BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 328i JB4 **STAGE2** Dyno Testing -- New World Record. :)
European Auto Source
      09-01-2013, 04:11 PM   #243
rustyminded
rustyminded's Avatar
175
Drives: BMW 328i
Originally Posted by ilya_treg View Post
i already have stock 328i program without bms !
Never heard of that, maybe that's causing a conflict ?! so you mean if you don't have the bms your car is like 328i 245 hp ?!
      09-01-2013, 04:14 PM   #244
rustyminded
175
Drives: BMW 328i
change the muffler if you want to squeeze more, I would recommend the AAW +10 hp
      09-02-2013, 02:18 AM   #245
ilya_treg
Drives: f30 320i
read the topic "320i tune suggestion" there is some information from me about reflashing ) yes i got 245 hp without bms, and races with stock 328i prove it
racelogic showes 5.8 0-100
racelogic with bms st2 map 2 + downpipe - 5.1
      09-02-2013, 09:33 AM   #246
ilya_treg
Drives: f30 320i
That's pretty good but it's weird because with st.1 I got 5 sec. avg. with st2 4.6 sec.
Have you changed the piston to that in the 328i ? maybe that's causing your problem because they got different piston numbers and John said the compression is different so maybe the setting fuel/air ratio doesn't match with your piston.
No, pistons 320i
yes compression is 11-1, where did you get 4.6 s? is it on map 7 ? i cannot drive on 7 map - ecu blocking the gas i think it's detonation, i'll try someday 7 map with 102 octane
      09-02-2013, 10:38 AM   #247
rustyminded
175
Drives: BMW 328i
No, pistons 320i
If you can get Ethanol your problem is solved because st2 loves the E85
0-60= 4.6 sec
1/4 mile= 13 sec.
http://tl.acurazine.com/forums/showthread.php?t=883562
      09-02-2013, 10:38 AM   #248
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Too much ricey silliness diluting this thread topic. If mods read this, take all this 320i with unconfirmed BS Russian 320>328 tune stuff and create a separate thread for it.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      10-06-2013, 11:28 AM   #249
stealth-twntrbo
stealth-twntrbo's Avatar
Drives: F10 535XI
Wish there was a way to push that torque curve to the right and create more peak power at like 6500
      10-10-2013, 10:03 AM   #250
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
Send a message via Yahoo to john08135i
When will this be available to purchase for the N20?
M Sport Line Estoril Blue
      10-10-2013, 04:43 PM   #251
palakat
Drives: 328xi
I think this is it, correct me if im wrong.
http://www.n54tuning.com/index.php?_...&productId=131
      10-10-2013, 08:51 PM   #252
Shmouzer
Drives: 2013 BMW 328i xDrive
Coworker told me to get something like this for my stock 328i, do I absolutely NEED to get the stage1 mod before I can even use the stage2? Thanks for any help.
      10-11-2013, 11:14 PM   #253
AgentCircus
Aviator
20
Drives: M235i xDrive, UH-60 Blackhawk
You can install stage 1 and stage 2 at the same time.
      10-21-2013, 04:35 PM   #254
FrozenDarkness
two questions:
Can someone point me to the installation guide for stage 2? It doesn't seem to be easily found
And also, where to download new firmware for stage 2? Everything I find seem to be for the N54/N55 engine not the N20
      10-23-2013, 10:43 PM   #255
NosceTeIpsum
Drives: 2013 328i xdrive
Originally Posted by David328M-Sport View Post
In fact, those who use 93AKI/98RON can up the turbo boost in Stage 1 from 3psi default to 4psi, using the special USB cable.
Is this cable from the tuners only or can i pick one up on ebay or amazon?
I just got stage1 and i have a e85gas station down the street and i always use 93aki....i would like to bring to +4
      10-24-2013, 03:04 AM   #256
David328M-Sport
Australia
75
Best to buy it from the manufacturer as it's a purpose built cable.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect. JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      10-24-2013, 09:51 AM   #257
NosceTeIpsum
Will do thank you!
      10-24-2013, 07:40 PM   #258
izzyM2
izzyM2's Avatar
Drives: M2 DCT, Mini CS & AMG GLC43
I am a little bit confuse. I found a reseller and he is saying they only sell the stage 2 version. I was wondering why so. I thought you have to get the stage 1 to get the stage 2 or is the stage 2 already package as one unit... and is it final already or still in testing stage.
      10-25-2013, 01:53 AM   #259
RSXDC5
RSXDC5's Avatar
137
Drives: M3
It's because you need to physically modify your stage 1 BMS harness to get it up to Stage 2 spec
      10-25-2013, 03:08 AM   #260
izzyM2
izzyM2's Avatar
I don't have a stage 1. So does the stage 2 look like the stage 1? I just want to make sure I'm not being sold a stage 2 that actually is a stage 1.
      10-25-2013, 03:25 AM   #261
RSXDC5
RSXDC5's Avatar
137
Drives: M3
I'm not familiar with your situation, but what I do know is that you have to modify the stage one harness and add in a few more wires to it and then it becomes a stage "two" harness. Along with the modifications to your stage one BMS harness you will also receive a new control box from BMS that your (now) upgraded harness plugs into. Those are the physical differences between the stage one and a stage two BMS tune.
2015 M3 - Alpine White 6Spd
LED's, CCB's, Adaptive Dampers, Swifts, VRSF DP's, GC Camber Plates, 275/305 AD08R, Signature Wheels SV103 19x10.5/11.5
      10-25-2013, 04:33 AM   #262
izzyM2
izzyM2's Avatar
^^ thanks for your help. But like I said I don't haver any tune whatsoever. So if I'm getting the full stage 2 am I gonna end up doing some rewiring like what you had to do or am I getting a product that's fully plug n play?
      10-25-2013, 12:29 PM   #263
RSXDC5
RSXDC5's Avatar
137
Drives: M3
I believe you have to do the wiring regardless, aka the product is not plug and play when you receive it. I would contact BMS via email to confirm this though.
      10-25-2013, 04:40 PM   #264
David328M-Sport
Australia
75
If the Stage1 was shipped prior to 5/31/2013 select "Needs Wires", or if it was sent after select "Has Wires". This refers to 4 extra add on wires used for Stage2. New N20 Stage2 systems (not upgrades) are listed under the N55 Stage2 tune.
