335i M-Sport: Estoril Blue II, 19" Rims, Sports Auto, Premium, Technology, Harmon Kardon, Heated Front Seats, Driver Assistance...
      02-25-2013, 05:49 PM   #2
AntBabeee
bump...
      02-28-2013, 05:30 AM   #3
AntBabeee
Anyone?
      02-28-2013, 08:31 AM   #4
Axman85
Drives: 335i x-Drive M-Sport Min. Grey
Have the same issue with iPhone 4S. The other quirky thing is that the radio doesn't know what station it was last on when the car is turned on after being off a few hours. The radio station will be the same as the last one played except there won't be a check next to it in the display. Quite annoying when you don't know the stations call sign or nick name. The screen also doesn't update when using one of the eight memory buttons to recall a station.
Will ask my dealer about it when it goes in. Probably going to have to live with it.
      02-28-2013, 05:07 PM   #5
AntBabeee
i tried restarting drive and doesnt work completely. I just restored my ipod touch, lets see if it continues again. I happens on my iphone 5 too. Dont recall it happening when i was on 6.0 for my iPod...
      02-28-2013, 06:07 PM   #6
ScarecrowBoat
Zooombie attaaack!!
ScarecrowBoat's Avatar
Drives: 328
Happens to me occasionally. The album art will be correct but the song doesn't update. It has to do with the iPod, not the car. Knowing Apple, they'll never fix it.
      02-28-2013, 08:42 PM   #7
awizon
Drives: 2010 BMW 328i Coupe
I think there are a few software issues with the iPod interface. Besides the long delay mentioned above, I found that with my 7th gen iPod, if I'm playing a playlist and go back to look at playlists, it always starts at my first playlist, not the one I'm currently playing. I'm pretty sure my previous 3-series (2010) did the later. Maybe people don't mind that behavior, but I like the system to keep the playlist position when I go to search again.
Also, there is definitely processor lag with current version iDrive. That is one thing that will be much better in next version. System is still great, but wish they had released the next version already.
      03-01-2013, 08:35 PM   #8
Axman85
Album art. Don't even get that.
      03-04-2013, 11:49 AM   #9
ScarecrowBoat
Zooombie attaaack!!
Drives: 328
Is there a confirmed issue with album art or are you speculating
      03-04-2013, 02:47 PM   #10
AntBabeee
I get album art. it just the song info dont change. I actually want to know is there a way to disable album art all together. haha
      03-04-2013, 03:51 PM   #11
Axman85
I don't get album art.
      04-03-2013, 08:10 AM   #12
Rajput
Drives: BMW F30 320d 2012
I have the base system and am using a 160gb 7th gen ipod classic.
I don't get any kind of album art.
I have smart playlists set up in iTunes, e.g. play all songs where the playcount is <10 (and therefore if >10 remove from playlist). This way I get to listen to all of my music over time, and not just my favourites.
If I start off with a song in a playlist on my ipod, and then connect it to the usb/ipod interface, the screen displays only the name of the current playing song. It's not possible to see what's coming up next, but, the title is always correct for whatever is playing.
If on the other hand I choose a playlist via iDrive i.e. after the ipod has been connected, then I can see the name of the "current" playing song, as well as what's coming up next. Effectively iDrive has read the contents of the playlist, so if you have say 100 songs in the playlist, it will display all 100 songs as potential plays. HOWEVER, as the ipod plays songs it effectively updates the smart playlist i.e. if I start out with 100 songs and play 3 of them, then there are only 97 songs remaining to play. Unfortunately, iDrive can't handle this as it thinks there are still 100 songs in the playlist, when in reality there are now only 97. iDrive doesn't update exactly at the end of a song, to say the song has finished, and this time lag is an issue, because by now a new song could have started playing. Hence it ends up displaying the wrong song title.
It's the fact that iDrive reads playlist contents in advance which is the problem.
I haven't tried playing a "static" playlist, to see if the same problem arises, or a smart playlist where none of the songs are removed from the list e.g. all songs by the same artist". Will have to try it out later to see if the song info updates properly or not. I can't remember if the playing via USB has the same problem, as playlist contents don't change - unlike with the latest ipod. I'm also going to disable the smart playlist update feature when I next update my ipod and see if i get the wrong song info if i select a playlist via iDrive.
      04-03-2013, 09:17 AM   #13
narlus
Drives: 2013 335xi
somewhat related...does anyone have a problem w/ their iPod freezing up? i have had to do a hard reset at least a dozen times in the ~4 weeks I've had my car...it's getting annoying.
The occurrence is not predictable either. it can happen during song skips, searches, or even during playback. all of a sudden, the music stops and the iPod option on the screen is grayed out as unavailable. the iPod screen itself will say 'OK to disconnect'
is this an iPod issue, a BMW connectivity issue, or both? for the record, i am in a 2013 335xi and am using the latest generation iPod 160GB model (almost filled).
as a side note, i do like seeing album art (virtually all my mp3s are tagged correctly, with album art) but the screen resolution is rather dodgy...why couldn't have BMW spec'd a slightly nicer screen so the image isn't pixelated?
      04-03-2013, 10:36 AM   #14
chriskd
Drives: 2016 340i M Sport
Others have complained about ipod classics freezing up. Might be related to them using traditional platter hard drives (http://www.f30post.com/forums/showthread.php?t=817605). Try one of the ipods that use flash memory instead - I use an ipod touch and it never freezes.
As for screen resolution for album art, again my ipod touch was a better choice due to its screen resolution. The album art from my ipod classic was pretty crappy (http://www.f30post.com/forums/showthread.php?t=816572)
      04-03-2013, 11:57 AM   #15
ghettodefendant
ghettodefendant's Avatar
Australia
Drives: F30 328i Sportline
2012 BMW 328i  [0.00]
I'm pretty sure the iPod classic album art is stored in a lower resolution then that of an iPhone or touch. That would be why it's pixelated.
      04-03-2013, 12:39 PM   #16
diesel86
Drives: 2012 BMW 328i Sportline
I would agree that it is most likely an iPod malfunction vs. an iDrive issue. Our 4Runner has an aftermarket Pioneer navigation system with iPod integration. Every so often, the on-screen song data is blank or just plain wrong. Everytime that has happened, it's been an iPod issue. When that happens, the iPod usually freezes and requires a restart. The restart always fixes the issue in my case. Based on the fact that it lives permanently in my glove box...and I live in Phoenix, I'm surprised it works at all!
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      04-03-2013, 03:22 PM   #17
AntBabeee
Could be a classic... i use an ipod touch. my ipod classic use to freeze all the time in my old car too. you can hear the harddrive clicking.
+1
I understand what your saying and all but i dont use any smart playlist. and it still stuck on previous song title. tends to happen more when i change songs from the HUDs or on the ipod itself.
      04-03-2013, 04:22 PM   #18
narlus
Drives: 2013 335xi
i am not sure that's true...i manually added the artwork myself, not via iTunes...most of the images are at least 600px in dimension.
maybe i'll try my iPad to see how that looks.
and yeah, it's an iPod classic...there's no way they will come out w/ a HDD-based iPod that has 160GB capacity.
      04-03-2013, 04:53 PM   #19
Rajput
UPDATE:
I've tested my smart playlist vs. static (i.e. non live updating) and I can report that it now always seems to show the correct name.
In iTunes I left my smart list 'live update' ticked, synched the ipod, then removed the 'live update' tick in the smart list, and re-synched the ipod, so that it thinks that smart updating is not required. This has solved the wrong name for the song playing problem. I can now scroll up and down and it plays the correct song by title when I select the same playlist via iDrive. I can select different songs either via iDrive on the screen, or the scroll wheel on the steering wheel, both 'upwards' and 'downwards', and it plays the correct song as shown by title, which until today I've never managed to get it to do correctly. The song title changes to the new title after about 3 seconds after the new song starts, when going from one song finishing to the new one starting.
With regard to ipod freezing. My ipod was doing the same, even though it was barely a month old, a couple/few times in the car, but usually after i removed it from the car and when I connected it to my pc to do an iTunes sync. I would end up doing a hard reset. The local Apple store suggested I take it in to be looked at, but before I did this, I let iTunes do an ipod software update (currently I am on 2.0.4) and iTunes v11.0.2.26 and this sorted the problem.
At the moment then, by turning off the live update option, as of today, it seems to be working in the way i'd like it to.
I suggest you do a factory reset on the ipod and then let iTunes update the ipod software if required. I'm sure I did this at least once if not more, just after I first got my ipod about 4 months ago. I haven't had any problems since doing the software update.
Try the links in the following post:
https://discussions.apple.com/thread...art=0&tstart=0
